Fuel Pump Leak. - Ford Bronco Forum
post #1 of 3 (permalink) Old 04-08-2012, 03:55 AM Thread Starter
LeviD's Avatar
Bronco Info: 1979 Ford Bronco, Ranger XLT, 400, 6" Skyjacker suspension lift, 35" mickey thompson baja claws
Fuel Pump Leak.
I noticed last weekend my fuel pump drips gas at about 1 drip per 1-3 minutes. I had really old tubing going from my hardline from the tank to the pump so I replaced that today and the tubing and fuel filter going to the carb while I was at it. Once I replaced it I started her up but the dripping continued. Do I have a bad fuel pump and should just buy a new one? Or do they have any types of gaskets that can be replaced on them that would be causing the leaking?
LeviD is offline
post #2 of 3 (permalink) Old 04-08-2012, 05:31 AM
RatBronco's Avatar
Bronco Info: 79 Free Wheelin' - 69 460/C6/D60/5.13/DL/14Bolt/5.13/Powr-lok/44" Hawgs
I think there is blow-by hole on mech fuel pumps to let you know it blew the diaphragm. Water pumps have this also but for the seal. Check your lines again but my money is on the pump. For ~ $20-$25, it is worth it to get one and eliminate the pump as the problem.
Check your oil for gas, if you blew the diaphragm. Sometimes gas will blow through and get gas in your oil.
James
79 Free Wheelin' Edition - 44" Hawgs
69 Lincoln 460/C6/205
D60/5.13/Powr-Lok
14Bolt/5.13/Detroit Locker
RatBronco is offline
post #3 of 3 (permalink) Old 04-08-2012, 08:08 AM
Joisey don't smell funny
2ndHelping's Avatar
Bronco Info: 78 Bronco, 460/ZF-5spd, D44 & D60, 4 link rear w/air bags, 35" BFG's
Check out this thread. <----clicky
I just went through this same thing.
Originally Posted by loarmistead View Post
It's simple, really. Non-hyphenated Americans have jobs, therefore they have no time to meddle in such menial and irrelevant affairs. Anyone who gives a shit about what you call him either has a vagina or too much time on his hands.
1979 Bronco 351m/NP435/33's 1996 - 2002 R.I.P.
1993 Bronco XLT 302/E4OD/33's 2002 - 2008 R.I.P.
1978 Bronco 460/ZF5/35's 2010 -
2ndHelping is offline
