Would changinf from 235 Stock to 31 Stock effect Speedo/Odo reading? - Ford Bronco Forum
post #1 of 16 (permalink) Old 11-28-2010, 05:45 PM Thread Starter
JohnMcD348's Avatar
OK, so I'm thinking way ahead about switching over to the 31x10.5x15 tire when my factory size 235's wear out. If I calculated right, my 235's are about 29-30" tires. If I switch to stock size 31" tires would I need to adjust the PSOM or would the 1-2 inch difference not be enough to throw the speedometer and odometer off?
I looked around online for a calculator for this and all I could really find were tire size calculators.
Thanks
JTMcD.
JohnMcD348 is offline
post #2 of 16 (permalink) Old 11-28-2010, 05:51 PM
#1 Asshole
theramsey3's Avatar
Bronco Info: 90 5.0 H.O. E4OD BW1356 3.54 3L55 32/11.50R15 Black not the one in the pic ^^^
Yes you will need to program your psom. It is a relatively simple process and should only take a few minutes. It will probably take longer to do the math than to make the change. Look herehttp://www.fullsizebronco.com/forum/show...highlight=psom for a how to it is super easy.
Gotta get going again soon. my supermotors for before and after.
Originally Posted by ford_munky_man View Post
I was always taught u got to lube it up before you stick it in. My friends said the teacher yesterday said that too.
theramsey3 is offline
post #3 of 16 (permalink) Old 11-28-2010, 06:39 PM Thread Starter
JohnMcD348's Avatar
OK, thanks. I think about going up to the other stock size but have concerns about it since I've got 3.08 gears. I can't justify spending $4-500 on new rubber and then having to spend more to get slightly lower gears (3.55-3.73) to go with it. I wonder what the average weight difference is between the two sizes.
JTMcD.
MY A/C Vacuum leak repair http://www.fullsizebronco.com/forum/showthread.php?t=175808
post #4 of 16 (permalink) Old 11-28-2010, 07:58 PM
RebelRider2010's Avatar
Bronco Info: '96 XLT. E4OD, E-T-case 351W-tune up. 4'' Rancho Lift kit. 31'' tires.
I've wondered about this as well, My truck has 31's on it now, pretty sure they weren't stock?
Looking through that link, it looks sort of confusing, I'm not a math person so all those equations throw me off...
The America flag flies from the last breath of each military member who has died protecting it. Americans don't fight because they hate what's in front of them. They fight because they love what's behind them
RebelRider2010 is offline
post #5 of 16 (permalink) Old 11-28-2010, 08:30 PM
#1 Asshole
theramsey3's Avatar
31's will be fine don't worry about it. I wouldn't run anything bigger than 32's on those gears.
post #6 of 16 (permalink) Old 11-28-2010, 08:49 PM
shibby
Dustball's Avatar
30"/31" = 0.97 so your speedo and odo will read approx 3% low. At 70 mph indicated on the speedo, you're really going 68 mph.
Dustball is offline
post #7 of 16 (permalink) Old 11-28-2010, 08:53 PM
U jelly of my
offroadkarter's Avatar
its so easy to reprogram it, i would
>>>super slow build thread<<<
2003 & 2004 Mercury Marauder 1985 BMW 745i 2016 Ford Mustang GT Performance Pack
offroadkarter is offline
post #8 of 16 (permalink) Old 11-28-2010, 08:54 PM
RaZOrFLy's Avatar
Bronco Info: 1993 XLT, E4OD, Ram Air 302CID-SD, 31s, 3.55:1, Locked and loaded, front and rear, 1994 F150 XLT
You are correct that the speedo/odo will read a little low, but the last bit is actually the other way round. A taller tire has a slower rotation, so the truck will actually be going a little faster than what is indicated on the speedo.
RaZOrFLy is offline
post #9 of 16 (permalink) Old 11-28-2010, 09:10 PM
RaZOrFLy's Avatar
Are you running 15 X 6" or 15 X 7.5" wheels?
If you've got 7.5" wheels, go with the 31/10.50 (or 265/75/15--it's the same size, but you get a UTQG rating, lighter weight and additional load rating, for whatever reason), but don't try to shoehorn a 31/10.50 onto a 6" wheel.
As per your question about weight difference (good question, BTW), assuming we are comparing all terrain tires and not mud terrain tires, you can expect the following:
235/75/15 Versus 31.10.50/15:
36LBS Versus 42LBS from BFG
38LBS Versus 46LBS from Goodyear
32LBS Versus 43LBS from Michelin.
RaZOrFLy is offline
post #10 of 16 (permalink) Old 11-28-2010, 11:01 PM
shibby
Dustball's Avatar
Ah, yeah- you're right. Brain fart on my part.
Dustball is offline
post #11 of 16 (permalink) Old 11-29-2010, 12:30 AM Thread Starter
JohnMcD348's Avatar
I think they are 7.5" wheels. They are the stock factory Aluminum Alcoa wheels. I'm planning on going with the BGF All Terrains when I make the switch. THey came stock on my Ram and I've been pretty impressed with them so far. Granted the ones on the Ram are E rated at 265/70/17. I don't get it much since I can't seem to get an equivalent rating on basically the same tire. If I go larger they are rated at D. I think the 31"(265) are only a C rated tire. I'll be getting new rubber on the Ram before I get it on the Bronco so I've been doing alot of looking around.
JTMcD.
post #12 of 16 (permalink) Old 11-29-2010, 03:46 AM
Driving Stuff Henry Built
El Kabong's Avatar
Here's a good Gear Ratio Calculator where you enter your info & it'll tell you the RPMs at various speeds, along with a ton of other info. It has 2 calculators side by side for easy comparison. Be sure to hit "Calculate" for each side after any changes. Plugging in an M5OD, 1356, 3.08 gears, & 29s it shows 1832 rpm at 65 mph. With an M5OD, 1356, 3.08 gears, & 31s it shows 1846 rpm at 70 mph.
El Kabong is online now
post #13 of 16 (permalink) Old 11-29-2010, 01:58 PM
RaZOrFLy's Avatar
It's a safe bet that they are 15 X 7.5", then. Pull off one to be sure, and look at the JJ stamp in the aluminum. It will confirm it or prove otherwise, but if memory serves, all 15 X 6" wheels for Bronco were steel.
Look at the Goodyear Wrangler Silent Armor "Pro Grade" line. They come in the same sizes as the regular "c" range SA tires, but have load range capacities between 116-123.
RaZOrFLy is offline
post #14 of 16 (permalink) Old 11-29-2010, 03:52 PM
yo John
Tire Rack has the info you'll need when you calibrate your PSOm when you go to large diameter tires
This is for da BF Goodrich All-Terrain T/A
http://www.tirerack.com/tires/tires....all=Blackwall#
Click on Specs for Revs Per Mile, Overall Diameter etc.
and compare it to Ford's Conversion Constants for validation
Calibration
miesk5 is online now
post #15 of 16 (permalink) Old 11-29-2010, 09:56 PM
justin's Avatar
Bronco Info: 96 XLT/5.0/E4OD
265/75/R15 was a stock option, check your doorjamb sticker.
-Winston Churchill
justin is offline
post #16 of 16 (permalink) Old 12-01-2010, 08:12 PM
Ok, I'll save the reprogram for when I go to 33's.
Thanks.
