Ewgoetz's 1996 EB Build-up II - Page 5 - Ford Bronco Forum
 3Likes
post #81 of 461 (permalink) Old 01-26-2013, 02:56 PM
Steve83's Avatar
Wherever it comes from, make sure it's spin-balanced to 7KRPM and warranted for a few years. There's a Spicer-authorized shop here that will be making mine...
post #82 of 461 (permalink) Old 02-08-2013, 08:27 PM Thread Starter
Ewgoetz's Avatar
Still waiting on the new drive shaft. Should be arriving soon.
Installed my new class 4 tow hitch. Had to do some modifying to the stock bumper a little.
Ewgoetz is online now
post #83 of 461 (permalink) Old 02-08-2013, 08:41 PM
Thread Killa
jowens1126's Avatar
What did you modify to get it to fit?
jowens1126 is offline
post #84 of 461 (permalink) Old 02-08-2013, 09:11 PM Thread Starter
Ewgoetz's Avatar
Had to trim a inch off the back part of the bumper. It would of fit if I left the hitch back, but I wanted the hitch to stick out a little to have a easier time pulling the pin for the ball hitch part.
post #85 of 461 (permalink) Old 02-09-2013, 05:15 PM Thread Starter
Ewgoetz's Avatar
Replaced the exhaust tips I had cut off yesterday while putting on the hitch and patched a piece of pipe that connected the cats to the muffler. Yes I know they are boogeyman welds,but its temporary for now. Later down the road I'm gonna pull it all off and clean it up and get some better welds in it.
post #86 of 461 (permalink) Old 02-09-2013, 06:00 PM
Bronco Boy 88's Avatar
Bronco Info: 88 Bronco 302 5.0L efi
What was wrong with the old tips?
When in doubt, throttle it out
4x4, for when big balls just aren't enough.
Bronco Boy 88 is offline
post #87 of 461 (permalink) Old 02-09-2013, 06:44 PM Thread Starter
Ewgoetz's Avatar
There were holes rusted threw them.
post #88 of 461 (permalink) Old 02-10-2013, 12:38 AM
Steve83's Avatar
Originally Posted by Ewgoetz View Post
Yep. That's undoubtedly a '96 Bronco exhaust! No other Ford truck has that triangular flange.
post #89 of 461 (permalink) Old 02-10-2013, 10:19 AM Thread Starter
Ewgoetz's Avatar
Here's a pic of the old tips in the trash already, with the rusted holes in them.
post #90 of 461 (permalink) Old 02-11-2013, 06:54 PM Thread Starter
Ewgoetz's Avatar
Went under the rear tailgate and replaced & cleaned up part of the ground that goes from the harness in the back to the frame.
Swaped the rear light harnesses for the tail lights from the Old bko to new Bko. Also swaped over the PS tail light from the old Bko as It was newer and undamaged. Found that cruise control no longer shuts off when I turn on a turn signal. Part of the Cruise control shutting off or not working is partialy fixed......
I'm suspecting part of the cruise control not working now has to do something with the front harness as the LED bulbs are not fully working in the front and the CC works fine when the parking lights are all off.
post #91 of 461 (permalink) Old 02-11-2013, 10:59 PM
i think all your light and cruise problems might be caused by your led flasher u installed. heard about alot of problems with those
post #92 of 461 (permalink) Old 02-12-2013, 01:58 AM
Steve83's Avatar
The rear frame ground is strictly for the trailer plug - nothing else (factory). The front parking lights have no direct effect on the cruise system. Keep checking/cleaning the grounds.
post #93 of 461 (permalink) Old 02-15-2013, 06:41 PM Thread Starter
Ewgoetz's Avatar
Got my 1ton shaft the other day. Installed it today.
post #94 of 461 (permalink) Old 02-16-2013, 10:47 AM
Thread Killa
jowens1126's Avatar
I dunno if you have the diagrams, but heres the 96 Cruise Circuit
http://sdrv.ms/WOuNzi
And 96 Ground Distribution.
http://sdrv.ms/XgaZl5
post #95 of 461 (permalink) Old 02-16-2013, 04:13 PM Thread Starter
Ewgoetz's Avatar
Thanks!
I do have a factory wiring manual, but unsure where its at right now. Also its notrealy on my primary to do list seeing I can live with out CC.
post #96 of 461 (permalink) Old 02-16-2013, 04:17 PM Thread Starter
Ewgoetz's Avatar
Started to take the Old interior door pannel off and cleaned things up under there. Replaced the Broken Door handle with one from the retired Bko. Cleaned the door pannel I wil be puting in the Bko, Still like to re-enforce parted of the Dor panel to prevent it from cracking or Braking in the future. Pannel I have is a bit in rought shape, but its better then what was on the New Bko.
Pannel removed.
Cleaned up and New Door handle installed.
I'm wondering if those are the factory speakers in that door panel still.
post #97 of 461 (permalink) Old 02-20-2013, 03:14 PM Thread Starter
Ewgoetz's Avatar
Finaly got my bronco air bumper in on Tuesday. I ordered it with a bare coating, Shackles and a tire carrier. They sent me all that + a hitch receiver. On the bright side they credited me $100 and didn't charge me for the hitch receiver.
So today I took out the plasma cutter and cut out the hitch receiver & went to my nearest metal supply and ordered some 3/16 plate to patch the receiver hole and to come down a little to hide my current class 4 hitch. Than bolted up the bumper to the back of the bko. Gonna hit it with some rattle paint to prevent surface rust from forming on it.
post #98 of 461 (permalink) Old 02-20-2013, 08:41 PM Thread Starter
Ewgoetz's Avatar
Installed the drivers side mirror tonight that I got for Christmas. Still have to wire it up.
Rattle caned the rear bumper for now also while at work.
post #99 of 461 (permalink) Old 02-22-2013, 08:26 PM Thread Starter
Ewgoetz's Avatar
Not realy liking how the shackles sit on the mount, I may do some modifying to widen that mount.
post #100 of 461 (permalink) Old 02-23-2013, 05:38 PM Thread Starter
Ewgoetz's Avatar
Installed the tie carrier and rattled caned it.
Also, loosened the bolts and nuts to the stock headers.
HTML code is On
