Odd question about thawed water. - Ford Bronco Forum
post #1 of 24 (permalink) Old 11-04-2008, 04:29 PM Thread Starter
godless's Avatar
Bronco Info: Sold Bronco, but still live in the off topic threads
I cant find the answer online. Probably because I dont know how to ask the question right.
What is the sediment that is present in the bottle after it is thawed?
What I mean is if I take a bottle of water, freeze it, then thaw it before I drink it there are white floaties present in the water that werent there before I froze it. (Or at least they werent visible)
Sounds weird but it happens to every bottle of water I freeze.
Anyone have an answer? It is boggling me.
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring."
Carl Sagan PH.D.
godless is offline
post #2 of 24 (permalink) Old 11-04-2008, 04:32 PM
Sway Is My Fan Club.
Mels's Avatar
Bronco Info: '78 Ranger XLT - 429/C6, 4"s/35s. '88 XLT - 351/C6, 6"s/35s
Air bubbles?
Mels is offline
post #3 of 24 (permalink) Old 11-04-2008, 04:33 PM
crank trigger
Bronco Info: 94 XL M5OD, 5.0, Ghetto K&N, 130A G3
either very small pieces of ice or cocaine.
ScorpionBoy is offline
post #4 of 24 (permalink) Old 11-04-2008, 04:41 PM
XDAILY's Avatar
Bronco Info: 1990 5.0 Eddie Bauer
Wow!
SAS D44,D60,10"lift,42's,4.10's,AOD/E4OD internals,Custom Bumpers,Aussie,Lockrite,Home depot
snorkle,K&N,True Duals,Hedman headers,High Flow Cats,Cherry Bombs. Still going.
XDAILY is offline
post #5 of 24 (permalink) Old 11-04-2008, 04:41 PM Thread Starter
godless's Avatar
nope and nope and nope
Carl Sagan PH.D.
godless is offline
post #6 of 24 (permalink) Old 11-04-2008, 04:45 PM
RESIDENT ASSHOLE
Dirtdigger's Avatar
Bronco Info: ,2003 F-150
Might be calcium.Over time calcium deposits attach to your water mains or pipes and harden.Every time you turn on the tap , some of this calcium breaks loose.Normally you wouldn't see them because before they settle you drink the water or use it in some other way,Make sure your facet has a screen on it,that might eliminate some of that.With that said if you do have a screen ,clean it often.
Dirtdigger is offline
post #7 of 24 (permalink) Old 11-04-2008, 04:52 PM
Shane C.'s Avatar
Bronco Info: 78 Bronco, FI 460/1995 RIP
Originally Posted by Dirtdigger View Post
Might be calcium.
Hmmmm does it happen with just tap water or even with the store bought stuff???? If its tap, is it straight city water or is it filtered at all??
My other car has doors.
Shane C. is offline
post #8 of 24 (permalink) Old 11-04-2008, 04:54 PM Thread Starter
godless's Avatar
Brand new unopened bottle water. No tap water.
Carl Sagan PH.D.
godless is offline
post #9 of 24 (permalink) Old 11-04-2008, 04:54 PM
Engineer
ToddACimer's Avatar
Bronco Info: 95 Eddie Bauer
iron
ToddACimer is offline
post #10 of 24 (permalink) Old 11-04-2008, 04:57 PM
No prepuce on my -
Supersanbob's Avatar
Location: Shepherd, MI. hating rust...loving maple syrup...
Bronco Info: 1990 XLT, 302, DD w/33's, Upgraded 3" exhaust, 6L tune-up,"slight" interior mods, sheet metal gone
iron, calcium carbonate, crystal meth. = one of those...
Supersanbob - Home of the Super Bronco (currently down, getting new body )
Supersanbob is offline
post #11 of 24 (permalink) Old 11-04-2008, 05:03 PM Thread Starter
godless's Avatar
Seriously.
Carl Sagan PH.D.
godless is offline
post #12 of 24 (permalink) Old 11-04-2008, 05:07 PM
RESIDENT ASSHOLE
Dirtdigger's Avatar
Can't answer about store bought stuff,I guess it depends on how they filter it.As far as tap,I have taken many cast iron and plastic mains apart.Depending on how old they are, they can be lined in calcium.Also depends on water source .Well ,river ,lake. Well water normally has the most.Most municipalities treat and filter their water ,but it does little for calcium.
post #13 of 24 (permalink) Old 11-04-2008, 05:12 PM
it's plasticisers...bottled water is bad
carboncrew is offline
post #14 of 24 (permalink) Old 11-04-2008, 05:13 PM
ladies enjoy his
spaustin889's Avatar
Bronco Info: 96, 6'' lift, rebuilt axles, stereo, lots of other stuff
mine does this too in my dorm room, although the water doesnt freeze, my fridge only stores water so i have it set almost freezing....little white chunks
SOLD THE BRONCO, but still sticking around
Supermotors for my Bronco
Originally Posted by Gillamonster View Post
dancing is something i should not compete in
spaustin889 is offline
post #15 of 24 (permalink) Old 11-04-2008, 05:24 PM
my bko ate my money
yoomooman's Avatar
Bronco Info: 92 Eddie Bauer Bronco 5.0, E4OD,MAF Conv, sixltre tune-up, OBA, on 31x10.50x15s
hey im not sure if anyone has herd of this yet but i herd on the news not too long ago that putting plastic in your freezer isnt recommended anymore b/c they have found a chemical in plastics that when frozen then thawed out and digested it can cause cancer, ive started using a metal cantine to freeze water now, not sure how true it is but it was on the news so i took it as a handy peice of info
92 Eddie Bauer bronco 5.0--Travis
Originally Posted by jopes
11:47 pm: hand pack it on the shaft. it's something you should be good at
Originally Posted by yoomooman
some bucks is better than no bucks!
yoomooman is offline
post #16 of 24 (permalink) Old 11-04-2008, 05:25 PM
User that is Registered
Worn Out F150's Avatar
Bronco Info: 92 F150 Custom SCLB 4.9, M5OD, Sag pump, T-bird calipers, half complete 4x4 conversion
I don't see why not, I don't see freezing the bottle expelling the particles from the bottle.
♪They see me trollin, they hatin... Moderatin and tryna catch me postin dirtay♪
Worn Out F150 is offline
post #17 of 24 (permalink) Old 11-04-2008, 05:29 PM
84mudhorse's Avatar
Bronco Info: 1990 mudtruck makeover in progress
its something in your water to be sure.....I bet if you boil that same water off you will find rings of residue in your pot, its prolly a mineral of some kind..all water has some degree of minerals in it exccept truly purified water from a demineralization filtering system like the kind used for water treatment to large steam producing boilers..these water treatment systems have multiple stages of filtering and actually produce non conductive purified water to the extent that it is actually unhealthy to drink because it will absorb minerals from your body
84mudhorse is offline
post #18 of 24 (permalink) Old 11-04-2008, 05:43 PM Thread Starter
godless's Avatar
Thanks. Just curious. I wasnt afraid it was going to kill me or anything but I am just one of those types that has to have an answer for everything.
Carl Sagan PH.D.
godless is offline
post #19 of 24 (permalink) Old 11-04-2008, 06:02 PM
I see Broncos
Froggmann's Avatar
Bronco Info: 93 OJ Special 4" Lift 35s and a bunch of other junk.
From what I understand most bottled water is tap water, well at least 40%.
Depositing random fluids around California, Nevada and Arizona since 1999.
Froggmann is offline
post #20 of 24 (permalink) Old 11-04-2008, 06:07 PM
big, long, hard
p54519's Avatar
Bronco Info: 1995 Eddie bauer 351 W/O Massair 2.5" Skyjacker lift 33X12.50 BFG A/Ts Westin nerf bars Ramsey winc
God put it there. He's trying to get your attention.
1995 Eddie bauer
351 W/O Massair
Originally Posted by ilystbronco View Post
i love my stick its soo much fun
Originally Posted by 96GreenMonster View Post
I Wanna Put a 9" In My Rear
p54519 is offline
