Interior/Exterior color pallet/options for 92-96? - Ford Bronco Forum
post #1 of 16 (permalink) Old 09-30-2010, 07:13 PM Thread Starter
Biebs Ain't BabyDaddy!
loarmistead's Avatar
Bronco Info: '96 w/ 351, '93 w/ 302
I am looking for a page that has the color combinations of different Bronco paint schemes, along with the paint name and number. I'd especially like the Eddie Bauer options - e.g. what exact paint colors/numbers were offered on the lower body and the top? I know some are lighter tan and some are darker.
‎"In our age there is no such thing as 'keeping out of politics.' All issues are political issues, and politics itself is a mass of lies, evasions, folly, hatred and schizophrenia."
-George Orwell
loarmistead is offline
post #2 of 16 (permalink) Old 09-30-2010, 07:48 PM
Bennelton's Avatar
Bronco Info: 86 Bronco 351/5.8L 385hp Ford Racing Crate Motor, 32" BFG AT's, soft top and some other stuff.
1986 Bronco Eddie Bauer 5.8L
https://www.supermotors.net/19921
Bennelton is offline
post #3 of 16 (permalink) Old 09-30-2010, 09:13 PM Thread Starter
I found this site:
http://www.tcpglobal.com/autocolorlibrary/
But it doesn't give me anything I can see as far as the available colors for the top.
-George Orwell
post #4 of 16 (permalink) Old 10-01-2010, 12:13 AM Thread Starter
I guess a better question could be - does anyone know the name of the different tan colors that Ford painted the tops? I know some tans are so light they almost look white, while other tans are darker.
-George Orwell
post #5 of 16 (permalink) Old 10-01-2010, 07:26 AM
yo,
So far this morning, I have this;
Brochure, 95 Bronco
Source: by Ford via Hans Tore Tangerud @ lov2xlr8.no
& in my broncolinks.com site, I have Links to:
Paint Codes TSB 92-20-01 for 93 Bronco, F Series & many others
Paint Codes TSB 93-24-04 for 94 Bronco, F Series & many others
Paint Codes TSB 95-23-01 for 96 Bronco, F Series & many others
TSB 92-20-01 Paint Codes
Publication Date: SEPTEMBER 23, 1992
FORD: 1993 CROWN VICTORIA, ESCORT, MUSTANG, TAURUS, TEMPO, THUNDERBIRD
LINCOLN-MERCURY: 1993 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VIII, SABLE, TOPAZ, TOWN CAR, TRACER
LIGHT TRUCK: 1993 BRONCO, ECONOLINE, EXPLORER, F SUPER DUTY, F-150-350 SERIES, RANGER, VILLAGER
ISSUE: The following 1993 Ford and Lincoln-Mercury color chart provides all of the supplier paint code numbers for the Ford two-digit paint codes listed on the Vehicle Certification Label.
ACTION: Paint should be available in either enamel or urethane from the manufacturers. To get the color match, either the "Factory Pack" or "Intermix" is okay to use.
will bbl with more on the top colors if I can find it in my notes or files
miesk5 is online now
post #6 of 16 (permalink) Old 10-01-2010, 07:37 AM
Section 00-01: Identification Codes 1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
post #7 of 16 (permalink) Old 10-01-2010, 10:50 AM Thread Starter
Very nice! Thanks!
Now if someone with a tan top and tan lower could pretty please let me know what their paint code is on their door so I can figure out what these colors look like, I would really appreciate it. Medium Mocha is looking like what I am shooting for.
-George Orwell
post #8 of 16 (permalink) Old 10-01-2010, 11:17 AM
yo! YW
See some Door Jamb Label (Certification Label, also referred to as the Patent Plate, Data Plate & the Warranty Plate) pics in my site under History
Such as;
Door Jamb Label (Certification Label, also referred to as the Patent Plate, Data Plate & the Warranty Plate) pic for a 96
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
VEHICLE CERTIFICATION LABEL (VC LABEL) CODES
Vehicle Type Codes
The vehicle data appears on the certification label on the second and third lines following the identification number.
The code set (two numbers, or several letters, or a number and letter) above COLOR identify the exterior paint color (two sets of codes designate a two-tone).
The digits under WB designate the wheelbase in inches.
The letter or digit under BRAKE TYPE designates the truck brake type.
The letters and/or numeral under BODY designate the interior trim, seat and body type.
The transmission installed in the vehicle is identified under TRANS by an alphabetical code.
A letter and a number or two numbers under AXLE identify the rear axle ratio.
The letters and/or numerals under TAPE designate the external body side tape stripe code.
The spring usage codes for the vehicle are identified under SPRING.
A two-digit number is stamped above DSO to identify the district that ordered the vehicle. If the vehicle is built to special order (Domestic Special Order, Foreign Special Order, Limited Production Option, or other special order), the complete order number will also appear above DSO.
SEM Vinyl & Leather Classic Coat™ Chart, Ford Colors W/Trim Codes; miesk5 Note; appears to be 2000 era model Ford colors codes; 17013 Midnight Black ZUEA 17023 Lt. Graphite ZUBA 17033 Lt. Parchment BJAA 17043 Med. Graphite ZUCA 17053 Med. Parchment BJCA 17063 Med. Prairie Tan AYCA 17073 Med. Dk Graphite ZU4A 17083 Dk. Graphite ZU5A
Source: by SEM
post #9 of 16 (permalink) Old 10-01-2010, 11:21 AM Thread Starter
Awesome! My codes are "DB UC." I don't know exactly what the DB is named, but I assume it's the black primary color, and "UC" according to your list above is "Light Mocha," which is my lower body/top color I presume. I am going to search for other Light Mocha tops because mine is so light it almost looks white. I am going to get it repainted, and if the light mocha color is actually darker than that, it's fine. But if Light Mocha is nearly white as it looks on mine, I'm going to look into making it a slightly darker shade of tan.
-George Orwell
post #10 of 16 (permalink) Old 10-01-2010, 11:27 AM
btw in VEHICLE CERTIFICATION LABEL
Broncos aren't listed in BODY section prob due to phaseout when Workshop Manual was edited by Ford
post #11 of 16 (permalink) Old 10-02-2010, 11:54 AM Thread Starter
Excellent, so it looks like the lower body/fiberglass top tan color for the 95-96s is "Light Saddle." The code for the body paint is "DZ - Light Saddle," and the code for the fiberglass top paint is "U - Lt Saddle." Correct me if I'm wrong. I am getting these codes from miesk's pictures.
Right now my '93 top and bottom is I believe "Light Mocha," which is like a very light desert tan. It's not a bad color at all, but if I am going to be shelling out all of these Benjaminz for a new paint job I'm going to make it the paint job I want.
-George Orwell
post #12 of 16 (permalink) Old 10-04-2010, 10:52 AM
yo,
When you go to the shop, get a sample and look at it outside in sunlight and/ or at night if you want to see how it looks outside your home or the club/or wherever; under whatever lighting is there (sodium makes a lot of colors look bad)
GL!
post #13 of 16 (permalink) Old 10-04-2010, 11:02 AM
convcit's Avatar
Bronco Info: 1984 with a 351W, HEI Dist, Hooker headers, Holly carb, C6, 4in suspension lift, 35in Falken tires.
I will try to get that off of mine when I get home..
convcit is offline
post #14 of 16 (permalink) Old 10-04-2010, 11:39 AM
yo
I failed to confirm this;
DB - Light Mocha Solid
From Steve83's TSB 92-20-01 Paint Codes Link I initially posted http://www.supermotors.net/registry/media/724168_1
but no code for UC
post #15 of 16 (permalink) Old 10-04-2010, 12:25 PM Thread Starter
UC must be the black code, but I haven't been able to find it, either. And DB is definitely the light mocha solid, and it looks like they retired that shade of tan after '93 or '94, as all of the '95s and '96s I've seen have been the light saddle shade of tan.
-George Orwell
post #16 of 16 (permalink) Old 10-04-2010, 02:46 PM
yo,
Ford made changes day-to-day at times.
Ebony UC
Found it @ an internet site.. for a Probe tho...
Here is a better version of the 93's TSB by Ford via Chilton this is a better scanned version
