35 inch tires on stock bronco? - Page 2 - Ford Bronco Forum
post #21 of 51 (permalink) Old 07-22-2012, 02:33 AM
rhauf's Avatar
two years later, the OP is still getting answers..
i was about to throw on some pics of my '82 before lift with cut fenders and 35's... it rubbed like hell before i cut the fenders.
-Ryan
rhauf is offline
post #22 of 51 (permalink) Old 07-22-2012, 03:08 AM
alaskan155's Avatar
Bronco Info: 1988 BRONCO 5.0/AOD axle code H5
toss them on we already started adding to it, then add it to the stickes that way when a noobie asks what fits on a stock bronco they can see it or ask will 35s fit stock here it is
we know 33s fit stock across the years, but it is nice to know the mods needed to run bigger tires
88 Bronco(sold)
new trail rig
2000 ranger
4.0/5r55e/bw 4.10 gears 35 mt/rs
alaskan155 is offline
post #23 of 51 (permalink) Old 07-22-2012, 03:28 AM
rhauf's Avatar
you got it.. '82 bronco, bone stock, stock non offset rims.
bald 35" tires and fenders cut at the concave crease.
here's a later pic taken after the 4" lift was installed... along with new 35's on 10 inch rims (with a tiny bit of offset, the least i could get in 10" wide)
i actually really like this look.. if i were building another bronco this is what i would go for. performed great and had the perfect look IMO.
-Ryan
rhauf is offline
post #24 of 51 (permalink) Old 08-06-2012, 03:14 PM
Bronco Info: 1988 XLT
Got my 35s comin today with little to no lift, keep you guys updated on the fitment!
JET88 is offline
post #25 of 51 (permalink) Old 08-06-2012, 03:16 PM
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
dont try to turn or flext the front...
Tim
Newest token Jeep owner....
Redwagon is offline
post #26 of 51 (permalink) Old 08-06-2012, 03:32 PM
carlforman's Avatar
Bronco Info: 1984 Bronco XLT. 302 carburated. C6 3 spd. D44, NP 208F, 8.8, 31" Wranglers
I have an 84 bronco. 31x10.50's rub on radius arm on turns. Before, with stock tire, I was able to do a complete circle on a 2 lane road, and not go off the pavement. The stock bronc had an excellent turn radius with the short wheel base, but now some of that turn radius is affected, I can live with that for now, I will most likely get steel spacers 1.5 to 1". My $.02.
carlforman is offline
post #27 of 51 (permalink) Old 08-06-2012, 05:56 PM
HEres my new to me 88 with the PO 33s, got a flat on the front left due to dry rot, so 35s comin and it will be a squeeze up front, prolly gonna run with no bumper for a lil and possible mount the high lift up there (like that look). im sure ill be getting rid of some inner fender goodies just for ease of mind.
JET88 is offline
post #28 of 51 (permalink) Old 08-08-2012, 05:06 PM
35s on, rear obviously had a lil lift but front is saggin so I'm thinking it's almost stock. Bumper came off for some clearance.
JET88 is offline
post #29 of 51 (permalink) Old 08-08-2012, 05:29 PM
alaskan155's Avatar
so when you trimming the back of the front fenders/ front of the rear fenders?
88 Bronco(sold)
new trail rig
2000 ranger
post #30 of 51 (permalink) Old 08-09-2012, 12:21 AM
She's gonna be a road queen til I get my lift, no rubbing accept rad arms at full turn obviously. But managed a u turn today with no issues. I'd rather not cut her up.
JET88 is offline
post #31 of 51 (permalink) Old 08-09-2012, 12:43 AM
alaskan155's Avatar
watch the speed bumps then, part of me trimming mine was the fender got into mine a little, not bad, but if they where new it would have done some pretty decent damage,
my problem wasent full lock, was about 1/4-1/2 way turned in the front
88 Bronco(sold)
new trail rig
2000 ranger
post #32 of 51 (permalink) Old 08-09-2012, 12:44 AM
Bronco Info: Red/White '79 Custom-400, 435, 205. '86 EB beater, 302, 435, 208 stock on 35's, '95 XLT, 302, 5spd.
That's too nice to cut up, plenty of rusted out fenders running around for cutting.
man... the things I've learned on this site simply boggle the minds of everyone I talk too. (Biker Pepe)
CS79bronco is offline
post #33 of 51 (permalink) Old 08-09-2012, 11:25 AM
alaskan155's Avatar
yeah i do love how clean his looks, wonder if mine ever looked that clean
88 Bronco(sold)
new trail rig
2000 ranger
post #34 of 51 (permalink) Old 08-09-2012, 05:37 PM
Bronco Info: 83 bronco xlt 4.9L 6cyl 300 cid carb'ed - mostly stock (for now)
for those of you who had to deal with 35's rubbing... was it the width of the tire or the height of the tire that was causing the rub?
wolf83 is offline
post #35 of 51 (permalink) Old 08-09-2012, 06:05 PM
Bebop_Man's Avatar
Bronco Info: '86 302 EFI
Width
http://www.fullsizebronco.com/forum/image.php?type=sigpic&userid=53052&dateline=133305  7678
'86 w/ 302, T-18 4-spd, BW 1345 T-case, 3G alt, Saginaw PS pump, hydroboost, 12000lb winch, custom bumpers, side rails, roof rack, 35" MTR's Supermotors Registry
Bebop_Man is offline
post #36 of 51 (permalink) Old 08-09-2012, 08:52 PM
86broncoxlt's Avatar
Bronco Info: 1986 ford bronco xlt with 351W. 3 inch body lift and 35x12.5x15 Mickey Thompson Baja mtz radials.
Width mine has 35x12.5 and rub when I go to do sharp turn I used to be able to turn on a dime now I have to hug the curb to make a u turn on a two lane road and I end up hitting the curb on the other side. I miss the turning radius. I think i might go with a smaller width on next set of tires.
Sent from my Autoguide iPhone app
86broncoxlt is offline
post #37 of 51 (permalink) Old 08-09-2012, 11:55 PM
alaskan155's Avatar
width and height and rim offset all cause rubbing.....
35s vs 33 you loose 1" in clearance because of tire height(tire is 1" bigger all the way around vs 33, so they give 1" lift), rims mine are 15x10( i believe may be wrong,), not sure on offset but they stick out more atleast 3" over the stock 15x7 rims i had
and my tires are 10.50 wide, pretty standard for 35s
btw my stock tires where 235/75r15 or 28.9 so i gained 3" of lift just in tires
88 Bronco(sold)
new trail rig
2000 ranger
post #38 of 51 (permalink) Old 08-10-2012, 12:09 AM
Mine are 35x12.5. On a 15x10 rim. Only rubs radius arms for now, did a lil rubber mallet action on the corners to be safe, only on the inside of course.
JET88 is offline
post #39 of 51 (permalink) Old 08-11-2012, 10:29 PM
alaskan155's Avatar
just found the specs on my rims
crager chrome quick tricks
15x10 and 3.75 backspacing so i have 6.25" of rim sticking out past the hub
88 Bronco(sold)
new trail rig
2000 ranger
post #40 of 51 (permalink) Old 01-17-2013, 11:58 PM
FordsForeverEric's Avatar
Bronco Info: '87- 4.9, Tremec RTS 4-spd, 33's, SAS
I think most all 35's are 12.50's
I think to get 10.50's you got to go BFG or Interco... maybe some others
but don't listen to me, I'm running 33's on mine with about 6" of SAS lift, I've never bought a set of 35's in my life....
Maybe someday when I'm not in college and am making money again lol
FordsForeverEric is offline
