Dual-Action Shifter - Ford Bronco Forum
post #1 of 14 (permalink) Old 02-07-2017, 11:37 AM Thread Starter
treehick's Avatar
Bronco Info: 1988 Bronco Custom, 351, C6, 33" on 15", clean mostly but has only bed floor rot.
Dual-Action Shifter
Can someone explain to me what a dual-action shifter is?
Tried googling it and couldn't find what it was.
I was googling stuff about the C6 and came across a kit to mount to a C6 and couldn't find any information regarding what was different about it.
Forest
DD - for sale: 06 Subaru Forester 2.5X
Wife's: 02 Chrysler Concorde 2.7 Lxi
Project: 88 Ford Bronco Custom - Fullsize 351 C6 on 33/12.50/15
https://goo.gl/photos/yE5yNu5CdTBsop3i9
treehick is offline
post #2 of 14 (permalink) Old 02-07-2017, 01:22 PM
Ford Hoarder
Most likely it is able to be put in D still or shift manually. I know kilduff makes a few like this. So that is how they get the dual action.
custom automatic ratchet shifters
CrazyBRONCOguy is online now
post #3 of 14 (permalink) Old 02-07-2017, 01:38 PM Thread Starter
treehick's Avatar
Wouldn't that hurt the transmission?
Isn't an automatic transmission supposed to be left in Drive and be good?
Forest
treehick is offline
post #4 of 14 (permalink) Old 02-07-2017, 01:40 PM
They can be modified with a manual valve body which requires them to be shifted manually.
Dman94X is offline
post #5 of 14 (permalink) Old 02-07-2017, 01:40 PM
Ford Hoarder
A c6 with the correct valve body will hold up just fine to manually shifting. Mine gets shifted manually more then it does automatically.
post #6 of 14 (permalink) Old 02-07-2017, 01:47 PM Thread Starter
treehick's Avatar
Do you have a dual-action shifter? Or do you simply start in first and shift up?
Can you down shift also?
Forest
treehick is offline
post #7 of 14 (permalink) Old 02-07-2017, 01:50 PM
Ford Hoarder
I have a B&M ratchet shifter in one Bronco and a Art Carr (winters) shifter in the other. Both of these have a Broader performance valve body in them. And yes start in first and shift up. Mine will still work in auto also though.
Yes downshift as you please at any time. The Broader valve body will also hold any gear as long as you tell it to, the stock one will not do that, even when shifted manually.
post #8 of 14 (permalink) Old 02-07-2017, 03:48 PM Thread Starter
treehick's Avatar
Wow - I've heard of people manually shifting an automatic before, but I didn't know that there was a safe way of going about it.
Thank you all for the lesson and clarification!
Forest
treehick is offline
post #9 of 14 (permalink) Old 02-07-2017, 04:18 PM
Ford Hoarder
Its also fun, somewhat of a 4 speed feel. If your off-road a lot the winters setup is better as its really simple and very robust. The B&M is nice but is prone to getting stuff in it, which can make it be hard to work.
post #10 of 14 (permalink) Old 02-07-2017, 06:09 PM Thread Starter
treehick's Avatar
I could see maybe getting it because I prefer manuals - specifically for pulling, hauling, and winter driving.
How much to convert to a dual-action? I have a c6 - which sounds like it's robust, and only 3 gears, so would it even be worth it?
Forest
treehick is offline
post #11 of 14 (permalink) Old 02-07-2017, 09:33 PM
Ford Hoarder
The ones I have shown are.ratchet or consol shifters. A dual action u can pull to the side and shift, or use the button... I have not seen one of those used in offroad application. Cost varies I think around 200 though
post #12 of 14 (permalink) Old 03-06-2017, 12:13 PM Thread Starter
treehick's Avatar
Ford C6 - Broader Performance - how'd you know which one to choose?
and would it be any different than this? TransGo C6: 67-3
Forest
treehick is offline
post #13 of 14 (permalink) Old 03-06-2017, 12:45 PM
Ford Hoarder
Auto Shift Valve Body - Broader Performance
You want that one, I would also suggest calling them and talking to him. He will get you setup. The difference is he sends you the whole valve body and you just swap it. Where as those kits you modify your own valve body.
I like getting the whole valve body as its a faster install and he also goes through and polishes and cleans up the needed surfaces, so they are better then new. I have had both and much prefer the whole valve body over the kits.
post #14 of 14 (permalink) Old 03-13-2017, 07:35 AM Thread Starter
treehick's Avatar
Great to know! Thanks for the recommendation!
Forest
treehick is offline
