Looking for M5OD diagram and pics - Ford Bronco Forum
post #1 of 6 (permalink) Old 01-06-2011, 11:09 AM Thread Starter
JohnMcD348's Avatar
OK, before I take the top off my transmission I'd like to see what I'm supposed to find so I can have a better idea of what's good and needs replacement. I'm expecting to see issues with the forks and possibly some missing teeth. But I'm also wondering if there's a gasket between the case and cover and info on anything else I need to know before I take it off. I want to get all the parts I'm probably going to need replacing. I know I'm replacing the plugs on top but not sure about anything else yet. I've tried Googling for images and diagrams and so far have turned up pretty empty.
Thanks
JTMcD.
JohnMcD348 is offline
post #2 of 6 (permalink) Old 01-06-2011, 01:16 PM
yo John,
I have a few Links in my site @ http://www.broncolinks.com/index.php?index=57
including;
M5OD-R2 Parts Break-Out Diagram w/ Out Ford Part Numbers & Nomenclature; "...TRANS code: M - Known problems include: leaks from shift rail plugs #60 & 61 sensitivity to fluid level & quality weak shifter susceptible to wear..."
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
http://www.mackstrans.com/transID.html
by MACK's
Go to page 50 of http://www.transtar1.com/catView.asp?ID=40
it's page 54 of 120) for break down of the M5OD R1/R2 transmissions
I can't view it because my pc here won't load it ..
post #3 of 6 (permalink) Old 01-06-2011, 03:06 PM
92Custom's Avatar
Bronco Info: 1992 Bronco Custom, 302/5 speed/4x4. pretty much stock.
Mine has literally eaten away half of the fork material on one side of one of the forks. That, some chewed up gears, the pilot bearing eating the snout, bad synchros all over, and some bearings out of tolerance made a new transmission the quicker, cheaper way to go. $975 + $100 shipping.
But don't feel bad. The E4OD guys have to pay $3000 for just a rebuild. :P
1988 Thunderbird Turbo Coupe, 2.3 OHC with turbocharger and intercooler/5 speed, time warp late 80's high speed road trip car/police magnet....
1992 Bronco Custom, 302/5 speed, lots of new stuff
1993 Tempo GL 2-door, 2.3 HSC/5 speed, my first car, probably giving to girlfriend to drive so I can justify keeping it around
92Custom is offline
post #4 of 6 (permalink) Old 01-06-2011, 06:02 PM
JBfab's Avatar
I Went through there m5. Two pairs of forks and a bad sincro. Spent $1000 on a zf never had a problem.
JBfab is offline
post #5 of 6 (permalink) Old 01-06-2011, 09:29 PM Thread Starter
JohnMcD348's Avatar
Well, I'm actually thinking my M5OD isn't as bad of a transmission as people make it out to be. After all, it was bone dry and got me home. After putting 4qts of Mobil1 ATF in it, it's still going but making some noises I don't particularly care for. The only bad part when the transmission went dry after 84,000 miles was that I had to shift from 1st to 3rd/4th/5th or start off in 2nd and go to 4th/5th. I'm hoping I only need to clean it our a bit and possibly replace the forks when I replace the rubber plugs so it will hold the fluid in. Then I think it will last me a good long while after that.
Thanks again for all the great info.
JTMcD.
MY A/C Vacuum leak repair http://www.fullsizebronco.com/forum/showthread.php?t=175808
post #6 of 6 (permalink) Old 01-15-2011, 01:47 PM Thread Starter
JohnMcD348's Avatar
OK, I popped the top today and didn't find what I was hoping for and also found something that has me very worried and concerned. The forks looked nearly new. The only wear I saw was on the front forks some of the original molding lines were still visible so I'm thinking they are not bad. What has me very concerned is the large front gear in the transmission. There is what looks like a machined flat spot on the gear. Here's the pictures I took.
wear noted on tip of front fork. You can still see some of the line from where it was molded.
Slight rub area in the arch of the front fork
Rear Fork. They still look untouched with no wear seen at all.
rear facing shot of both forks
This is what concerns me. Is this normal? Is there some reason this gear is formed this way or should there be teeth all the way around it?
JTMcD.
