Drug Smuggling 101- AKA Bead Balancing Tires - Ford Bronco Forum
post #1 of 247 (permalink) Old 06-18-2005, 12:07 AM Thread Starter
negative creep
Andy351's Avatar
as most of you know, there are many options available out there to balance tires. there is the traditional stick on weights, high priced equal powder, and even cheap ass solutions like golf balls and BBs. personally, i am a cheap ass and i am tired of ripping off weights on the trail so i decided to try something different. one thing that most people dont take into consideration is that when aired down on high traction surfaces like rock the tires actually spin a little bit on the rim (this is why drag racers use rim screws) so stationary weights like the stick on kind become useless when one or more tires spins on the rim and the weights are no longer in the correct spot to balance everything.
- golf balls were a no for me, since they eventually wear out from all the rubbing inside the tire and then turn into big globs of crap that dont roll and just heat up the tires.
- BBs were a no since i dont like the idea of tiny metal balls that can rust zinging around my expensive tires wearing them out from the inside out.
so after reading a couple threads on pirate, i decided to go with 6mm plastic BBs. these are the ones that those $20 walmart pellet guns shoot aka Airsoft guns. there are several different sizes, but i chose the .12g ones because i could get a box of 10,000 of them for cheap.
now, there is a little bit of math involved here, you will need to find out how much to put in each tire. so going off the chart found here:
http://www.innovativebalancing.com/BigTirechart.htm
i decided on roughly 10 ounces per tire.
some math:
10,000 bbs / 4 tires = 2500 bbs per tire
.12g x 2500 = 300 grams
10 ounces x 28.3 grams (per ounce) = 283 grams per tire
as you can see, it takes roughly 2500 bbs per tire, but it will vary from tire to tire. i put in about 10.7 ounces since my tires run slightly larger than most 37s.
start by dividing the ecstasy pills, i mean bbs into 4 equal quantities
jack the bronco up and start taking off tires
once the tires are off, pull the valve stems...
and pry off the stick on weights (if you have any)
now you will need a trailer hitch and a hi lift, stick the hi lift in the hitch and the foot as close to the bead as possible. make sure the valve stem is 180* away, or you could rip it.
start jacking it, the bead will begin to come off
when the jack begins to get stubborn you can either rotate the tire and jack it in a different spot or jump on it till it unseats fully. (at 170 dripping wet, it doesn't always work for me)
now pop the drugs i mean bbs into the bead area and push them thru.
all you need to do now is take the tire to a gas station or something and pump it full of air to reseat the bead. WD40 around the bead will make it a little easier to go on.
you are now ready to smuggle drugs with nicely balanced tires wherever you please
Andy351 is offline
post #2 of 247 (permalink) Old 06-18-2005, 12:10 AM
Cadillac of Men
SquattyD's Avatar
Bronco Info: 78 Bronco
sweet, doin the same thing monday for my tires...but my pellets are .23 gram each, ill be putting about 1250 pellets per (8 oz ish).
SquattyD is offline
post #3 of 247 (permalink) Old 06-18-2005, 12:24 AM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
I want to do the same thing. Just 128 bolts are holding me back.
Let's Go Fishing.
jopes is offline
post #4 of 247 (permalink) Old 06-18-2005, 12:35 AM
Honeynut Cheerios Urine
JoeBob1901's Avatar
Bronco Info: 95 Bko/C150/C350
kinda funny you're putting in a bunch of "little blue pills"...anyways
are they big enough to come out of the valve stem? otherwise, great idea, and much cheaper than ceramic beads, although not near as dense, but should keep heat down, and wont rust like BB's
Nice work
JoeBobOutfitters.com
SOLD:'95 2DR Bronco 60/10.25
SOLD:'95 4DR C350 PSD
SOLD:'95 4DR C150 351 '05 60/10.5[/URL]
JoeBob1901 is offline
post #5 of 247 (permalink) Old 06-18-2005, 12:37 AM
jackmo's Avatar
Bronco Info: 95 302 32/11.5/15
Holy $hit
Please dont tell me you used wd40 on your tires to seatthe bead The wd40 will brake down the rubber and distroy the bead. Plus it dosen't go away after you set the bead and it will make it a lot easer for the tire to spin in the rim.... (I had a realy bad experance with that and a steep hill )
when you want to lub a bead to set it use dish soap it won't hurt the rubber and when the tire seats it presses it out (its not penitrating like wd40)
jackmo is offline
post #6 of 247 (permalink) Old 06-18-2005, 12:39 AM
MyFullSize's Avatar
Bronco Info: Previously: '89 Bko XLT 351W
Give us a follow up on how it does on the road, city and highway, pls sir.
1993 Jeep Cherokee Sport
* USAR/ARNG 11B RET *
1/116 INF 29ID(L) - (My unit was 1st wave on D-Day)
Read the book "The Bedford Boys"
^^ My animated .GIF is better than yours! ^^
MyFullSize is offline
post #7 of 247 (permalink) Old 06-18-2005, 12:52 AM Thread Starter
negative creep
Andy351's Avatar
Originally Posted by jackmo
Holy $hit
dish soap lingers and when wet (ie snow runs) it doesnt do so well. last i checked, WD40 is petroleum based just like rubber. me and buddies have been using it for a long time with no ill effects.
took it for a quick spin, fine in town. once i get above 60 i get some vibrations, but those were there before. i think i chipped a drum on the con or something
Andy351 is offline
post #8 of 247 (permalink) Old 06-18-2005, 12:54 AM Thread Starter
negative creep
Andy351's Avatar
no
IMO all that matters is the total weight of what you put in there. look at equal, that stuff is about the same grit as sand, and it works great for balancing.
Andy351 is offline
post #9 of 247 (permalink) Old 06-18-2005, 01:41 AM
jackmo's Avatar
I worked in tire shops almost 10 years (good year firestone) always been told not to use petroleum products on tires that it worked like a mild solvent(arn't most solvints petroleum based) and slowly broke down the the rubber on the bead. Plus as any petroleum lubracant it's made to well reduce the friction betwean two surfasas. I had a customers car not stop when she hit the brakes on a hill becuse the other tire guy used bearing greese to lub the bead (i know its not wd40) not trieng to be a smart a$$ and I'm sure the wd40 thing works but i think soap would be a better altunitive..
jackmo is offline
post #10 of 247 (permalink) Old 06-18-2005, 01:53 AM
Engineer
ToddACimer's Avatar
Bronco Info: 95 Eddie Bauer
In my experience, no matter what, a little bit of lube helps the rubber slide in better. But you dont want the rubber to break down that's never a good thing
ToddACimer is online now
post #11 of 247 (permalink) Old 06-18-2005, 02:01 AM
DragonDave's Avatar
Bronco Info: 93 XLT 5.8L
Great tech write up Andy!
"A lifted 4x2 is like a hamburger without the bun!" (bad azz prerunners excluded)
My 1993 XLT Link
DragonDave is offline
post #12 of 247 (permalink) Old 06-18-2005, 02:31 AM
chambiec1's Avatar
Bronco Info: Chevy, dodge... No bronco
Or you can get your favorite flamable substance, spray in the tire, make a line away from the tire, and light it! Don't think the little BB'swould like that, though
Anyways, good writeup.
My Superford
[dougs89] 1:57 am: i was flipping through channels and saw an old man with wood
[chambiec1] 1:57 am: like dick wood?
[dougs89] 1:58 am: no like big piece of wood wood
-Just call me "Casey"
chambiec1 is offline
post #13 of 247 (permalink) Old 06-18-2005, 12:07 PM Thread Starter
negative creep
Andy351's Avatar
i wouldn't try that. IMO thats only a last resort for the trail.
Andy351 is offline
post #14 of 247 (permalink) Old 06-18-2005, 12:12 PM
PowerB's Avatar
Bronco Info: 93 Bronco XLT
Good write up. Did you count out all of those bb's by hand??
93 Bronco XLT 5.0L
31's, Quad Front Shocks, Mostly stock
PowerB is offline
post #15 of 247 (permalink) Old 06-18-2005, 12:21 PM
Big Mike C.'s Avatar
Bronco Info: '79 HD edition Bronco
We used to use WD40 when putting on new grips on our bikes/motorcycles they slide on real nice and then stick real good...never had a problem with those slipping off.
79, 408, T-18, 205, D44, 9", 6" Deavers, 38.5 14.5x15TSL SXs on AE 589s, kustom Krylon paint...more to come
"Nimrod Wildfire"
http://www.supermotors.net/getfile/6.../cropped03.jpg
Big Mike C. is offline
post #16 of 247 (permalink) Old 06-18-2005, 12:27 PM Thread Starter
negative creep
Andy351's Avatar
no i found 4 same sized cups and filled them, just so happened when all 4 cups were equal there was only like 10 bbs left over. thats close enough for me
Andy351 is offline
post #17 of 247 (permalink) Old 06-18-2005, 12:40 PM
Owned 21 Years
Great idea Andy.
But, the drug dogs will still be able to sniff out your stash!
post #18 of 247 (permalink) Old 06-18-2005, 02:42 PM
eljefe's Avatar
Originally Posted by thejuice
Great idea Andy.
not if u put a a good amount of almorol(sp) on ur tires
good write up
"It is better to die on your feet than to live on your knees" Zapata
eljefe is offline
post #19 of 247 (permalink) Old 06-20-2005, 08:51 AM
78Moose's Avatar
did you get any vibration before 60 before you switched to the blue bb's? obviously, they're plastic/rubber; any noises involved?
FTAC '03
1978 Bronco, 400, 205, C6, 38.5" Hawgs
78Moose is offline
post #20 of 247 (permalink) Old 06-20-2005, 09:04 AM
Currently FSB divorced
Slickerthanyou's Avatar
Bronco Info: Had a 1990 XLT 5.8L Parting out to buy a '79 by spring 08
At slow speeds is there any noise? I have those Centramatic balancers and from 0-30ish it sounded like a hula hoop with bbs it in (Swishing noise) Annoying! Expensive too!
Broncoless at this time Yip she left me!!
Originally Posted by Ranger1 View Post
I beat on it, beat on it and beat on it some more and I have the fork tool in there almost until it can't go in anymore.
Is there a trick to this ?
Slickerthanyou is offline
HTML code is On
