Ultimate Rock Slider thread - Page 8 - Ford Bronco Forum
 4Likes
post #141 of 150 (permalink) Old 07-31-2014, 12:41 PM
Moabicon's Avatar
Bronco Info: 94 FSB EB, 5.8L, 33" BFG M/Ts
My version of sliders for a 78/79 Bronco.
I built mine using 1.75 dom tubing, 2x3 rectangular, 1.5 square tubing and 3x16 plate. I secured them with 1/2" grade 8 bolts,washers & locking washers. I doubled up the 1.5 square tube for the supports. When it was time for paint I scuffed them up with sandpaper and a brillo pad, cleaned them with a duplicolor prep wipe, primered with rustoleum rust killer primer, painted them with duplicolor truck bedcoating in a spray can and rolled on the coating in the "step" area for traction. Finally for the completion I sprayed 3 coats of duplicolor textured metal flake paint.
Most of these sliders look great but isn't there a company that manufactures these or very similar, that I could buy them instead of make them myself? I probably dont have the skills or a good enough welder to do myself. I want true sliders to use off road and not nerf bars.
Thanks
Moabicon is offline
post #142 of 150 (permalink) Old 08-01-2014, 02:09 PM
Builder10's Avatar
The rock sliders saved getting more body damage on the large rock. The bottom of the rear fender wasn't so lucky when we came off the rock.
SOLD : 1979 Bronco, 460ci swap, 6" lift with 38s, rebuilt Dana 60 front with ARB locker, Chevy 14-bolt rear with ARB locker and disc brakes, TripleSix custom Bumpers, 12k Winch, + MUCH more..
Builder10 is offline
post #143 of 150 (permalink) Old 08-04-2014, 03:32 PM
wileec's Avatar
Bronco Info: 95 302 ZF5 4.56 w/Detroit in the back 33" tires, Sag swap, warn winch and Custom Soft Top
Thanks
You can try http://www.heftyfabworks.com/
His stuff is plenty strong
Always topless
wileec is offline
post #144 of 150 (permalink) Old 08-04-2014, 04:57 PM
Moabicon's Avatar
Yes, I like his rockers. They are priced at $395 (not bad). But you still have to weld them to brackets or to the frame. The optional step shown is no longer available (LOL!)
Thank you
94 EB 351 33" BFG MTs
Moabicon is offline
post #145 of 150 (permalink) Old 01-04-2015, 03:34 PM
Jimmyz's Avatar
Bronco Info: 94 Bronco 5.8L
Originally Posted by Meixter View Post
I like those Gilla!
Very low profile...nice job.
Here's mine...a little different:
I like that design. Nice and clean looking!
92bronco73 likes this.
Jimmyz is offline
post #146 of 150 (permalink) Old 01-04-2015, 03:53 PM
sliders
They are a very cool design.. Nice work.
remember its your ride build it your way not there way.
but build it dont buy it
thin blue line is offline
post #147 of 150 (permalink) Old 01-04-2015, 05:55 PM
I did all for the Nookie
huggyb1972's Avatar
Forgot to post mine. I put them on the Bronco about 3yrs ago. I constructed them out of 2x4x1/4" steel tube they are welded and sealed and could be used as storage tanks (primarily air) I tested them to 140 psi, but never charged them on the Bronco. I incorporated a removable step on each side. I have usex them many times and even jacked the up Bronco with them.
FOTM DEC. 2011
huggyb1972 is offline
post #148 of 150 (permalink) Old 01-04-2015, 06:22 PM
Local # 40 Boilermakers
BRONCONUT's Avatar
Bronco Info: transforming...
I'll play
UNION PRIDE
MY STUPIDMOTORS
BRONCONUT is offline
post #149 of 150 (permalink) Old 02-29-2016, 11:02 PM
raleigh's Avatar
Figure I'll add a couple of the new sliders I made, they have worked well so far!
The main slider is 2x2 .25 wall and the outboard slider is 1.5x1.5 .25 wall.
These things are beef! Really happy with the form and function.
Dave
raleigh is offline
post #150 of 150 (permalink) Old 03-24-2016, 03:06 PM
Beach bumming it ........
Saltlife's Avatar
I'll play... 2x4 tubing with 2" DOM welded to the frame.
I couldnt find a top view after install. This was about the only picture I could find.
kuss, Hillbilly Heaven and tbrooks like this.
Saltlife is online now
HTML code is On
