Florida wrenching & mods - Page 3 - Ford Bronco Forum
 16Likes
post #41 of 654 (permalink) Old 10-14-2015, 10:15 PM
Nothing beets a Fullsize
Kingfish999's Avatar
i know someone selling a good set of GT40P heads for 75$ but i bet i can get him down even lower for ya but unfortunatly that would require special headers. and i already have a GT40 intake ill give you that i jsut pulled from the F250. and i always have a few sets of EV6 injectors laying around ill give ya also. that saginaw pump. ill hook ya up man! just say the word and ill help ya out
btw u can probably buy an entire engine gasket kit for cheaper than you spent buying them all seperate.
Kingfish999 is online now
post #42 of 654 (permalink) Old 10-15-2015, 08:34 AM
Originally Posted by digger159 View Post
jermil, thanks for pointing out my psycho tendencies...rofl..
we all have them..
jermil01 is online now
post #43 of 654 (permalink) Old 10-16-2015, 01:01 PM Thread Starter
digger159's Avatar
Bronco Info: 1987 Ford Bronco XLT 302 w/AOD 32 x 11.5 BFG MT's k&n filter
drive tests have gone perfect for the new gasket, etc...
"I never met a fish I didn't like. "
digger159
digger159 is offline
post #44 of 654 (permalink) Old 10-16-2015, 02:13 PM
that's purdy...nice and clean..
post #45 of 654 (permalink) Old 10-16-2015, 09:49 PM
pfun41's Avatar
But for the love of all that is holy could we get something other than a Fram on there?
pfun41 is offline
post #46 of 654 (permalink) Old 10-17-2015, 06:24 AM Thread Starter
digger159's Avatar
why you raggin' on my Fram ???...It's new and clean...
today i put the driveshaft back on and i am going to lkq tampa to look for a matching rim to my truck...
the front axle and wheels are the last thing left under the vehicle to change/ rebuild of the drive train except motor and tranny...
digger159
post #47 of 654 (permalink) Old 10-17-2015, 10:13 AM
Fram has a bad reputation. especially with the anti-drainback valve that lets oil drain out of it when engine sits idle. that means every time you start the engine it has to spend abit of time refilling the filter and isnt oiling the engine so it can cause worn bearings faster. they also known to have other issues
i use Purolator or Motorcraft filters depending which is on special. i also use Motorcraft oil because its OEM and pretty cheap for a synthetic blend. usually get filter and oil on special for 25$
I have a limited slip Dana 44 differential if you want it for when u tear the front axle apart
dash_cam likes this.
post #48 of 654 (permalink) Old 10-17-2015, 02:01 PM Thread Starter
digger159's Avatar
are you gonna help me with all this wrenching putting those parts on..?
digger159
post #49 of 654 (permalink) Old 10-17-2015, 10:27 PM
ill do it for ya, i dont care. i jsut love to wrench
but the limited slip still requires meshing gears and thats something i havent gotten into doing so i wont do that.
post #50 of 654 (permalink) Old 10-17-2015, 10:29 PM
Thread Killa
jowens1126's Avatar
great job! Thats a bitch with the motor in the truck.
jowens1126 is offline
post #51 of 654 (permalink) Old 10-18-2015, 06:34 AM Thread Starter
digger159's Avatar
i appreciate the kind words guys...and the generosity, but i don't change any part out or upgrade until it breaks...plus, i have things that need attention before the heads or front gears...lol...the ttb bushings are in the next slab of work coming up in the future....any volunteers to assist on that task ???
digger159
post #52 of 654 (permalink) Old 10-18-2015, 11:56 AM
ill sell ya a used 6" front lift with extended arms 500$. u can do that while u replace the bushings
post #53 of 654 (permalink) Old 10-18-2015, 06:51 PM
September 15 FOTM
ANGELO's Avatar
Bronco Info: 1992 F-250 custom, 7.3 idi, zf5, 4x4
Will the limited slip work in a d44 solid?
1992 f250 turbo intercooled idi
ANGELO is online now
post #54 of 654 (permalink) Old 10-18-2015, 10:09 PM
yess but its for 3.73 and down. i feel like Casey needs this the most. if you guys dont want it i might go ahead and install it when i install the 6" lift im getting monday. my rear is 3.73 and my front is 3.55 so i need to regear anyways
post #55 of 654 (permalink) Old 10-18-2015, 11:45 PM
pfun41's Avatar
I think I might just need to go to straight lockers at this rate.
pfun41 is offline
post #56 of 654 (permalink) Old 10-19-2015, 08:36 AM
I wouldn't go with a full locker..a tru trac or something of that variety would be fine.
post #57 of 654 (permalink) Old 10-19-2015, 02:15 PM
pfun41's Avatar
I was talking more along the lines of an ARB or Ox locker.
Yeah right, like that will ever happen.
pfun41 is offline
post #58 of 654 (permalink) Old 10-19-2015, 08:26 PM
September 15 FOTM
ANGELO's Avatar
Before we go that far, you should do that oil change
post #59 of 654 (permalink) Old 10-19-2015, 08:42 PM
pfun41's Avatar
*Ahem* look close.
pfun41 is offline
post #60 of 654 (permalink) Old 10-20-2015, 07:25 AM Thread Starter
digger159's Avatar
well, i installed the new u-joints on the front driveshaft...and i found the matching rim for a spare finally, dang i have been searching for that for awhile now...anybody have a tire laying around that i could use as a spare ??..i sanded and painted it to match my others, ready to go on...
finding a 15" tire in mud terrain or all terrain is near impossible...just wondering if any of you guys had some tires laying around...thanks...
when do you guys wanna ride again ???..before christmas or next year early months...???
digger159
  Ford Bronco Forum > Wheeling > Dixie Chapter
