The new one from Germany - Ford Bronco Forum
post #1 of 7 (permalink) Old 03-05-2017, 02:38 PM Thread Starter
Hi @all
I'm Pascal from Germany and on my way to get a Bronco :)
I would like to use it in the woods and for a cruise at the weekend!
In Germany are not so many Broncos on the street and it is hard to get a car which is in a good chape. But i won't give up
uprising is offline
post #2 of 7 (permalink) Old 03-05-2017, 03:47 PM
Yo Pascal,
Welcome!
For any Broncos questions, it is better to ask each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view).
Look @ Common Replies to FAQs that includes information such as;
How to use search (Advanced)
How to POST PICTURES
Baba Looey's Favorite FSB Links (lots and lots of tech links)
Ask for maintenance records. If no maint records are avail; check and replace if needed all filters and fluids.
Order a CarFax. Although not all accident info is provided other important info is providee @ https://www.carfax.com
While you take a test drive, have someone stay behind or follow and check for leak puddles, exhaust smoke, tire shimmy, etc.
dash_cam offers very good advice on having an independent inspection done at sellers location! If you cant inspect it yourself, post Location in the noobie section and ask members for their help or seek out an ASE certified shop in area to inspect it for you.
Besides the usual visual, driveability and leak checks, look for:
- oil pan rust - our's formed spots @ 62k miles - sand it down and prime/paint it w/Rust Bullet Automotive) & high temp. paint - too time-consuming replacement for such a basic thing as not having better gauge and paint by Ford
- radiator plastic side seam leaks, esp. during engine cool-down period/overnight - our's leaked @ 50k miles & again just recently - look for leaks after engine has cooled down, esp overnight
- auto tranny - E4OD in 90 to 96 had a lot of improvements made by 96 so look for good shifts and see the maintenance records; fluids/filter should have been changed every 30k miles and less if used for towing - look for leaks around pan from (front) Pump seal. Observe color and odor of the fluid. It should be red, not brown or black. Odor may indicate overheating condition, clutch disc or band failure. Use an absorbent white facial tissue and wipe the fluid level indicator. Examine the stain for evidence of solid particles and for engine coolant signs (gum or varnish on fluid level indicator).
If particles are present in the fluid or there is evidence of engine coolant or water, the transmission pan must be removed for further inspection.
- engine rear main/timing chain cover seals, etc.
- rust in inner rear fender lips, bottom of B pillars and bottom of tailgate (fender lips are rusting due to Ford's flawed spot weld process on the inner (tub) and 1/4 panel that lets moisture & debris in the seam) - A Bronco may need extensive & $$$ patch or full panel replacements at a body shop, but some diy.
check tg drains for clogs/rust..check weather seals, esp the outer ws on glass
- radius arm bushing deterioration (I coated em w/pure silicone, from day 1) but replaced at 80k miles w/Daystar polyurethane bushings
- Programmable Speedometer Odometer Module (PSOM in 92-96), make sure it works; look for a slight waver in the needle at highway speeds.
- cracked exhaust manifold/Y, etc.
- roof/gutter area cracks (mostly appl. to earlier years)
- emissions air check valve & cat. converter (AIR) tubes tend to rust early; as does the AIR tube; buy locally or from pciinc.com
- radiator core supports, lower, it rusts mainly on passenger side, PIA to replace
- body mount deterioration and frame rust
-transfer case operation - electric push button motor/connector is a prob. area; usually a broken travel stop and/or the motor connector is fouled, etc.
Also the Check Engine Light (CEL) comes on when the electronic engine control system is not working properly. The check engine warning indicator comes on briefly when the ignition switch lock cylinder is turned to ON, and should turn off when the engine starts. If the check engine warning indicator does not come on when the ignition switch lock cylinder is turned to ON or if it comes on while the vehicle is moving, the system is malfunctioning
If the CEL does not light up at all when starting it; then suspect that bulb is burnt-out or loose, socket was damaged by PO or shop, etc. or someone removed it.
Is CEL ON when starting or while driving?
Same for:
E4OD Transmission Control Indicator Light (TCIL) , it is a LED and overdrive on/off switch at end of the Transmission shifter stalk; flashing OD light is an indication of a transmission related trouble code in the Powertrain Control Module (PCM).
Is it flashing while driving?
For pre 96 with EFI do a SELF TEST for diagnostic trouble codes (DTC)s by my pal BroncoJoe
For a 96 get it checked for codes free at Parts Stores if you don't diy with a scanner.
The anti-lock brake electronic control module monitors the electromechanical components of the system. Malfunction of the anti-lock brake system will cause the Anti-lock brake electronic control module to shut off or inhibit the system. However, normal power assisted braking remains. Malfunctions are indicated by the amber ABS warning light inside the vehicle.
The 4-wheel anti-lock brake system (93-96) is self monitoring. When the key is placed in the RUN position, the anti-lock brake electronic control module will perform a preliminary self check on the anti-lock electrical system indicated by a momentary illumination of the amber ABS warning light in the instrument cluster. During vehicle operation, including normal and anti-lock braking, the anti-lock brake electronic control module monitors all electrical anti-lock functions and some hydraulic operations. In most malfunctions of the anti-lock brake system, the amber ABS warning light will be illuminated. However, most malfunctions are recorded as a coded number in the anti-lock brake electronic control module memory and assist in pinpointing the component needing service. If system is OK, Code 16 will be present.
Our module blew the microprocessors a few years ago and two yard modules were bad. No returns so I'm running without 4WABS, just like the old days.
miesk5 NOTE: "1987 was the year the rear anti-lock brakes (RABS) were standardized on Broncos; "...Rear-wheel ABS is another type of ABS available on some light trucks. It works in a similar fashion to four-wheel ABS, but monitors and operates only the rear wheels, especially important with light trucks, which often carry heavy loads supported primarily by the rear suspension and wheels..."
Suggest you buy the official FORD Powertrain Controls and Emission Diagnosis (PCED), Electrical and Vacuum Troubleshooting Manual (EVTM) on DVD.. be sure your pc, etc will be able to read the DVD, or buy a paper version.
Cash is King.
As craigslist advises, "Avoid scams, deal locally Beware wiring (e.g. Western Union), cashier checks, money orders, shipping"
A summary of questions to ask the seller;
"* Do you have all the maintenance records?
* Do you have a clean title in hand and is there a lien on the Bronco?
* How do I get the title?
* Has the vehicle been in any accidents?
* How much tread is left on the tires?
* Are there any scratches or dents on the vehicle?
* Did this car belong to a smoker?
* Was this car used by pet owners?
* Can I receive close-up pictures of a specific area (miesk5 note, such as on 1/4 panels, tailgate, etc)?
* Are there any document or preparation fees?"
Courtesy of ebay
Great luck & Enjoy our site!
Please VOTE FSB for Top4x4 site once daily[/B] @ Top4x4Sites.com - Listing some of the top 4x4 and Off Road sites on the web!
post #3 of 7 (permalink) Old 03-05-2017, 05:42 PM
Mountain dewd's Avatar
Welcome and good luck!
Do NOT tread on me.
Mountain dewd is offline
post #4 of 7 (permalink) Old 03-05-2017, 06:20 PM
remco's Avatar
Bronco Info: FSB 1991 XLT.......351W
Welcome!
Im from Slovakia and bought Bronco 8 years ago in Germany:)
Some nice are on mobile.de / autoscout24.eu but the prices are now little higher. I bought it for 3800 eur.
Good luck with purchase and then with TUV :)
One of the few bronco owner in Europe
https://s6.postimg.org/6ovncsvhd/zzzx.jpg
remco is offline
post #5 of 7 (permalink) Old 03-09-2017, 09:49 PM
Pascal, its funny that you from Germany and getting a Bronco, I live in the states and here is my other 4x4
Russ K
RussK is offline
post #6 of 7 (permalink) Old 03-09-2017, 09:56 PM
nra1ifer's Avatar
Bronco Info: 1981 w/302
Welcome, Pascal!
Good luck with your Bronco search.....
nra1ifer
MADE America Great Again!!!!
nra1ifer is offline
post #7 of 7 (permalink) Old 03-11-2017, 10:00 AM
My Little Mule's Avatar
Bronco Info: 1979 Bronco 351m
Welcome!,
Good luck with your search! You will find a good one, and PLEASE post some pictures of her when you find her. Or post some pictures and as some questions on this forum. Lots of great people on here willing to help.
79 Bronco
71 Torino
67 Charger
My Little Mule is offline
