Using stock AC unit for air compressor - Ford Bronco Forum
post #1 of 121 (permalink) Old 02-26-2005, 09:05 PM Thread Starter
Raf is my Idol!!
dblue351's Avatar
Bronco Info: One ton 91'
I never used my AC so I turned the stock unit into on board air. Pumps pretty nicely too!
http://wt4x4.net/tech/onboardair.htm
dblue351 is offline
post #2 of 121 (permalink) Old 02-26-2005, 09:24 PM
Bronco Info: 1988 Bronco Custom I6 EFI
That's pretty sweet. How much pressure will it put out? have you checked it yet?
brad
darb is offline
post #3 of 121 (permalink) Old 02-26-2005, 10:53 PM
negative creep
Andy351's Avatar
nice dave, now i don't have to be marks guinea pig
Andy351 is offline
post #4 of 121 (permalink) Old 02-27-2005, 12:10 AM
EvlErn69's Avatar
Bronco Info: 1984 Fullsize bronco...
I want a A/C unit now.. sigh... at least a working heater.. sigh....
84 ford bronco - 302 - c6
4 inch coming soon (andys old setup)
EvlErn69 is offline
post #5 of 121 (permalink) Old 02-27-2005, 03:51 AM
flourman's Avatar
I take it you wired in a switch or do you just turn the AC on with the stock climate controls??
I WHEEL BY BRAILLE
flourman is offline
post #6 of 121 (permalink) Old 02-27-2005, 09:29 AM
sascrotch's Avatar
Bronco Info: '88 XLT, 302/C6
also interested in how much pressure it puts out.
sascrotch is offline
post #7 of 121 (permalink) Old 02-27-2005, 12:41 PM Thread Starter
Raf is my Idol!!
dblue351's Avatar
It is wireded to a switch. I will get the presure numbers ASAP.
dblue351 is offline
post #8 of 121 (permalink) Old 02-27-2005, 04:32 PM
Something Spiffy
Stokes's Avatar
Bronco Info: just another Bko on 1tons
a few of us in the NW chapter have it setup like that (not me yet though) my first impression is that it doesnt pump out that much compared to the york, and be shure to oil it often, tim can tell you more about that.
Edit: duh......you have the oil issue covered.
Stokes is offline
post #9 of 121 (permalink) Old 02-27-2005, 06:40 PM Thread Starter
Raf is my Idol!!
dblue351's Avatar
Ya it is not as fast as a york, but it is way better then nothing!
dblue351 is offline
post #10 of 121 (permalink) Old 02-27-2005, 09:19 PM
I was just talking about this with another board member yesterday
What kind of oil consumption does it have? I saw you added a pre-oiler, but how fast does it use up the oil in it?
reptillikus is offline
post #11 of 121 (permalink) Old 02-28-2005, 12:03 AM Thread Starter
Raf is my Idol!!
dblue351's Avatar
The pre-oiler I got is adjustable. But since I just installed all this yesterday I am not sure the consumption rate. Although I am looking at running a line from the filter after the compressor that catches all the oil before it goes to the tires and make it dump back into the oiler. I have read about thid being done, but have not tackled it yet.
dblue351 is offline
post #12 of 121 (permalink) Old 02-28-2005, 02:05 AM
Bronco Info: 1981 Bronco
I have been wanting to do this and now I really want to do this. Do I have to buy a high temp lubricator/coalescing filter since they will be in the engine compartment? I found one that has a rating for 175 F. Would I have to get one with more temp rating than that? Also you just turn the compressor on by turning your A/C on right?
-Billy
I like dirt
BillyBronco is offline
post #13 of 121 (permalink) Old 02-28-2005, 12:10 PM
Bronco Info: '89 Xlt, '79 Custom
I have an On/Off that i put in the dash to turn mine on and off....hand throttle up to 1700 rpm makes it do pretty well with a 3 gal air tank...
I dont have an oiler, i put a few drops into the intake tube before each use.
Crazedatwork is offline
post #14 of 121 (permalink) Old 02-28-2005, 03:49 PM
broncofied
MANNY's Avatar
Bronco Info: 1984 bronco xlt 302W c-6, 6 inch 35's
Beutiful. Thats is awesome d blue. I've still got the old compressor of my 302 didn't know of such a method of running it. Now i must do that soon!
Dapper Dan
Your in charge of this boat, and we're following you all the way to the bottom!
MANNY is offline
post #15 of 121 (permalink) Old 02-28-2005, 04:15 PM Thread Starter
Raf is my Idol!!
dblue351's Avatar
You will need to run a switch to the dash. The AC control will not turn on and off the AC clutch.
dblue351 is offline
post #16 of 121 (permalink) Old 03-01-2005, 10:19 AM
Well Done Man!
welndmn's Avatar
We find some other ideas i have to stab on your rig.
Numbers coming soon, we are going to test the FS8 (daves compressor) against a york, CO2 tank, Viviar, and my shop compressor.
Mark
71 BKO 42 inch balloons.
http://www.wildhorses4x4.com/
welndmn is offline
post #17 of 121 (permalink) Old 03-01-2005, 02:05 PM
Bronco Info: 1978 Bronco--boxing frame/building 460 and getting ready to hang coils at all 4 corners with dana 60 front+corp14rear
you can tap off of the end of your block with a 45 degree plug after you pull out the filler plug for your oil set up to lube your compressor and then run excess back to a remote cooler or you can just route right back into your fller(I use my egr valve heh heh)--big block set-up in a 1978--works fine---just another easy simple set-up--I route my tube up and across using some hydraulic hose...and I am also looking at a way to double the ratio of air output....nothing yet...
speeed_dmonx is offline
post #18 of 121 (permalink) Old 03-01-2005, 02:59 PM
mkwalt's Avatar
Bronco Info: 1987 XLT Bronco with 31" Pro Comp Mall Terrains, Pro Comp ES 9000's, 4.10's and Ox Lockers
Great write up and what a great way to save a few extra $$$.
NOR*CAL
"If you don't still surf....You never really did." Dewey Weber, Costa Rica.
"I smoke Sensimilla everyday" Jacob Miller
mkwalt is offline
post #19 of 121 (permalink) Old 03-01-2005, 08:17 PM
sascrotch's Avatar
can't wait to see how it does.
post #20 of 121 (permalink) Old 03-01-2005, 09:20 PM
Cody's Avatar
Bronco Info: 1979 Bronco, 400/c6/np205, dana 44/ 9"rear, 3.50 gears, 4" suspension lift with 35"x12.5"x15" tires
we used the one on the scout to set the bead twice this last weekend on the offraoding trip. it works good and the pressure we hit 120 psi cause our popvalve is a 120psi setoff.
he put a tank on the back to have enough air to run airtool and such.
1979 Bronco
1979 Ford F-100
1979 Camaro
2003 ranger
Cody is offline
HTML code is On
