Transmission overheating...your thoughts - Ford Bronco Forum
 17Likes
post #1 of 25 (permalink) Old 03-13-2017, 03:27 PM Thread Starter
Erik
'89Bronco302's Avatar
Bronco Info: '89 Bronco,'92 Bronco,'85 F350
So this is the second time out off-roading that my transmission has gotten extremely hot. So hot it boiled the fluid out of the inspection cover and drain tube. It got way hotter this last time though. We believe these 2 times it occurred was due to the transfer case being in 4 hi. 4 low wouldn't stay engaged but that seems to be fixed now. I also bought another transfer case yesterday morning because it was so cheap. So is it reasonable to think running in 4 hi and using more throttle because of that led to my overheating issues? Surprisingly the transmission actually seems fine again despite the burnt fluid but I need to test it in similar conditions. I have 1/2 inch braided stainless lines, an external filter, and a huge cooler with its own fan for the trans. When the transmission boiled fluid 2 days ago the cooler was only warm. I guess it's getting rid of the heat or is my extensive cooling system too much fluid volume for the transmission to handle? I didn't have this cooling setup last time it boiled however. Just some thoughts, I need to test it and see what happens.
'89Bronco302 is offline
post #2 of 25 (permalink) Old 03-13-2017, 04:55 PM
Bronco Info: 1995 Bronco
My first thought is that you are not getting adequate fluid movement. Are you sure the filter is letting fluid move past it?
huck2080 and CDA 455 like this.
“A veteran is someone who, at one point in his life wrote a blank check made payable to ‘The United States of America ‘ for an amount of ‘up to and including his life.’ That is Honor, and there are way too many people in this country who no longer understand it.”
BioTex is offline
post #3 of 25 (permalink) Old 03-13-2017, 06:52 PM
x2 on the fluid, Erick with those big tires and low gears when that thing is in 4wd it's going to produce a lot of heat. At least try re-routing from the filter and see what that does..with that big cooler and fan you shouldn't be having those problems.
CDA 455 likes this.
jermil01 is online now
post #4 of 25 (permalink) Old 03-13-2017, 09:20 PM Thread Starter
Erik
I think the fluid should be moving but how can I really tell? I had this filter setup with the stock transmission lines and cooler before. And the filters and fluid were new shortly before this last trip. I can try bypassing parts of the system but the only 2 times it boiled was after hours of low speed crawling in 4 high so it will be hard to test. Didn't seem to happen the one time in 4 low so that's where my theory began.
CDA 455 likes this.
post #5 of 25 (permalink) Old 03-13-2017, 09:21 PM
Nothing beets a Fullsize
Kingfish999's Avatar
get a tranny temp gauge. im lucky enough that i have a OBD-II reader that displays tranny temps and i watch it like a hawk. i got it up to 240* this weekend so i let it idle for a few minutes till i cooled. at Hardrock it would get really hot since little airflow, think like 280*
did you have an AOD or C6? was it rebuilt at any point? there may be something internally wrong. maybe even stuck valves or clogged passages. if its stock doesn't have a shift kit, you may consider it. the Transgo reprogramming kits are pretty good and do some other mods to help with cooling and durability. almost every time i done a shiftkit in a vehicle, i have found at least 1 broken spring for a valve
CDA 455 likes this.
Kingfish999 is offline
post #6 of 25 (permalink) Old 03-13-2017, 09:30 PM Thread Starter
Erik
Yea, I've been meaning to add a temp gauge. Need to see where I can add one, I have the aod by the way. I've owned the bronco since 2006 on the same transmission. Previous owners provided me with all past service receipts and it was rebuilt somewhere around 5 years before I bought it. Never had issues with it ever slipping and ever since I added the external filter I swear it has shifted firmer. I was actually pricing out transmission work at a local good shop this morning just incase. If I have to I'll have them rebuild it and throw in my manual t case at the same time. I just don't want to spend that coin if not necessary yet. If all goes well I'm trying to do the 460 swap this next winter. I've already started watching the market on 90's 460 4wd fords.
CDA 455 likes this.
post #7 of 25 (permalink) Old 03-14-2017, 09:13 AM
theres a line pressure test port you can add a gauge sensor to
CDA 455 likes this.
post #8 of 25 (permalink) Old 03-14-2017, 09:30 AM Thread Starter
Erik
Ok, thanks I'll look into that. The unknown inside my transmission concerns me. I want to enjoy wheeling the rest of the year with no issues and I plan to save this drivetrain for another build. May wait a week or 2 to test it but I feel like I should tow it to that transmission shop and have them take a close look at everything.
CDA 455 likes this.
post #9 of 25 (permalink) Old 03-16-2017, 11:43 PM
House of Windsor 4ever!
Handy_andy_cv64's Avatar
Just remember this rule of thumb: For each time ATF exceeds 170* F., it cuts the fluid life in half. A filter will not change that. I also think you have something going on in the cooler circuit that's restricting ATF flow, and possibly also not enough air flow when driving at low speed (engine fan clutch) or cooling system hangup (plugged rad, bad t-stat).
'89Bronco302 and CDA 455 like this.
Handy_andy_cv64 is offline
post #10 of 25 (permalink) Old 03-17-2017, 01:59 AM
MidlifeCrisisUndrWay
CDA 455's Avatar
Very informative thread .
μολὼν λαβέ
CDA 455 is offline
post #11 of 25 (permalink) Old 03-17-2017, 02:11 AM
JKossarides's Avatar
Here here!
JKossarides is offline
post #12 of 25 (permalink) Old 03-17-2017, 09:59 AM Thread Starter
Erik
I changed the fluid right after it boiled both times. Guess it doesn't matter if it keeps doing it though. The cooler definitely gets enough air flow but probably not enough fluid flow. Engine has an electric fan that keeps it very cool. It is set on a temp switch but also has manual overrides. There also is an individual fan for both the transmission cooler and power steering cooler. Those are just on a switch and I only use them when wheeling. Cooler never gets hot. With the recent snow I drove around in 4 low flooring it through snow banks. Wasn't as much of an opportunity to heat up as usual but it still got warm and lost a little fluid. As soon as this snow melts I'll pressure wash the mud off and get it ready to tow down to the transmission shop.
post #13 of 25 (permalink) Old 03-17-2017, 06:21 PM
aka: kemicalburns
TravisITGuy's Avatar
are you draining the TC as well or just dropping the pan to change the fluid?
TravisITGuy is online now
post #14 of 25 (permalink) Old 03-17-2017, 09:55 PM
He has a good point--the TC does have a drain plug, and has a specific method to refill the full measure of fluid. But the fact is, there's a reason the fluid's burning and not heating up the fluid. Since it's going down to the trans shop, I won't idly speculate anymore. But I would like to know what the problem is, and I also recommend you have the shop check the cooling circuit from the trans cooler connections at the trans case.
CDA 455 likes this.
post #15 of 25 (permalink) Old 03-18-2017, 12:09 PM Thread Starter
Erik
I drained and refilled the torque converter last time it boiled. Haven't done it this recent time yet because I originally was just going to bring it straight to the shop.
CDA 455 likes this.
post #16 of 25 (permalink) Old 03-18-2017, 10:22 PM
Owned 21 Years
Did you bypass the radiator for cooling the tranny as some tell you to do? Always advised against that. I run a tranny temp gauge and specific puller fan for my E4OD cooler upfront, but still run it through the radiator first.
CDA 455 likes this.
post #17 of 25 (permalink) Old 03-19-2017, 09:15 AM Thread Starter
Erik
My radiator has been bypassed for probably at least 3 years now. That should be insignificant cooling wise I think. With the cooler I have, big lines, and external filter I have way more fluid than before. The cooler I have now is at least 3 times the size of my stock one.
CDA 455 likes this.
post #18 of 25 (permalink) Old 03-19-2017, 04:18 PM
How soon will you be hearing from the trans shop?
post #19 of 25 (permalink) Old 03-19-2017, 06:49 PM Thread Starter
Erik
Been busy with a couple other things but I'm hoping to get it down there Wednesday morning.
post #20 of 25 (permalink) Old 03-30-2017, 11:27 AM Thread Starter
Erik
So I just spoke with the transmission shop for probably the 5th time. Dropped it off last Wednesday morning. First they test drove it and said they didn't notice anything wrong which I told them. I explained all the issues so we agreed to drop it. They have an older guy that is apparently their expert on this transmission. Said the torque converter was trashed and sent metal throughout the transmission. When I talked to them now they said it's almost back together but their waiting on one part that should be in today. It's some type of roller bearing. Apparently from the metal it also ended up trashed. It should be ready by the weekend. The guys said my cooling system for the transmission is the most extensive one they've ever see and should have no problem keeping it cool. I'm just anxious to get it back. Need to do a bunch of work on it myself and I'm ready to really test out that warranty.
HTML code is On
