Ewgoetz's 1996 EB Build-up II - Page 4 - Ford Bronco Forum
 5Likes
post #61 of 464 (permalink) Old 11-27-2012, 12:24 AM Thread Starter
Ewgoetz's Avatar
Went to Firestone and got a new lifetime alignment for the new bko. Had them align her. Drives nice and straight now with no pulling. Next on the list is to do the front wheel bearings. Front brakes look like they are in decent shape with plenty of meat on them stil.
Ewgoetz is offline
post #62 of 464 (permalink) Old 11-27-2012, 01:19 AM
Bronco Boy 88's Avatar
Bronco Info: 88 Bronco 302 5.0L efi
Originally Posted by Ewgoetz View Post
ok, not to be a dick or anything, but those tires are WAYYY to small for that truck, the "stock" ones on the old bronco look bigger. i would run the 37s for a bit alteast and sell the other ones to try and make some money for the 35s u want.
When in doubt, throttle it out
4x4, for when big balls just aren't enough.
Bronco Boy 88 is offline
post #63 of 464 (permalink) Old 11-27-2012, 01:54 AM Thread Starter
Ewgoetz's Avatar
Np, I already have ordered 35's. Just waiting for them to come in. I dont want to run the 37 cause they were wearing out real fast as a dd. been thinking of keeping them and using them for weekend off road trips. Those in that pic are 33's. also need to get rid of the 3 inch body lift that's on it.
Ewgoetz is offline
post #64 of 464 (permalink) Old 11-27-2012, 03:15 AM
kentucky4x4's Avatar
sweet looking bronco! whered you get the headlights?
kentucky4x4 is offline
post #65 of 464 (permalink) Old 11-27-2012, 03:44 AM Thread Starter
Ewgoetz's Avatar
Got the head lights from eBay as a hid kit. Haven't ever hooked up the hid stuff yet for them. I been using the stock head light bulbs.
Ewgoetz is offline
post #66 of 464 (permalink) Old 11-27-2012, 08:21 AM
Beach bumming it ........
Saltlife's Avatar
Good looking bronco man. I saw the accident thread and sucks I really dug your ride. But good that you are keeping everything the same as the old.
The insurance company totaled your old rig and did not take it? Things must be different from FL and VA. In VA if they total it and give you the money they also take the rig, you then get a chance to buy it back for like 25% of value.
I like the tires on it but a not big fan of the wheels glad you decided to swap for your one on the old rig they look way better.
Is this a dent in the rear quarter panel? Or the angle making it look that way.
Saltlife is online now
post #67 of 464 (permalink) Old 11-27-2012, 08:46 AM Thread Starter
Ewgoetz's Avatar
I had the chance to buy it back after the totaling out. Cost me $500.
Yes it's a dent. One of the previous owners left the spare tire unlatch, causing the dent.
I took off the spare tire carrier. I got a bumper ordered with a spare tire carrier on it. Not sure when I'm gonna be getting it yet. Most likely around Christmas.
Ewgoetz is offline
post #68 of 464 (permalink) Old 11-27-2012, 08:49 AM
Saltlife's Avatar
Nice that was cheap for the buy back. Are you going to be able to pull the dent out or swap the panels from the old bronco?
post #69 of 464 (permalink) Old 11-27-2012, 08:54 AM Thread Starter
Ewgoetz's Avatar
Unfortunely my old bko has the same exact dent in the same exact panel. That's why I know why it's there lol
Ewgoetz is offline
post #70 of 464 (permalink) Old 11-27-2012, 07:03 PM Thread Starter
Ewgoetz's Avatar
Replaced the bearings and seals on the ps of the bko.
Bearings weren't to bad. The races looked like they were in good shape so I left them in.
The ps was the side that looked on the rusty/mudy color side. Pic before I started.
Used a new locking spindle nut.
Next on that side I'm gonna have to change out the ball joints. Found after changing the bearings the lower ball joint is going bad. Has some play to it.
Ewgoetz is offline
post #71 of 464 (permalink) Old 11-29-2012, 03:50 PM Thread Starter
Ewgoetz's Avatar
Finished installing led bulbs in the outside lighting. Have yet to do the interior lights and under hood.
Swaped out the turnsignal switch with the old bko(had installed a new one a year or 2 ago).
Top one is old, bottom one is the old bko's
In the progress of swapping the dash bezel, before I finish that up need to do some reinforcing to the bezel. Some areas are cracking slightly and like to repair them befor they get noticable or the switches break away completely.
Ewgoetz is offline
post #72 of 464 (permalink) Old 11-29-2012, 07:51 PM Thread Starter
Ewgoetz's Avatar
Reinforced/repaired some screw holes in the dash bezel from the old bko. Gotta wait 48 hours now for the gel epoxy to harden fully.
Ewgoetz is offline
post #73 of 464 (permalink) Old 01-02-2013, 05:25 PM
lifeizhard102205's Avatar
looks good. cant wait to see the new tires on it.
lifeizhard102205 is offline
post #74 of 464 (permalink) Old 01-18-2013, 05:11 PM Thread Starter
Ewgoetz's Avatar
They will be on as soon as I wear out the old tires I had on the Old rig.
But here's a teaser of whats going on. They are a total hight of 34.5 inches.
I transfered a few things over from the old rig today.
Outside Grab bars:
The old Trailer harness from the old Rig:
Old extended breather tub from the old rig.
Ewgoetz is offline
post #75 of 464 (permalink) Old 01-18-2013, 08:50 PM
Resurection Ranch
379sinvb's Avatar
Where did you order the Pro-comps from, 4wheel parts?
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #76 of 464 (permalink) Old 01-24-2013, 04:15 PM Thread Starter
Ewgoetz's Avatar
Yes, they were having a deal on them.
Ewgoetz is offline
post #77 of 464 (permalink) Old 01-24-2013, 04:18 PM Thread Starter
Ewgoetz's Avatar
So the double cardan joint on the rear axle are going bad. Was vibrating a lot and squeaking. Swaped in the rear drive shaft from the old bronco for a temporary fix. Not sure how long that shaft has before it starts to go on its way out. Not sure if I want to get a new shaft or have the old one rebuilt. ATM I think I'm leaning to getting a new beefier shaft.
Ewgoetz is offline
post #78 of 464 (permalink) Old 01-24-2013, 07:00 PM Thread Starter
Ewgoetz's Avatar
Gonna be ordering a 1 ton shaft from these guys.
http://www.highangledriveline.com/
Pricey but I think it will be worth it. Just gotta go outside to measure the length from flange to flange.
Ewgoetz is offline
post #79 of 464 (permalink) Old 01-26-2013, 12:38 PM
kinglank's Avatar
why not use a tom woods driveshaft?
heres his site http://4xshaft.com/
1978 Bronco
460
37s
kinglank is offline
post #80 of 464 (permalink) Old 01-26-2013, 02:21 PM Thread Starter
Ewgoetz's Avatar
I didn't come across them.
The driveline angle one I came across at pirate 4x4.
Ewgoetz is offline
HTML code is On
