Engine ID Code: Is it a 302 or 351W? - Ford Bronco Forum
post #1 of 17 (permalink) Old 03-17-2010, 12:54 PM Thread Starter
Runnin'OnEmpty's Avatar
Question Engine ID Code: Is it a 302 or 351W?
The eighth character in the VIN number is "H".
Does the H signify a 351W? If so, what's the letter
for a 302? I searched and couldn't find the answer anywhere.
Thanks,
ROE
1978 Bronco Ranger XLT, Trailer Special with FreeWheeling Package, 351M, NP435, Ford alloys w/BFG 31's, MAC/IMCO hybrid exhaust.
Runnin'OnEmpty is offline
post #2 of 17 (permalink) Old 03-17-2010, 02:53 PM
brd
Bronco Info: 83 FSB/302 33x12.5x15/ AAL and front coils,c-6,np 208. 8.8,Sag pump,3G alt,eletric fan,91 roller fro
brd is offline
post #3 of 17 (permalink) Old 03-17-2010, 03:21 PM
JoeBronc's Avatar
Bronco Info: 1990, 351w, E4OD, 33's and a little custom work
H should be a 351W motor... "Should be" what is the year of the truck and the intake plentum should also say 5.0 or 5.8 unless the motor has been replaced or upgraded...
"o really so u have a nice body???""haha. i consider myself athletic. yea im pretty smart""haha reall do u consider ur self hot????"uh depends on the day,my wife thinks i look good tho" "omg y didnt u tell me u was married lol""you never asked"
JoeBronc is offline
post #4 of 17 (permalink) Old 03-17-2010, 06:00 PM
brd
F is 302
brd is offline
post #5 of 17 (permalink) Old 03-17-2010, 07:08 PM
sackman9975's Avatar
Originally Posted by brd View Post
F is 302
Really?
Doubt it, my 302 equipt truck was an "N".
sackman9975 is offline
post #6 of 17 (permalink) Old 03-17-2010, 07:17 PM
FSB's Dirty Jersian
Smok3y's Avatar
Bronco Info: 89 EB, 91 Silver Anniv, 91 F250, 79 F250
**EDITED**
Totally missunderstood the question. I dunno how but I did.
89 Eddie Bauer - 6" RC Lift, 35" KO's, 302/c6 swap, Ford 9"
79 F250 Ranger Lariat - 9" Lift, 40" Ground Hawgs, 400/435/205, D60/D70 LOCKED
Originally Posted by SigEpBlue
All I want people to do is STOP, THINK, and SEARCH. Only post if those three fail after thoroughly repeating.
Smok3y is offline
post #7 of 17 (permalink) Old 03-17-2010, 08:34 PM
lifeizhard102205's Avatar
H is a 351, N is a 302. if in doubt google "VIN decoder" and plug the vin in, it'll tell you the year, make, model, engine size and i believe weight rating for the vehicle (dont quote me on the last, but i'm 100% positive about the others).
lifeizhard102205 is offline
post #8 of 17 (permalink) Old 03-17-2010, 09:51 PM
Depends, in a '69 Mustang an "F" for the fifth digit in the VIN did indeed signify a 302.
tim
TS 90F150 is offline
post #9 of 17 (permalink) Old 03-17-2010, 10:39 PM Thread Starter
Thumbs up Thanks
My thanks to all for the replies and links.
I should have said 5.0L instead of 302, since that's the Ford
nomenclature for the later models and my saying 302 was confusing.
I'm in the market for a later model Bronco, 90-96, and needed to
identify the engine size by looking at the VIN.
As was stated, H equals 351W, and N is the 5.0.
Thanks again.
post #10 of 17 (permalink) Old 03-17-2010, 11:46 PM
brd
Originally Posted by sackman9975 View Post
Really?
Not saying that an N is not a 302 ,only that an F is.Least so says the Ford fleet vin decoder
https://www.fleet.ford.com/maintenan...ls/default.asp
I ran mine its a F 302
brd is offline
post #11 of 17 (permalink) Old 03-17-2010, 11:49 PM
We're talking 8th in the VIN, not the 2nd.
post #12 of 17 (permalink) Old 03-18-2010, 12:05 AM
brd
So am i......
Unless there is something odd about my truck,and im not ruling that out.....
I entered my vin into the Ford decoder and got a 302 off the f in the 8th position of my VIN....and yes my 2nd is also F
Heres a copy of the ford vin decoder up to and including the 8th position.
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FM
Assembly Country: UNITED STATES
Make: Ford
Body Style: Sport Utility Vehicle
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: E
GVWR Range: 6,001 - 10,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: U15
Vehicle Line: Bronco
Series: U100
Vehicle Type: Truck
Engine Type - 8th Position
VIN Code: F
Engine: 5.0 L
Cylinders: 8
Fuel: Gasoline
brd is offline
post #13 of 17 (permalink) Old 03-23-2010, 12:20 PM
could have changed depending on the year groups. i was looking for 87-96 broncos when i found mine. on ads where the engine size wasn't listed i looked up the vin, found h for 351 and n for 302. never let me down that way. if yours is different could be your truck is weird or ford just could have used a few different letters at different times.
post #14 of 17 (permalink) Old 03-23-2010, 12:21 PM
tim
last i checked this is a bronco forum, not a mustang forum. so answers given here should go without saying that they will be bronco specific or ford truck specific....not 69 mustang specific.
post #15 of 17 (permalink) Old 03-23-2010, 05:11 PM
JoeBronc's Avatar
tim
im also going to assume the 69 did not have a 17 char vin but instead something like an 8 or 13 number (not sure of the number but under 17) vin correct?
JoeBronc is offline
post #16 of 17 (permalink) Old 03-24-2010, 12:26 AM
Damn dudes ligthen up just a little will you?
post #17 of 17 (permalink) Old 03-28-2010, 09:56 PM
found these vin codes in the lmc truck catalog
1981-1986
3-6cyl 230 cid 3.8L 2bbl carb 82-83
E-6cyl 300 cid 4.9L 1bbl carb 81-82
Y-6cyl 300 cid 4.9L 1bbl carb 83-86
D-V8 255 cid 4.2L 2bbl carb 81-82
F-V8 302 cid 5.0L 2bbl carb 81-85
N-V8 302 cid 5.0L EFI 85-86
W-V8 351M cid 5.8L 2bbl carb 81
G-V8 351W cid 5.8L 2bbl carb 81-85
H-V8 351W cid 5.8L 4bbl carb 84-86
Z-V8 400 cid 6.6L 2bbl carb 81-82
1-V8 420 cid 6.9L diesel 83-86
L-V8 460 cid 7.5L 4bbl carb 83-86
1987-1996
Y-6 cyl 4.9L EFI 87-93
Y-6 cyl 4.9L MFI 94-96
N-V8 5.0L EFI 87-93
N-V8 5.0L MFI 94-96
H-V8 5.8L 4bbl carb 87
H-V8 5.8L EFI 88-93
R-V8 5.8L (F-150 lightning) EFI 93
H-5.8L MFI 94-96
R-V8 5.8L (F-150 lightning) MFI 94-96
1-V8 6.9L Diesel 1987
M-V8 7.3L Diesel 88-94
F-V8 7.3L Turbo Diesel 94-96
K-V8 7.3L Turbo Diesel 94
L-V8 7.5L 4bbl carb 87
G-V8 7.5L EFI 88-93
G-V8 7.5L MFI 94-96
this is right out of the catalog which has all the break downs of the vin's for 81-96 f series and broncos. if you want to know more...order the catalog. it's free and takes 6-8 weeks for delivery.
