'79 351M Timing Pointer ?????? - Ford Bronco Forum
post #1 of 4 (permalink) Old 10-13-2007, 11:00 PM Thread Starter
Bronco Info: 1974 Bronco, 302, 3spd., 33's, 3.5" lift, 1979 Bronco that needs a new home....
Hey folks,
Maybe a stupid question here, but where is the timing pointer on the 351M suppose to be located? I just bought a '79 Bronco and I cannot find the timing pointer anywhere. Thanks in advance for the help!!!
James
JCoggin is offline
post #2 of 4 (permalink) Old 10-14-2007, 12:27 AM
Ziggy's Avatar
Bronco Info: 79 Bronco
Passanger side of the engine, down low. It is hard to see unless you know where to look.
Ziggy is offline
post #3 of 4 (permalink) Old 10-14-2007, 12:59 PM Thread Starter
Ziggy,
My engine is apart and I did not notice it having a pointer. Is it made on to the timing chain cover or does it bolt on?
Thanks,
James
JCoggin is offline
post #4 of 4 (permalink) Old 10-15-2007, 01:41 AM
Ziggy's Avatar
I believe it is attached to the timing chain cover, it's been a while so I can't remember. But, I pretty sure that it is not a seperate piece like a Chevy engine.
Ziggy is offline
