1998+ F250 Rear Axle - Ford Bronco Forum
post #1 of 11 (permalink) Old 07-22-2010, 02:07 PM Thread Starter
ToughBronco's Avatar
Bronco Info: Sold
I bought that 1990 F250 w/ 7.3 IDI and ZF5, and I noticed it doesn't have the original rear end. It has the newer post-OBS F250 10.25 which is non-free floating by the looks of it (has no huge outer hubs sticking out of the rim). How good are these rear ends? By it being non-free floating I it imagine sucks.
1997 Ford F250 Heavy Duty XLT 4x4
7.3L PSD CCSB, E4OD, D50 TTB, 10.25 FF LS, 3.55's
2001 Ford E350 Super Duty Work Van
5.4L V8
ToughBronco is offline
post #2 of 11 (permalink) Old 07-22-2010, 03:13 PM
Crawdaddy's Avatar
Bronco Info: 82 Ford Bronco 302, stock, electrical horror show
The proper term is semi-floating. The main difference that I know of is that the weight of the vehicle is resting on the axleshaft and that if the shaft breaks, the wheel can come off the truck. I'm not sure of anything else I have in mind.
Crawdaddy
82 Bronco XLT, 302,C6,NP208, MileMarker hubs, otherwise stock
Wanna know every piece that went into the build of the space shuttle? Want the assembly instructions as well? It's likely right here at FSB
Crawdaddy is offline
post #3 of 11 (permalink) Old 07-22-2010, 03:51 PM Thread Starter
Bronco Info: Sold
That's pretty shitty. Free-floating 10.25 swap maybe in the future, if I can find one for the right price.
5.4L V8
post #4 of 11 (permalink) Old 07-22-2010, 06:10 PM
Engineer
ToddACimer's Avatar
Bronco Info: 95 Eddie Bauer
What gear ratio do you need? There have been several on CL north of Milwaukee. Does that have the long or short pinion? Otherwise there is a nice junkyard up here in Oshkosh that would definitely have one
ToddACimer is offline
post #5 of 11 (permalink) Old 07-22-2010, 07:13 PM Thread Starter
Bronco Info: Sold
4.10's would be best. Dont know which pinion it has, how can I tell? Are there any 87-91 F-series up there that would have a good steering shaft in it as well? The bushing on the one in this truck is wore out. I thought it would be a cheap fix but turns out you can only get the whole shaft from Ford for $315...
5.4L V8
post #6 of 11 (permalink) Old 07-22-2010, 08:54 PM
shibby
Dustball's Avatar
So your truck has metric wheels in the back and standard wheels in the front?
Dustball is offline
post #7 of 11 (permalink) Old 07-22-2010, 10:44 PM
It's either a SF 10.25 or a SF LD 97 or 98 f250 axle. You know the f250s, that have the same body as the 97-03 f150s.
and yes a FF 10.25 or 10.5 is better.
A diesel f250 has the HD pkg, which is a full float rear axle from the factory. So the SF isn't stock.
GetBent4x4 is offline
post #8 of 11 (permalink) Old 07-22-2010, 11:56 PM
95F1504x4EB's Avatar
Bronco Info: 1995, F150, MAF 5.0L, 4R70W, BW 1356, 3.31 gears, 31x10.50s, 130A 3G, Saginaw, Eddie Bauer Edition
Weren't those LD F250s 7 lug axles?
I know that like 01-03s could have an option called the "7700 GVWR package", and they had the 7 lugs.
95F1504x4EB is offline
post #9 of 11 (permalink) Old 07-23-2010, 01:54 AM Thread Starter
Bronco Info: Sold
It looks like it has the original wheels in the back. It has a plug where the VSS would go on here and it's connected to the rear end and everything. I thought 1990 was too old to have VSS. It definitely is a 10.25 case though. I'll get some pictures when I get a chance. So Ford did make a SF 10.25 for this year?
EDIT: Seems they did use a SF 10.25, as a "lighter duty" version on these years. Did not know that. Neither did my Ford nut friend. Id still like a FF 10.25 sometime in the future though. I miss those big outer hubs. And knowing that if you break an axle shaft while hauling a load in the bed that the wheel isn't going to fly off is kind of reassuring.
5.4L V8
post #10 of 11 (permalink) Old 07-23-2010, 08:20 AM
shibby
Dustball's Avatar
They sure did. Also the VSS started in '87 I believe.
Dustball is offline
post #11 of 11 (permalink) Old 07-24-2010, 09:27 AM
USAF C-17 Avionics
adrianspeeder's Avatar
Yeah, the lightest GWVR obs F-250s had the semifloat. The 99+ superduty's 10.5 Sterlings are all full float as far as I know, just the hub doesn't stick out as far as the 10.25. I think the light duty '97-'98 F-250's and '99+ F-150 7700's seven lug thinger is a Sterling 9.75 whatnot.
Adrianspeeder
adrianspeeder is offline
