Ocala: The Swamping Chronicles - Page 5 - Ford Bronco Forum
 31Likes
post #81 of 1117 (permalink) Old 02-25-2015, 07:03 AM Thread Starter
digger159's Avatar
Bronco Info: 1987 Ford Bronco XLT 302 w/AOD 32 x 11.5 BFG MT's k&n filter
Originally Posted by pfun41 View Post
I make time where it needs to be.
Should I bring my chainsaw? Or should I just worry about avoiding ditches this time?
Avoiding ditches??? I swear bud, you were so centered and deep it look like you tried that...
Mar. 21 or Mar. 28 ?
"I never met a fish I didn't like. "
digger159
digger159 is offline
post #82 of 1117 (permalink) Old 02-25-2015, 07:11 AM
Erik
'89Bronco302's Avatar
28th would be good..
'89Bronco302 is offline
post #83 of 1117 (permalink) Old 02-26-2015, 01:37 PM Thread Starter
digger159's Avatar
We have 3 for the 28th..I am staying the night if weather permits...got some firewood saved from yardwork....
digger159
post #84 of 1117 (permalink) Old 02-26-2015, 03:25 PM
September 15 FOTM
ANGELO's Avatar
Bronco Info: 1992 F-250 custom, 7.3 idi N/A, zf5, 4x4
28th is fine, but i would rather stay the night.
1995 red xlt sport! with 351
ANGELO is offline
post #85 of 1117 (permalink) Old 02-26-2015, 04:24 PM
pfun41's Avatar
I'm staying the night, should be a little warmer this time. I only have a little bit of wood left, I'll bring a chainsaw.
pfun41 is offline
post #86 of 1117 (permalink) Old 02-26-2015, 06:55 PM
Erik
I'll camp out again. Maybe have time to make some food beforehand too.
post #87 of 1117 (permalink) Old 02-27-2015, 02:08 PM Thread Starter
digger159's Avatar
Let's go swampin'...!!! I just coated the whole floor two mores times with the dura-liner stuff. Including 2 coats on tailgate this time. Rebuilt back brakes...lubed and adjusted front bearings and hubs...repainted the selector lever on the hubs....installed new poly bushings in the front shocks....getting a new air intake mod completed...oh yeah, and I'm stocked up on wire...
I'm gonna go topless for the ride...maybe I can get scuba-Steve to ride in the back of my truck...
Where the heck is jermil01 ???
digger159
post #88 of 1117 (permalink) Old 02-27-2015, 03:09 PM
September 15 FOTM
ANGELO's Avatar
im working on my intake to.
might have a rebuilt 351 by then too
ANGELO is offline
post #89 of 1117 (permalink) Old 02-27-2015, 03:12 PM
I'm here...should be able to make this, but probably won't be staying over.
jermil01 is offline
post #90 of 1117 (permalink) Old 02-27-2015, 04:11 PM
pfun41's Avatar
And I'm just sitting here ****ing around with a Dodge.
pfun41 is offline
post #91 of 1117 (permalink) Old 02-27-2015, 04:22 PM
September 15 FOTM
ANGELO's Avatar
are you going to bring your book?
ANGELO is offline
post #92 of 1117 (permalink) Old 02-27-2015, 04:24 PM
pfun41's Avatar
pfun41 is offline
post #93 of 1117 (permalink) Old 02-27-2015, 04:41 PM
September 15 FOTM
ANGELO's Avatar
the Sasquatch book
ANGELO is offline
post #94 of 1117 (permalink) Old 02-27-2015, 04:44 PM
Erik
I also have been doing a lot of work to my bronco. Still have that damn idle issue though.
post #95 of 1117 (permalink) Old 02-27-2015, 05:24 PM Thread Starter
digger159's Avatar
yes I will bring a copy of my book........i will also show you guys the picture I will be using for the cover of the next book...HD pic of a Sasquatch up close...
I will also have my new door gasket kit on by then....this thing will float...
digger159
post #96 of 1117 (permalink) Old 02-27-2015, 07:48 PM
pfun41's Avatar
the Sasquatch book
Did you sort out those vacuum lines? What about the smog pump. Also did you have cats? I can't remember.
Every time you say that word I think of this:
I just drove mine for the first time in a few days, I realized I have alot of work to do. When your more comfortable steering a smelly truck being pulled down the interstate than in your own vehicle there's a problem.
Yours doesn't need to float mine does! I'm the one with carpet.
pfun41 is offline
post #97 of 1117 (permalink) Old 02-27-2015, 09:24 PM
September 15 FOTM
ANGELO's Avatar
is that question for me or eric?
ANGELO is offline
post #98 of 1117 (permalink) Old 02-27-2015, 09:32 PM
pfun41's Avatar
One of you has the tangled vacuum lines the other has the oil burner for an engine.
pfun41 is offline
post #99 of 1117 (permalink) Old 02-27-2015, 09:42 PM
September 15 FOTM
ANGELO's Avatar
it will run of gas at the next meet.
i have a bassani high flow cat. i saw one of your posts about using the van air injection tubes that go to the manifolods but i have headers. im going to talk to the machine shop to see what i can do
ANGELO is offline
post #100 of 1117 (permalink) Old 02-27-2015, 09:51 PM
pfun41's Avatar
Perfect! Just get some nuts or fittings that fit the van AIR injection tubes and weld them into the headers. No machining required.
pfun41 is offline
  Ford Bronco Forum > Wheeling > Dixie Chapter
