My 67 F2Bronco Build - Page 12 - Ford Bronco Forum
 47Likes
post #221 of 250 (permalink) Old 02-14-2017, 11:54 PM Thread Starter
fordguy_78's Avatar
Bronco Info: 67 F250/88xlt Dana 60 links and stuff 37 Iroks 429
Front ready to be tacked together and double checked on clearance langth and stuff. rear tube will be cut and ready to tack up tomorrow i think.
Phill
78 Mustang Rally T-top Boss 302 TKO-500 5speed
67 F250/ 88 Bronco frame 429 SAS 37s
10 F250 Harley Davidson
fordguy_78 is offline
post #222 of 250 (permalink) Old 02-15-2017, 02:39 AM
Harley's & Bronco's FTW!
you must have a nice, warm shop Phill.
BikerPepe` is online now
post #223 of 250 (permalink) Old 02-15-2017, 09:03 AM Thread Starter
fordguy_78's Avatar
Where the truck is not so much. Where the lathe and Mill are it stays about 62 - 75 so a crap load of time has been spent in there onece I ran out of propane for the garage.
BikerPepe` likes this.
post #224 of 250 (permalink) Old 02-21-2017, 05:27 PM Thread Starter
fordguy_78's Avatar
rear drive shaft put together was a few degrees out of phase so i used the mills flat table and clamping force to make it right. may still have a shop weld them up and balance them or at least the rear.
And the big new meats showed up 4D's
JGR likes this.
Phill
post #225 of 250 (permalink) Old 02-21-2017, 11:35 PM
coming right along.
post #226 of 250 (permalink) Old 02-22-2017, 11:39 AM
JGR
Full Of Rowdy Drunks
JGR's Avatar
Bronco Info: 1986 SAS'd, 37s, otherwise stock
That is a sweet build you got there! You weren't a fan of the Baja ta's? Just curious how they did, that's what I'm running.
JGR is offline
post #227 of 250 (permalink) Old 02-22-2017, 11:43 PM Thread Starter
fordguy_78's Avatar
They had a really hard compound so I ended up always running 0-3 psi offrod otherwise they sucked. Also the plan has been to put 40s on this thing the hole time if I was going to keep the 37s I wouldn't have done 5.38:1 gearing.
JGR likes this.
post #228 of 250 (permalink) Old 02-23-2017, 10:23 PM
JGR
JGR's Avatar
Makes sense. Been looking at 16.5 tires for a while, but there really isn't a huge selection out there anymore! Rockers, or Irocks for the most part...problem, still going to be driver her on the street.
Back to your build... can't wait to see the rockers mounted on your truck!
JGR is offline
post #229 of 250 (permalink) Old 02-23-2017, 10:53 PM Thread Starter
fordguy_78's Avatar
There is also Boggers, TSLs, bfgs, and the other military take offs. SO yeah if i didn't have my h1 beadlocks i would be getting 17s i almost made my pitbull order in 17s just to force my hand to make me get different wheels.
Back to the build I got my fuel rail extrusion today, so as soon as my intake is done being welded up i can cut it in half and do my injector bung drilling.
Also put one of the tiers on rear isn't quite at full bump and the front is past full bump. Some cutting is in my future.
Front
BikerPepe` and JGR like this.
Phill
post #230 of 250 (permalink) Old 02-24-2017, 01:25 AM
where there goes the beautiful body lines. you plan to get anymore lift or all hack and slash?
post #231 of 250 (permalink) Old 02-24-2017, 11:03 AM Thread Starter
fordguy_78's Avatar
to get it up and going quickly i'll probably trim kinda like my trucks twin, but long term i'm on the look out for some usable front fenders so i can use the wheel well opening out of them to raise the rear up kinda like the auto fab fenders. Also i'm looking for a set of doors so i can make half doors out of them.
twin
auto fab
Phill
post #232 of 250 (permalink) Old 02-26-2017, 11:21 PM
Sway Is My Fan Club.
Mels's Avatar
Bronco Info: '78 Ranger XLT - 429/C6, 4"s/35s. '88 XLT - 351/C6, 6"s/35s
Your truck is f'in awesome.
Not a fan of green usually, but really like that shade.
fordguy_78 likes this.
'66 F100 -- Little Black
'78 Bronco -- Brutus
Mels is offline
post #233 of 250 (permalink) Old 03-02-2017, 12:58 AM Thread Starter
fordguy_78's Avatar
With all the reading on building efi 460 the stock 24lb injectors are right at 90% pulse width with a stock motor with freer flowing intake and exhaust so it seemed the power level i am shooting for 36lb would have be just fine but wile looking i came across 38lb ev6 injectors that came one turbo volvos and still use ev1 connections so that's what i got
Phill
post #234 of 250 (permalink) Old 03-16-2017, 04:13 PM Thread Starter
fordguy_78's Avatar
Got the short block together. now i just need to get my but in gear and get my heads together. then it will just be waiting to my buddy to finish up my intake welding then i can machine it and the fuel rails. Good thing I'm getting tuning done the computer may freak out over my cam, its the next bigger one over the one in the last motor.
Phill
post #235 of 250 (permalink) Old 03-16-2017, 04:21 PM
Hey Phill... let me know if you're heading out for any mellow to mid level wheelin' trips, early on this season.
I still need to pull my 6" an install the 4" but I haven't got this thing up in any decent trails yet.
I was thinking 7 mile should be an awesome mud put about now. Not just in places... but the whole damn ORV park.
I might even drag my ass out of bed to catch you early birds.
post #236 of 250 (permalink) Old 04-10-2017, 11:39 PM Thread Starter
fordguy_78's Avatar
sure will pepe.
Gotten a few things done
Motor back in
headers switched over to v-band clamps and o2 sensors added
Phill
post #237 of 250 (permalink) Old 04-22-2017, 12:04 PM Thread Starter
fordguy_78's Avatar
Slowly chipping away at it mainly waiting on my intake to be done being welded so i can machine it for the injectors then i can figure out my fuel system. Although lots of things are done that are not pictured trans now has a punisher valve body 4r100 trans pan. trans cooler lines redone with ptfe hose and heat shield added to keep the exhaust heat away.
Seeing how badly the air pump fits i'm thinking i can make it work
I'm relatively positive it will work with the new intake manifold it will just have more angle as the new one is 3" higher. Intake plumbing duel 55mm throttle body to 4" piping to terminator cobra / lightning 90mm maf witch isn't 90mm its 103mm as my original 90mm maf can fit inside of it. Also a remote mount iac valve because it didn't clear the 4" piping.
Phill
post #238 of 250 (permalink) Old 04-22-2017, 03:36 PM
so much of your build is over my head. are you planning to box or snorkel that K&N, Phill?
post #239 of 250 (permalink) Old 04-22-2017, 03:44 PM Thread Starter
fordguy_78's Avatar
probably box it for now and if water becomes a problem i'll figure some thing out. The one thing that's still over my head is tuning it i'm just not sure on if i should have some one do flash tune or get the interface and tune it myself. I keep putting off getting prices and seeing who all can/ wants to do it.
Phill
post #240 of 250 (permalink) Old 04-22-2017, 03:53 PM
you've done so much... you probably wouldn't be satisfied with someone else doing it.
bite the bullet and jump.
HTML code is On
