what i did tonight - Page 11 - Ford Bronco Forum
 16Likes
post #201 of 223 (permalink) Old 03-11-2017, 02:12 AM
I found a surprising number of errors in the '94 EVTM in the areas that I had problems, especially the power locks/RKE area. Just be aware that the EVTMs could be wrong, which just adds to the fun of these old trucks.
Good Luck with your project!
Mikey350 is online now
post #202 of 223 (permalink) Old 03-11-2017, 10:54 AM Thread Starter
chucklebill's Avatar
Bronco Info: 1993 black xlt ZF swap, manual hub swap, LOTS of rust repair, 1974 project http://www.fullsizebronco
thanks great i love errors lol
link to my project bronco 93' , 5.8,ZF use to be rot box
http://www.supermotors.net/getfile/1056478/fullsize/img_5427.jpg
2006 f150 screw silver
chucklebill is online now
post #203 of 223 (permalink) Old 03-12-2017, 10:17 PM Thread Starter
well hacked my wiring harnnes all to hell and back spliced in what i needed from the bronco harness and suprizingly it all works (well most of it any how still have to put a few things back in and check them out but seems like everything works
huck2080 likes this.
post #204 of 223 (permalink) Old 03-16-2017, 09:15 PM Thread Starter
last few days waiting on parts, but i did get the rest of my new frame chassis savered, i also ran all new brake lines, installed my rear most cross member, reinstalled my fuel tank (waiting on a new pump to convert to a 1995 style, my bungs for my O2 sensors came in and still need to be welded in place to accomadate for the OBDII swap. the whole underside has been chassis savered and then i used permatex bed liner over that 2 coats. next is to get the oil pan water pump,alt bracket installed, install the airpump bypass AC by pass do a tune up and install the flywheel and pilot bearing for the manual transmission
if i can get that all done next week then by the weekend i should have the engine transmission and body installed on the frame, get all the wires hooked up rad support on and i should be able to get it running by next sunday then it will be finding all the issues that its going to have from swapping over to OBDII
post #205 of 223 (permalink) Old 03-16-2017, 09:51 PM Thread Starter
so i realized while going through my supermotors page that i never posted these pics of how bad the rot was in the back of my bronco! she has come along way in the last 8 years and i think im going to keep her around for atleast another 8
this is my frame under at the up swing on the bottom before the right front shock tower
post #206 of 223 (permalink) Old 03-16-2017, 09:53 PM Thread Starter
this was my right front body mound, it comes from the fire wall and goes under the passanger floor board the forward most body mount before the fenders
post #207 of 223 (permalink) Old 03-16-2017, 11:56 PM
Harley's & Bronco's FTW!
damn man. that's freakin' zombie rot.
BikerPepe` is offline
post #208 of 223 (permalink) Old 03-17-2017, 06:04 PM Thread Starter
yeah shes come a long way hoping to be done for a few years after the OBDII swap , frame swap and putting carpet back in the front
post #209 of 223 (permalink) Old 03-17-2017, 08:39 PM
thread started 2/18/2010. Been a very, very long night.
post #210 of 223 (permalink) Old 03-27-2017, 09:44 PM Thread Starter
well an update on the 1996 obdII swap, engine is in, trans is in, transfer case is in, body is back on the frame and all the mounts allowed the bolts to drop in with a little work. tonight i ran the wires over the engine to see if my harness under the dash would allow it to crank and it did, i have spark but no injector firing, im assuming at this point is a ground issue because the only the main harness was grounded not all the little grounds around the engine bay and under the dash. so i will post more updates as they come along, tomorrow will be bedline the rad support so it can be mounted and i can install the radiator add coolant and attach all the grounds
but i did pick up this little gem over the weekend shes a bit of a diamond in the rough but its a truck i have allways wanted
post #211 of 223 (permalink) Old 03-27-2017, 10:15 PM
Resident Nice Guy
schwim's Avatar
That needs it's own thread. We must have more pics.
BikerPepe` and huck2080 like this.
schwim is online now
post #212 of 223 (permalink) Old 03-27-2017, 10:36 PM Thread Starter
im sure i cant post here lol its a bronco fourm. ive wanted one of these sence i was a kid! i need to find bed parts why doesent any one make bed sides. i will get pics before i put it to bed for a while untill i get my own shop built and can take it nut and bolt apart
post #213 of 223 (permalink) Old 03-27-2017, 10:55 PM
give us a thread in the General Discussions. It's where I often go to post pics or get help with my '73 F250.
if it weren't for Bronco's, that would be on my preferred pickup list.
chucklebill and huck2080 like this.
post #214 of 223 (permalink) Old 03-29-2017, 02:44 AM
House of Windsor 4ever!
Handy_andy_cv64's Avatar
The bed is '80-and-up. I have as my wallpaper a shot of the 1978 New York Auto Show Ford truck display, and the older round-fendered Flareside bed design is what was used. I may have long ago posted it to here, I'll have to check.
Handy_andy_cv64 is offline
post #215 of 223 (permalink) Old 03-30-2017, 10:48 PM Thread Starter
nice i sent you my e mail i thing that the 80s bed fits these trucks better i'm pretty sure that that other than the fenders the sides are the same there kinda hard to find but auto fab makes fiber glass ones, but tonight i picked up my fuel injectors then i dumped some gas down that carb of that old truck hooked up a jump box and she fired right up. after a few taps to the starter relay.
post #216 of 223 (permalink) Old 03-31-2017, 02:14 AM
That's always good. I got a few things done to Babe, my '79 Ranchero GT, and have been driving it while the Exploder awaits injectors.
New front turn/park light sockets and bulbs:
Name:	IMG_20170330_174026424 (640x360).jpg
post #217 of 223 (permalink) Old 03-31-2017, 02:15 AM
"Attached Thumbnails." You have to look real squinty to see the park lamps....
post #218 of 223 (permalink) Old 04-02-2017, 11:05 PM Thread Starter
well it was a long weekend, but i got my bronco out the door under its own power, its not road ready yet but its under its own power, the list of what i did is too long to type but the list of stuff i need to do is not so over whelming now,
i need to bleed the clutch again, install bumpers, put my dash back together, but the huge plus is that i finally got to drive it today
http://www.supermotors.net/getfile/1...e/img_9154.mov
the last few weekends ive been slowed down on my project helping a buddy work on his in the same bay as my project... will never do that agian! he has been helping me through this whole process but he is a puddy buddy. he has learned alot about owning an older vehicle. he has an 73-85 chevy, he rolled it when he was 17. brought it here (to nantucket) with a new cab, no bed, before he rolled it he put a 350 in it , swapped in a sm465 trans mated to a np205. about 6 months ago he locked up the rear end (pin fell out after the keeper bolt sheared off while driving and shut the whole motor down in a sudden jolt) we found him some 3/4 ton 8 lugs instead of rebuilding his old axles he had some stupid chevy gear ratio. so every thing was fine he bough new bed sides put them on painted it , installed his own 6" lift kit, bought 35's to put on it. so heres where it all snowballed to hell
2 weeks ago he was helpin me out he wanted to put on his new rims and tires so i said pull it in. he got the wrong lugnuts, so we were leaving and he called me and said he blew up his tranny so we towed him back to the shop and called it a night, so that weekend we pulled the trans and it was fine we pulled the bell housing and found the center of the clutch had stripped out
well while he waited for a clutch to ship he pulled his oil pan and found a drip of coolant running down the inside of the block.
so he ordered an intake/ head gasket set... well now this friday night we pulled the intake and heads off, found the failed gasket. while he was cleaning it up i was looking over the heads and found his number 7 valve peaned over and the rocker destroyed
couldnt source a set of heads of another engine this week end but it really slowed my progress down. but its almost done
post #219 of 223 (permalink) Old 04-02-2017, 11:12 PM
Resident Nice Guy
schwim's Avatar
Started out replacing rims and wrapping up replacing heads after a pitstop at the clutch? Talk about mission creep :)
post #220 of 223 (permalink) Old 04-05-2017, 09:41 PM Thread Starter
almost got my entire dashboard back together. next is trimming the carpet for the shift boot. still havent bolted the engine/transmission down. and put the bumpers on
HTML code is On
