Possible to fit ATV in back? - Ford Bronco Forum
post #1 of 41 (permalink) Old 07-13-2009, 09:10 PM Thread Starter
Bronco Info: 1984 F150 4WD, 351W, C6, 9" rear AussieLocker, Deaver Coils, 35" MT/R's
Hey, I currently have a F150, but really have always loved broncos and everything about them... and if/when I blow this truck up that might be my next buy. I was just wondering if anyone has ever done or seen an ATV fit in the back of one with the cap off and I guess rear seat removed. I go riding a lot and being able to haul my quad without having to drag behind a trailer would be awesome. If I got one I'd probably just soft-top it anyway, and takin the rear seat out for good or on occasion wouldn't really matter. Just for size reference I have a 400ex. I know i've seen someone with a dirtbike in the back of one, but never seen a quad.
fmf300ex is offline
post #2 of 41 (permalink) Old 07-13-2009, 09:14 PM
F.O.T.M. - MAY 2014!!!
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs Daystar leveling kit
I doubt a 400ex can fit. I can barely squeeze in my boys 110, but thats with the rear seat folded down and the top on.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options. 4.10 gears LSD 33" MTs First ever Stock Fullsize of the Month...
J A S N http://www.supermotors.net/registry/19528
fartman is offline
post #3 of 41 (permalink) Old 07-13-2009, 09:30 PM
Im scared of jopes
78'460's Avatar
Bronco Info: 78' 4spd 460 38's
I seen a fricken sea doo in the back of a bronco, You can get a quad in lol.
78'460 is offline
post #4 of 41 (permalink) Old 07-13-2009, 09:34 PM
Owned 20 Years
How would you plan on getting it up in there? I have a soft top and would not be able to ride a quad up in. Nor would my tailgate hold the weight. between the wheelwells is 4' and you've got about 6' to work with, so I can see one fitting easy enough, it's just getting it in there, especially with any lift.
post #5 of 41 (permalink) Old 07-13-2009, 09:38 PM Thread Starter
Well I have a couple of wood ramps and I just ride it into the back of my truck no problem... but then again thats an 8foot bed. And I guess the wheel wells on the bronco would be closer in than my truck, so that would be a pain to probably work around.
fmf300ex is offline
post #6 of 41 (permalink) Old 07-13-2009, 09:42 PM
I used to have a 91 Bronco with no lift. I used to fit a 300EX in the back with the stock cap still in place. I had to remove the rear seat, handlebars and deflate the front tires. It was kind of a pain, but it worked.
96DailyDriver is offline
post #7 of 41 (permalink) Old 07-13-2009, 09:53 PM Thread Starter
Fit inbetween the wheel wells or have to pick it up overtop of them? If a 300 fit like that with the cap, then the 400 should be alright with the cap removed.
fmf300ex is offline
post #8 of 41 (permalink) Old 07-13-2009, 10:22 PM
Owned 20 Years
wheelwells would be the same....fullsize truck allows a sheet of plywood or drywall to lay flat between the wheelwell (need a good 48").
tailgate is said to only hold about 300lbs safely. You could probably beef the cables and have it hold closer to 500lbs, who knows. You'd need the top off though to ride it up in there.
post #9 of 41 (permalink) Old 07-13-2009, 10:24 PM
tmwalmart's Avatar
Bronco Info: '91 EB, 393W w/MAF conversion, 6" Susp. Lift, 35X12.50s, Rblt E4OD Tranny, Rblt BW1356 TC
I used to fit my old Blaster in the back. Hard top off and the rear seat folded forward.
tmwalmart is offline
post #10 of 41 (permalink) Old 07-13-2009, 11:06 PM
cemusic86's Avatar
Bronco Info: 1995 XL ,302 V-8, 99% stock, Mile Marker manual hubs
why don't you measure it?...sorry I know ..asshole/.but seems to be the simple solution...
Back off man...I'm a scientist...
cemusic86 is offline
post #11 of 41 (permalink) Old 07-14-2009, 06:59 AM
I believe I had to pick the rear up to get it over the wheelwells.
post #12 of 41 (permalink) Old 07-14-2009, 12:11 PM
Bronco Info: 1989 Ford Bronco Custom
Theres another pic floating around here with a atv in the back of a bronco. I tried looking for it but cant find again.
jasonparson is offline
post #13 of 41 (permalink) Old 07-14-2009, 12:20 PM
I see Broncos
Froggmann's Avatar
Bronco Info: 93 OJ Special 4" Lift 35s and a bunch of other junk.
As others have said, you should be able to but you'll have to work for it. In my case it was a Honduh 250EX and to make it fit we just had to loosen and roll the handlebars down and flatten the tires. Of course this was with the back seat removed but I was able to even close the tailgate and have the back window up.
Depositing random fluids around California, Nevada and Arizona since 1999.
Froggmann is offline
post #14 of 41 (permalink) Old 07-14-2009, 12:55 PM
Not Frilly.
86' MUDSLAYER's Avatar
Bronco Info: 1986, 4inch lift on 35s, 302C.I. E.F.I., KC Daylighters Up Top, Pilot Fogs Down in Front
my blaster fits in mine on knobs, just fold down the handlebars, set the front on the tailgate pick up the rear and shove her in. idk if a 400 would fit though, i havent tried to put mine in there, daddys got a longbed
Originally Posted by RickyB View Post
Well done. Like they say, every cloud has a silk purse in the bush.
Or something...........
86' MUDSLAYER is offline
post #15 of 41 (permalink) Old 07-15-2009, 07:13 PM
Newbie Ronco's Avatar
Bronco Info: 86 Bronco 351W HO 670 truck avenger 35's 4.10's front LS rear Locked
my honda 350 4x4 will fit after i pull out the rear seat... wheel wells not in the way, i can almost close the tailgate... so i use a strap to hold the tailgate almost closed ...have crappy pic if nessesary
Newbie Ronco is offline
post #16 of 41 (permalink) Old 07-15-2009, 10:33 PM Thread Starter
Thanks everyone, I get the picture. Was mainly just curious for if/when I step into the Bronco world... For now I'm just thankful to have an 8foot bed haha. Even with a rollbar in the back can manage to fit two 400's with one stood up and the tailgate dropped (and a handful of ratchet straps). Thanks for the input everyone, definitely appreciate it.
fmf300ex is offline
post #17 of 41 (permalink) Old 07-15-2009, 10:46 PM
Bronco Info: 93 Bronco 5.8 6" lift 33" tires
you can make anything fit anywhere.....
as for getting it in there....was a time when I could put a riding lawn mower or ATV up in the back of a truck lifting the front end up on the tailgate then lifting and pushing from the back....
If I tried that now my nuts would fall off......
CrazyElvis is offline
post #18 of 41 (permalink) Old 07-24-2009, 07:49 PM
illinidorry's Avatar
Bronco Info: 93 F-150 4x4
i would prob fit w the seat removed if a dirtbike can fit then a quad could bikes are longer....look at the pic with the blaster and add a good 6-8 inches in length with the 400 though. Are the wheelwells that much narrower on the bronco then the F150? I used to get my 450R in the back of my Quad Cab Dakota between the wheelwells no problem but the tires stuck out about 6 inches onto the tailgate.
93 F-150 5.0 reg cab, swb, 4wd
08 135i - full bolt on
03 GTI VR6 6spd sold
96 Formula-WS6, 1LE, M6, 1 of 10 sold
illinidorry is offline
post #19 of 41 (permalink) Old 02-10-2010, 11:17 PM
i know this is an old post but i Have a 96 Bronco and i am getting a raptor 700 would it fit with door closed and rear seat out completely? I measured it but im not sure.
coolarr0w is offline
post #20 of 41 (permalink) Old 02-11-2010, 01:35 AM
JoeBronc's Avatar
Bronco Info: 1990, 351w, E4OD, 33's and a little custom work
well whats the width on your raptor from outside tire to outside tire and from the front to back in the longest part?
Edit: raptor 700 specs. L x W x H 72.6 x 46.1 x 44.5 in (pulled from Here)
ill go measure the back of my bronco for ya... nothing better to do
JoeBronc is offline
