"help please" Ford F150 + Homemade Hummer Body = Ford H150 (Build Thread) - Page 5 - Ford Bronco Forum
post #81 of 1133 (permalink) Old 10-16-2005, 12:22 AM
Steve83's Avatar
OOOOOHHH... Finally, a perfeshinul to render an opinion on our universal/constant-velocity/double-cardan debate!
(...if we don't drive him nuts. )
Are you trained as a mechanical engineer or a draftsman?
post #82 of 1133 (permalink) Old 10-16-2005, 01:17 AM
MikE2's Avatar
OMG your not starting that again are you
Everyone except you knows a double cardan joint is a CV joint.
With U-joints on a driveshaft or on a double cardan joint its all about the angles that give it a constant velocity or not
MikE2 is offline
post #83 of 1133 (permalink) Old 10-16-2005, 07:21 AM
Bronco Info: 1989 5.0 Eddie Bauer 6" lift 35" Tires 4.88 Gears ARB locker in rear
I can only say holy shit that looks great. Very nice work.
302 powered Eddie Bauer 6" Pro Comp stage 2 lift with Sky jacker Springs in front Heddman K&N Air filter TES headers (got stay smog legal) Mass Air Conversion Rear ABS Air locker Sitting on 35" Pro Comp X-terrain.
Wildbroncobill is offline
post #84 of 1133 (permalink) Old 10-18-2005, 09:00 AM Thread Starter
H150's Avatar
as promissed
here a picture of the bender i made
here how it work, you loosen the "C"clamp and slide the sheet metal between the angles then tight the "C" clamp and lift the handle (on the right of the picture, not the visegrip)
its simple to make, all you need is 3 piece of angle and a few flat bar
here one door panel that was bend with the bender
1987 F150 hummer replica 96 PSD power
2001 Bullitt mustang SOLD
2011 JEEP JK Unlimited
H150 is offline
post #85 of 1133 (permalink) Old 11-08-2005, 11:02 PM
FSB warrior
81Bronk36's Avatar
H150, can you elaborate a little bit more on this, maybe get a few more pics???? With the c clamp does that mean that you can only do as far as you can stick the sheet metal in to the C clamp???? what if you incorperated the C clamps worm parts and 2 peices of flat bar (or the angle on top, flat on bottom and squeezed the flat up to the bottom of the angle) Would that work with that design.
1BadBronco
81Bronk36 is offline
post #86 of 1133 (permalink) Old 11-09-2005, 07:17 AM Thread Starter
H150's Avatar
You can stick as long sheet as you want all you have to do is move the "C" clamp to the outer edge, the only limit of this bender is in a "Z" bend. With the 2-1/2" angle you need 2-1/2" between the bends. Ill get better picture tonight you will see what i am talking about
H150 is offline
post #87 of 1133 (permalink) Old 11-09-2005, 10:55 AM
FSB warrior
81Bronk36's Avatar
AHH ya that makes sense!! But more pics would be nice.
1BadBronco
post #88 of 1133 (permalink) Old 11-10-2005, 10:43 PM
Mr. Asks Alot
rsm688's Avatar
Bronco Info: 78' Bronco
wow....that is amazing...
~spencer~
78 Bronco:
SUPERMOTOR PICS
SOLD....well traded, to a dealership for $7000
rsm688 is offline
post #89 of 1133 (permalink) Old 11-11-2005, 04:43 PM
She knws my tractors sexy
Bronco Info: 94 eddie bauer. 1 ton swap. Detoit, 5.13, 42'' TSLs, 8pt cage. Pro lined
Geezus thats awesome man. Good job and congrats i cant wait to see how it turns out. Bulletproof?
Take the good with the bad, smile with the sad. You've got to love what ya got and remember whatcha had.
bigbluebronco is offline
post #90 of 1133 (permalink) Old 11-11-2005, 05:07 PM
JB
Dead Horse
JB's Avatar
Bronco Info: 95 XL
thats a sweeet project, cant wait to see it completed
95 XL on 37's
99 Civic Ex w/ b18c swap
JB is offline
post #91 of 1133 (permalink) Old 11-11-2005, 07:00 PM
MyFullSize's Avatar
Bronco Info: Previously: '89 Bko XLT 351W
Please keep us updated! Great work!
1993 Jeep Cherokee Sport
* USAR/ARNG 11B RET *
1/116 INF 29ID(L) - (My unit was 1st wave on D-Day)
Read the book "The Bedford Boys"
^^ My animated .GIF is better than yours! ^^
MyFullSize is offline
post #92 of 1133 (permalink) Old 11-11-2005, 07:11 PM
XLTbeast's Avatar
Bronco Info: 74 bronco 302/C4 6.5" lift
wow i never caught this thread but i just read through in and all i have to say is dayum. that thing looks sweet but i wanna see it rollin on 37's.
94' F150 Extended Cab long bed aka the limo.
74' bronco. 302/C4 6.5" lift work in progress http://www.supermotors.net/vehicles/registry/17161
XLTbeast is offline
post #93 of 1133 (permalink) Old 11-12-2005, 11:55 AM
ruger1022's Avatar
Bronco Info: 79, Bored 351m, Wieand 4BBL, DUI Diz, Iske Cam, Heddman Headers, Magnaflow Duals, 3G, Saginaw Pump
I salute you H150. I've seen a lot of Hummer's modified with more tools than what you are using, don't come near yours...If you wanna put a couple of gun mounts on it, I can give you a few ideas that worked for us...I don't have any experience fabricating or building a Hummer, but I do have a hell of a lot of experience driving/riding in one, here's my 2 cents...make sure if you use military issue seats (canvas), do a little research and get the high back buckets for the Hummer (sorta like what you have now) , you're back will thank you for it. They started coming out right about 2002 and they are definitely worth it.
ruger1022 is offline
post #94 of 1133 (permalink) Old 11-23-2005, 04:25 PM
ruger1022's Avatar
Bronco Driver Magazine
I see your build made the Bronco Driver Magazine. Good Article.
post #95 of 1133 (permalink) Old 11-23-2005, 04:55 PM
jam0o0's Avatar
Bronco Info: 95, 5.8, E4OD, D60, ford10.25
amazing. makes me think i should learn to weld too. but that is just beautiful.
95: 351w, E4OD, BW1356, D60, 10.25, ARB, detroit, 5.13, H1's, 38" boggers
http://www.supermotors.org/vehicles/...il.php?id=9014
'93 F250 7.3 turbo, ZF5, 2wd, excab, long bed.
jam0o0 is offline
post #96 of 1133 (permalink) Old 11-23-2005, 08:28 PM
FSB warrior
81Bronk36's Avatar
1BadBronco
post #97 of 1133 (permalink) Old 11-24-2005, 07:17 AM Thread Starter
H150's Avatar
DID YOU SEE THE ARTICLE?
I haven't got my copy yet, how does it look
H150 is offline
post #98 of 1133 (permalink) Old 11-24-2005, 08:32 AM
ruger1022's Avatar
It looks really good. Think they did a professional job. It's toward the back of the magazine, in the technical section, looks to be about 4 pages. I think it's the largest article in there. Pictures came out really well too.
post #99 of 1133 (permalink) Old 11-24-2005, 09:04 AM
FSB warrior
81Bronk36's Avatar
the newest Bronk Driver, or an old one??
1BadBronco
post #100 of 1133 (permalink) Old 11-24-2005, 09:37 AM Thread Starter
H150's Avatar
Its got to be issue 18
I canít wait to get mine in the mail
H150 is offline
HTML code is On
