LIFT AND TIRE INFORMATION FOR 80-96 BRONCOS - Page 31 - Ford Bronco Forum
 21Likes
post #601 of 632 (permalink) Old 02-07-2016, 03:19 AM
TOPPNOTCH's Avatar
After a lift how do i get 1 to 2 more inches added up front?
Sent from my SM-N920V using Tapatalk
TOPPNOTCH is offline
post #602 of 632 (permalink) Old 02-16-2016, 09:11 PM
S00TLYFE's Avatar
Bronco Info: 1989 XLT 5.8 C6 C&T Coilovers Bypasses 35s Methods PRPs
Buy super lifts with radius arms, save for deavers or scour forums for a used pair. Got my deavers for $350 lightly used. Lifted my whole bronco for $1050 and the rear is done while I save to long travel and convert the steering to crossover
1989/5.8/C6/MAF/C&T Beams/Coilovers/Bypasses/F53s/Corbeau Buckets/110W Race Radio/Bassani Headers/Y-Pipe/Black Widow Venom 250/Methods/35" Red Letters
S00TLYFE is offline
post #603 of 632 (permalink) Old 03-07-2016, 03:55 PM
DrDuktayp's Avatar
Bronco Info: 4" Lift - 35x13.50 Toyo M/T's - 4.88 gears - Lockers Front & Back - Big Six 300 - Clifford Intake
Originally Posted by fdchief View Post
I am interested in the superunner steering kit but it says it can not be used with Rancho or Skyjacker.. Does anyone know by looking at these pics which lift this is? Thanks...
[IMG][/IMG]
Probably too late but that looks like my Rancho lift. The Super Runner steering needs the lift part to go straight down instead of at an angle. My son was able to modify the Super Runner for the Rancho lift on mine but he's a welder by trade. There is no way I could have made it work. Also, if you do the Super Runner make sure you get the Super Lift drop pitman. The Rancho pitman is a slightly different length and will chew up the front tires.
Fast Floyd likes this.
DrDuktayp is offline
post #604 of 632 (permalink) Old 03-20-2016, 10:30 PM
Will getting a longer driveshaft reduce the angle because my angle is really steep and i dont want to ruin a good driveshaft
Hunterd127 is offline
post #605 of 632 (permalink) Old 03-21-2016, 12:26 AM
Elliott000's Avatar
You would have to push the rear axle back to reduce driveline angle. How much lift u got? Front or rear shaft
Elliott000 is offline
post #606 of 632 (permalink) Old 04-26-2016, 08:10 AM
Post need more info on 6 inch lift for my bronco
im wanting to put a 6 inch lift on my ford bronco will i have to extend my drive shaft and i know i will have to extend brake lines im wanting to put the 6 inch rough country lift and can all pls help what things i will have to extend and how long do you think it will take me to do it
nandosbronco is offline
post #607 of 632 (permalink) Old 04-26-2016, 10:36 AM
Yup get a new driveshaft. Shocks will also need to be longer. Depending on your skills and available tools it can be accomplished in a weekend.
BigBlue 94 is offline
post #608 of 632 (permalink) Old 04-26-2016, 10:59 AM
Beach bumming it ........
Saltlife's Avatar
You DO NOT need to extend your drive shaft. Only things that will need to be extended besides the normal lift parts will be your brake lines.
Saltlife is offline
post #609 of 632 (permalink) Old 05-15-2016, 09:28 AM
Bronco Info: 1995 Bronco Eddie Bauer
Just did the RC 6 inch lift and all I needed extra was th extended break lines. Took me about 8 hours and you definitely need a second set of hands.
Emrldlx is offline
post #610 of 632 (permalink) Old 06-20-2016, 04:57 PM
Bronco Info: '93 Bronco XLT 5.8ltr
Thank you for this thread, WES, and thanks to all who contributed. I just read the whole damn thing and I no longer have one single question about lift systems and tires. Well done.
NCJake is offline
post #611 of 632 (permalink) Old 06-20-2016, 11:40 PM
Harley's & Bronco's FTW!
well... WES is long gone but members who can search and learn are always appreciated around here.
BikerPepe` is online now
post #612 of 632 (permalink) Old 07-07-2016, 10:25 PM
Wheel/ Tire question WRT 4" BDS lift, with 4.11 and E4OD (see signature line for more detail) and yes I searched.
Current setup: 33x12.5x15 on steel UNIQUE wheels 15x10.
Option 1 setup: 17" Level 8 Trackers rims with 295x70x17R (gives it a 33.3" diameter), tire/wheel weight the same at current setup/ tire.
Option 2 setup: 17" Level 8 Tracker rims with 285x75x17R (gives it a 33.8" diameter), tire/ wheel weight about 10 lbs heavier than current setup/ tire.
the reason for this is the 12.5 BFG width on the pavement is giving outside wear despite every 6K rotations. I had the tires reversed from blackwall to whitewall to even things out. Plus the tire stick out a bit more causing more "bow" in steering linkage.
By running either option 1 or 2, the more narrow tire will pulll the wheels/ tires back closer to stock position and increase MPG, and turn radius.
Am I missing anything with this analysis. Of course if I go with Option 2, I will need to re-calibrate PSOM and make sure the near 34" works find with travel and backspace to the radius arm. Also, it does put a bit more strain on engine and gearing. Option 1 would be nearly no change, minus less rubber on the road.
Thoughts? This change is a look ahead to less maintenance, wear/ tear and hopefully better looks and performance.
Thanks for the input.
jw
1995 XLT 5.0L, mileage 200K+, floor shift, D-44, Ford 8.8" (4.11) LSD, E4OD, BW 1356-->Mods: BDS 4"-ext. rad arms, 33x12.5 BFG, 15x10 rims, PSOM adjust, FIPK (57-2543), Hayden Trans Cooler (679), Warn manuals (20990,32720), remote tran filter (perma-cool 10677)
julietwhiskey is offline
post #613 of 632 (permalink) Old 08-19-2016, 11:27 AM
I just finished a SAS and I am trying to figure out how much lift I got out of the front before I order rear springs. Does anybody have measurements to the top of the fender wheel arch before and after a lift with 31" tires. I started at 35" and ended up at 39.5" so I know I netted 4.5 up, but I'm not sure if the truck had a leveling kit on it before I bought it or if the rear springs are just sagged.
Vochy is offline
post #614 of 632 (permalink) Old 10-30-2016, 08:11 PM
Bronco Info: 1996 XL 5.0L; ProComp 6" lift w/ extended radius arms
Hello,
I've been reading around the forums about what tire I should put on my newly lifted(ProComp 6" w/ Extd Rad Arms) 5.0L '96 Bronco(see Below).
Is it true that I need to get re-geared with a 35" tire? Is my 5.0L enough to push the bigger tires?
Does anyone have any personal experience or recommendations on 34" vs 35" w/ a 6" lift?
Edit: this is a weekend warrior/camping truck. Hit easy to medium trails in Colorado. Not a daily driver.
Thank you for reading!
duvalbronco is offline
post #615 of 632 (permalink) Old 11-13-2016, 08:16 PM
Bronco Info: '96 Bronco Eddie Bauer, 5.8L, E4OD, BW1356E, Auto Hubs
Here are the measurements that I recorded on my '96 with 31x10.5R15 tires at the bottom of the wheel wells.
Front: 35 3/8"
Rear: 36"
Hope this helps out.
'96 Eddie Bauer Bronco, leather, 5.8L, 3.55 LSD, Bilstein 4600's, DC XC 33x10.5x15, K&N stock replacement, 460 intake tube.
They call me Dave.
Bruners4 is offline
post #616 of 632 (permalink) Old 01-27-2017, 07:42 AM
91broncocrawler's Avatar
So I just bought this 1991 Bronco. It appears to have a leveling kit on it. It has these axle pivot brackets with the two holes like they were discussing earlier in this forum. I am going to purchase a 6 inch lift kit. However was wondering if these brackets would be enough if I were to just buy the extended radius arms, coils, shocks and pit man arm and pieced together the kit I want. I just didn't know if they had a bracket that fit the 2 inch lift and 4 inch lift and then another bracket for the 4 inch lift and the 6 inch lift. Dont know if there is a difference or not.
Thanks in advance.
91broncocrawler is offline
post #617 of 632 (permalink) Old 02-03-2017, 10:59 AM
Does anyone know if they have lift block shims to readjust the pinion angle on a 6" lift
Fighting wolf is offline
post #618 of 632 (permalink) Old 02-03-2017, 12:35 PM
Bronco Info: 1990 Ford Bronco XLT 5.0EFI, 4x4,(Original Stock Everything).....For Now!!!
Hello,
I have been seeing some Broncos with 4 front shock absorbers (two on each front tire), instead of traditional 2, (one on each tire). I wonder is that due to aftermarket modifications, or factory equipped with select Bronco models. What is the benefit of having 4 front shock absorbers in stead of 2? Can a Bronco that was originally equipped with 2 shock in the front, be modified to accept 4?
BroncoJohn87 is offline
post #619 of 632 (permalink) Old 02-03-2017, 02:16 PM
a lot of these questions should be asked in their own thread in this Noobie section folks.
Would get you the answers you seek much faster.
post #620 of 632 (permalink) Old 02-03-2017, 05:53 PM
Fast Floyd's Avatar
Bronco Info: 1994 Bronco XLT 5.8L auto, 3L.55 on 10.50 x 31 x 15 Goodyear Wranglers
Yes there are different degree shim blocks to adjust the angle of the Pinion. these can be found at a local Speed shop.
1994 Bronco XLT 5.8L auto, 3L.55, on 10.50 x 31 x 15 Good Year Wranglers. Work In Progress.
Bassist for "3DC" Three Dog Knight Celebration
Fast Floyd is offline
