'94 F350 Taillight Wiring - Ford Bronco Forum
  • 1 Post By locopny
post #1 of 6 (permalink) Old 03-19-2017, 08:37 AM Thread Starter
I did done broke it
InsanePyro's Avatar
Bronco Info: 1993 F150 5.8L 2WD a.k.a RaceTruck
I got a '94 F350 cab chassis and put a normal bed on it. I'm working on the tail lights now. It only has two wires back there since it had rectangular bolt on tail lights. The kind you see on trailers alot. How do I make that work with a regular 3157 tail light socket that has three wires?
Surviving is winning. Everything else is bullshit. Whatever it takes, kid. Survive.
Center your signatures you goddamn Neanderthals
InsanePyro is offline
post #2 of 6 (permalink) Old 03-19-2017, 11:10 AM
They call me "MR FLAT TIRE"
locopny's Avatar
Bronco Info: 90 swapping to7.3IDI, ZF5 & 1 tons. 66 5.0 & AOD
My first thought is that those original light housings included a ground through the mounting bracket where a 3157 in the plastic lens housing had it through the plug.
I would probably just add the ground as finding a wire harness from a pickup box may not be all that easy.
InsanePyro likes this.
locopny is online now
post #3 of 6 (permalink) Old 03-19-2017, 11:31 AM Thread Starter
I did done broke it
InsanePyro's Avatar
Yup thats what it is. I dunno why that didn't occur to me. I had already done that for the reverse light.
post #4 of 6 (permalink) Old 03-19-2017, 02:17 PM Thread Starter
I did done broke it
InsanePyro's Avatar
Anyone know if I can get those bulb retainers anywhere? just noticed two of the sockets I got from the junkyard are missing them
post #5 of 6 (permalink) Old 03-19-2017, 04:12 PM
House of Windsor 4ever!
Handy_andy_cv64's Avatar
Wiring harnesses from any E/F-150/250/350 and Bronco are all the same. I'm sure you could find a truck at the nearest U-Pull-It yard that will have everything ready to be removed. I would take the harness from the ground wire connections all the way back to the cab, and include the license plate lights if the truck is going on the road. If you can't find one, I have 3 Pick 'n' Nose yards and a pair of independent U-Pull-Its within short driving distance of me. If this is the case, PM me and we can hash out details.
Handy_andy_cv64 is offline
post #6 of 6 (permalink) Old 03-20-2017, 01:10 PM Thread Starter
I did done broke it
InsanePyro's Avatar
Thanks for the offer but I just made my own. Once I understood what each wire did on the socket a light bulb went on in my head and I just got to work. I also had plenty of free wire to use. I work at a Chevy dealership and one of the techs I'm buddies with had just done a recall (go figure) that involved replacing a huge wiring harness. I asked him for the old one. Chopped it up and used it for what I needed
HTML code is On
