2004 F150/battery died/sercurity key disabled? - Ford Bronco Forum
post #1 of 9 (permalink) Old 11-22-2009, 04:26 PM Thread Starter
sackman9975's Avatar
Guys, maybe someone can point me into the right direction for a friend of mine.
He came home from work this morning, left his lights on. Came out to a totally DEAD @SS Battery. Called me up to give him a jump. Did so. The starter will not turn over for nothing. The security light flashes MAD. He said he's never seen it flash like that. The radio works, lights come on now. After reading the owners manual, I'm believing that the ECU has lost its programming for his key. Does anybody have any input for trying to get this truck started without having it towed to the stealership so they can reprogram his key (if this is the real problem)?
Been searching on the F150 forums, but all I keep getting is battery died then engine clicks. He's got no clicks, nothing. I'll keep searching............
Any help would be appreciated.
sackman9975 is online now
post #2 of 9 (permalink) Old 11-22-2009, 04:45 PM
http://www.f150online.com/forums/200...tration-2.html
Battery or fuses (pass kick panel & underhood)?
Need4racin is offline
post #3 of 9 (permalink) Old 11-22-2009, 05:03 PM
NASSTY's Avatar
Bronco Info: 1992 Bronco XLT 5.8L 4" Dick Cepek stage2 lift 35" Boggers 4.10s True Trac
Has he charged the battery?Test the battery, if it doesn't have over 12 volts the truck won't start.These things take a lot of juice to start.
If the battery in my 06 is completely dead it doesn't like to take a boost either.I always have to put the battery on a charger to revive it.I've had to charge my battery a few times because it wouldn't start with a boost.
I don't drive my truck much and if I let it sit for about 2 weeks the battery dies.I finally had to invest in a battery tender.I know it's not the same as your friends issue but I've read about several others on the F150 forums whose batterys drain if the truck sits too long.
NASSTY is online now
post #4 of 9 (permalink) Old 11-22-2009, 05:19 PM
Camo Horse's Avatar
Scott, you may want to disconnect the battery and then reconnect after 1 minute or reset the ECU trouble codes to allow start. If in protection mode, and the ignition is disabled, then you may or must reset it.
Camo Horse is offline
post #5 of 9 (permalink) Old 11-22-2009, 05:36 PM Thread Starter
Checked. All look good.
Battery is on charger now. Letting it charge for a couple hours to see if it cures the issue.
I'm gonna call him and tell him to disconnect the battery. Will report back with what happens.
Open to all suggestions here.
post #6 of 9 (permalink) Old 11-22-2009, 06:00 PM Thread Starter
Well he tried t agan before disconnecting the battery, nothing. Told him to disconnect the battery for 5 minutes then reconnect and try. That worked. He's a happy little guy.
Thanks guys, appreciate the help. Lunch is on him
post #7 of 9 (permalink) Old 11-22-2009, 06:05 PM
Camo Horse's Avatar
Sounds good. Usually win you run the battery to a certain low point, it can trip the ECU and shut the ignition off thinking in protection mode. So disconnecting usually resets it.
Good to hear it is up and running.
post #8 of 9 (permalink) Old 11-22-2009, 10:08 PM
a renegade of funk
95thebroncoman351's Avatar
Bronco Info: 1995,351,33" meat 4"in roughcountry lift,flowmaster,pioneer sound, yukon axles, new england rust.
theft mode anal raping?
95thebroncoman351 is offline
post #9 of 9 (permalink) Old 11-23-2009, 01:07 AM
House of Windsor 4ever!
Handy_andy_cv64's Avatar
They're also supposed to reset if you turn the ignition on, and leave it on for ten minutes; same as Chebby/Jimmy trucks with Passkey III.
Handy_andy_cv64 is offline
