1995 bronco transmission trouble - Ford Bronco Forum
post #1 of 30 (permalink) Old 07-07-2011, 12:28 AM Thread Starter
i bought this 1995 bronco the other day to be my off road toy. being a bowtie guy "sorry just stating my automotive knowledge" i dont have much experience with ford transmissions. i drove this truck home and everything was fine. parked it in front of the house and went back out to take my wife for a drive and i had no forward gears. put it in reverse and the trans engages and wont move. tried to push the truck back in neutral and it wont budge. push it forward and it goes. checked the fluid not burnt and full. started the truck again put it in drive and nothing. put it in reverse and gave it some gas and i heard a small pop from the rear end and she drives backwards. put it back in drive and nothing. now here is the weird thing. if i put it in 4 low and in 1st i hear the trans engage and if i rev the engine it goes backwards. WTF??? it has the 5.8 but im not sure of the trans. the truck is completely stock never molested. still has the original stereo in it. i bought it from an old guy who only used 4x4 a couple of times.
any ideas?
greasemykey is offline
post #2 of 30 (permalink) Old 07-07-2011, 12:29 AM Thread Starter
oh i forgot to mention that i checked the return trans fluid lines check valve and its working fine and free. i did find that online in a forum somewhere.
post #3 of 30 (permalink) Old 07-07-2011, 12:31 AM
I scrape on both sides
Jasonhughes2009's Avatar
Bronco Info: 91 ish
you checking the fluid on level ground?
what tranny is it
1991, fresh 5.0, OBA, 6 inch lift, 9 inch rear, 5.13s. detroit rear aussie front, 37" pitbull rockers, beadlocks. e4od
Originally Posted by tonyroc14 View Post
If only I could have 6 of his 32 inches!
Jasonhughes2009 is offline
post #4 of 30 (permalink) Old 07-07-2011, 12:35 AM Thread Starter
what tranny is it
i check it with the engine running on a flat surface. im not sure about the trans. can you give me an idea on what to look for to verify?
post #5 of 30 (permalink) Old 07-07-2011, 12:38 AM Thread Starter
trans code on the door says "E"
post #6 of 30 (permalink) Old 07-07-2011, 12:49 AM
Bronco Info: 93 Bronco with 302
TRANS codes:
adrianspeeder's Trans ID list
5Speeds.Com's Tag Identifier (bottom of page)
A = NP435
B = BW T-85 3sp ('76-78 ), Clark OD 4sp ('79-86), Ford SROD/Tremac T170 4sp, or T199 (Mexico only)
C = Ford 3.03 3sp, or ZF S5-42 Close-ratio
D = BW T-89 3sp
E = BW T-87 3sp (early), orE4OD/4R100 auto (gas)
F = BW T-18 4sp
G = Ford C4 auto
J = Ford FMX auto
K = Ford C6 auto
M = Mazda M5OD-R2
P = BW T-19 (early), or Ford C6 auto
T = Ford AOD auto
U = Ford 4R70W auto
W = Ford C5 auto, or ZF S5-42 HD Wide-ratio
Z = ZF S5-42
6 = ZF M6HD-6
7 = Ford E4OD/4R100 auto (Lightning)
9 = Ford E4OD/4R100 auto (diesel)
jkm354 is offline
post #7 of 30 (permalink) Old 07-07-2011, 01:04 AM Thread Starter
its the E4OD then i think its the planitery gear set but im hoping its something stupid like a vacuum line or valve body issue
post #8 of 30 (permalink) Old 07-07-2011, 01:06 AM
CWbronco's Avatar
Bronco Info: pile of parts
you most likely have an e4od. Which is a mess. I have nothing else of use to include so good luck to you.
Build
SAS
FOTM Oct. 2012
CWbronco is offline
post #9 of 30 (permalink) Old 07-07-2011, 08:42 AM Thread Starter
bump???
post #10 of 30 (permalink) Old 07-07-2011, 05:28 PM Thread Starter
bump
post #11 of 30 (permalink) Old 07-07-2011, 08:52 PM
Dmanic's Avatar
Bronco Info: 1993 XLT 5.8 e4od/7.5" on 37's/4:56/shackle flip/3G/efan/cust steer/punisher v/b/saginaw/redhead
This is a long shot, but have you checked the gear selector? i had one that did all kinds of weird s%*! because it was missing one of the bolts on the selector shaft. Also check the linkage underneath. Just a thought.
Good luck.
93/88/96
Dmanic is offline
post #12 of 30 (permalink) Old 07-07-2011, 10:29 PM Thread Starter
any info on how to check and adjust would be awesome
post #13 of 30 (permalink) Old 07-08-2011, 02:39 AM Thread Starter
bump
post #14 of 30 (permalink) Old 07-08-2011, 02:58 AM
A broke kid with a bronco
catsnw's Avatar
Bronco Info: 1995 EB bronco 5.8, auto, true duals, k&n intake, 3G alternator, 12 front lights (more to come!)
You have an E4OD. Start with the basics pull codes!! (here) do that first. Post back. I wonder if the shift solenoids are jacked up. You have a weird reverse so I don't think the filter fell out and into the pan. Pull codes and post back.
Originally Posted by 88LiftdBronco View Post
So what you're saying is, that when you see a penis you think of another guy?
٩(●̮̮)۶
catsnw is offline
post #15 of 30 (permalink) Old 07-08-2011, 03:09 AM
Dmanic's Avatar
Do a search for adjust transmission, a ton of them come up. I think its one of the first two links...
93/88/96
Dmanic is offline
post #16 of 30 (permalink) Old 07-08-2011, 03:55 AM
catsnw's Avatar
Pull codes before adjusting the mlps. If you pull codes it can tell if the sensor needs adjusting.
٩(●̮̮)۶
catsnw is offline
post #17 of 30 (permalink) Old 07-08-2011, 02:27 PM
Bronco Info: 1995 Eddie Bauer
The gear selector can come loose at the steering column. The linkage is also prone to coming apart. Just my $.02.
billybobg is offline
post #18 of 30 (permalink) Old 07-09-2011, 12:19 AM Thread Starter
but for it to go backwards in 1st gear??? i am beginning to think my valve body is jacked up.
post #19 of 30 (permalink) Old 07-09-2011, 03:43 AM
catsnw's Avatar
I'm thinking the same thing.
But pull those code! It can tell if the mlp is wacked up/not correct position.
٩(●̮̮)۶
catsnw is offline
post #20 of 30 (permalink) Old 07-09-2011, 10:43 AM
yo. I agree with CATSNW on just doing the DIY Diagnostic Trouble Code (DTC) Testing first.
There are two types of Tests, Key On Engine Off (KOEO) & Key On Engine Running (KOER).
The Link provided goes to Ryan M's KOEO portion of the test; Ryan needs to include a Hot Link someday to the KOER portion which is @ http://www.fordfuelinjection.com/?p=94
The engine temperature must be greater than 50F (10C) to pass the KOEO Self-Test and greater than 180F (82C) to pass the KOER Self-Test.
Run it around to heat the engine up and try to shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Make sure A/C is off and transmission is in Park (automatic)
Do Key On Engine Off (KOEO) portion first.
Look Codes up in my broncolinks.com site using the new Search function if in a hurry.
And Post em here according to:
KOEO
& KOER
Is the Transmission Control Indicator Light (TCIL) (overdrive off/on Button and LED on end of shifter stalk Blinking?
Is Check Engine Light (CEL) ON all the time?
It should light up briefly when first starting the Bronco.
E4OD shifter pattern
pic by Chris A
Trans code: E
