Official Name This Part Thread! - Page 5 - Ford Bronco Forum
 4Likes
post #81 of 459 (permalink) Old 03-12-2013, 09:15 AM
Thread Killa
jowens1126's Avatar
LOL
jowens1126 is offline
post #82 of 459 (permalink) Old 03-12-2013, 09:31 AM
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
I use that pin to keep my camper tie down bar from sliding on the frame rail
I can see Alvins theory working on the 70s frame as they did not have alot of stuff rivited on them to interfer with stacking would not take alot to hold a frame from sliding only need two engagement points
the more I think about it the angle of the coil buckets on the 80+ frames would allow stacking as well as they do angle a bit from the frame
when I was aligning frames we did not use the pins we did use prepunched holes in the frame most of the pins were bent one way or the other plus our guages needed holes to secure to
without being a ford engineer that designed the frames in the first place my idea of the pins use is just speculation though I did find my own use for it :)
InfoFord is offline
post #83 of 459 (permalink) Old 03-17-2013, 10:08 PM
Bronco Info: 88, 302 Windsor, mostly stock
whats this part called?
http://www.supermotors.net/registry/media/970635IMG]
http://www.supermotors.net/registry/media/970635[/IMG]
nonco is offline
post #84 of 459 (permalink) Old 03-17-2013, 10:45 PM
Ziggy's Avatar
Bronco Info: 79 Bronco
Inside door handle/latch assembly.
Ziggy is offline
post #85 of 459 (permalink) Old 03-18-2013, 08:18 AM
User Registered
BakerBaker's Avatar
Bronco Info: 87 EB,C6,1356
With a 9.8 grade bolt to hold that, no wonder I feel safe in my bronco.
BakerBaker is offline
post #86 of 459 (permalink) Old 03-18-2013, 07:40 PM
Jesse Cantelope's Avatar
Bronco Info: 95 5.8L Eddie Bauer. 33's, MSD ignition coil and distb,K&N intake, Optima yellow top
ok, whats this?
Breather?, it's located between the battery and radiator. the thing with two knobs on it.
Jesse Cantelope is offline
post #87 of 459 (permalink) Old 03-18-2013, 09:13 PM
Steve83's Avatar
post #88 of 459 (permalink) Old 03-19-2013, 11:08 AM
Thank you sir!
post #89 of 459 (permalink) Old 03-27-2013, 09:28 PM
Bronco Info: 1986 Bronco 351W
Okay, on my '86 5.8 there's a hose that leads to the passenger side valve cover near the back of the motor. This hose connects to a metal piece that just sits in a hole in the top of the valve cover - no clip or screw or anything; it just sits in the hole. Along this tube there is what looks like a lever that swings 360 degrees. sometimes it makes a loud hissing noise - vacuum leak I presume - and I can momentarily stop it by putting my finger on the lever.
what is it and what does it do?
cjshelley is offline
post #90 of 459 (permalink) Old 03-27-2013, 09:57 PM
Bronco Info: 96 White 351w D44-TTB, 8.8, E4OD with Punisher Valve Body
PCV Valve, it should be pressed in to a rubber grommet in the valve cover with a hose going to the manifold it allows gasses to escape from the crankcase. Just replace the valve, grommet and reroute the hose while your at it.
http://www.fullsizebronco.com/forum/showthread.php?p=2610245
Giddy-Up is offline
post #91 of 459 (permalink) Old 03-28-2013, 11:59 AM
Thanks, however...
Thanks Giddyup, however I'm more concerned with what the eff that lever thingie is. I should have been more clear, but about eight inches down the line from the pcv valve there's a lever-device that is the source of the noise.
post #92 of 459 (permalink) Old 03-31-2013, 01:11 PM
Is it on the PCV line, can you post a image of it?
Giddy-Up is offline
post #93 of 459 (permalink) Old 04-01-2013, 03:04 PM
okay, 3 inches down the line, not 8. sorry.
Here's the photo
post #94 of 459 (permalink) Old 04-06-2013, 12:21 AM
Bronco Info: 1993 XLT 5.8l
what is this called....ive searched everywhere
anyways I stripped the hole for the automatic tensioner, now i need a new bracket
i have only found one on ebay, and they call it an "alternator side accessory bracket"...is there another name for it?
http://www.ebay.com/itm/Ford-E150-E2...-/320978675172
wkenyon07 is offline
post #95 of 459 (permalink) Old 04-25-2013, 12:58 AM
AKA: Butthead
Alvin in AZ's Avatar
Here's the photo
Did you ever get an answer on that?
Alvin in AZ
Alvin in AZ is offline
post #96 of 459 (permalink) Old 04-25-2013, 01:12 AM
AKA: Butthead
...I stripped the hole for the automatic tensioner, now i need a new bracket
No way to fix it?
Tap it out bigger?
Glue the screw back in with JBWeld or PC-7?
Drill all the way through and use a long machine screw and nut?
Absolutely -nothing- can be done to save it? ;)
Somehow this tinkering fool can't believe it, see? LOL :)
...found one on ebay, and they call it an "alternator side accessory bracket"
Ford has a name for it somewhere. xD
But if they don't sell it separately or it only comes as an assembly, with that
part included, then in that case they don't usually publish a name for it or a
"part number" either.
Alvin in AZ
post #97 of 459 (permalink) Old 04-25-2013, 01:20 AM
Steve83's Avatar
Here's the photo
It's too close - I can't even tell where it is in the engine bay, or what the lever is attached to. Take another from farther back, and a different angle.
...i need a new bracket
Probably, but just go to any junkyard & pick one up. They're common as dirt: all F/Bronco '87-96 5.0L/5.8L use that bracket.
BTW
Ford calls them "the brackets for the air pump, alternator, power steering and compressor", but I haven't found anything more specific.
post #98 of 459 (permalink) Old 04-25-2013, 01:33 AM
AKA: Butthead
How do you make a "divided by" symbol? :) = /2 ?
(could use it as the opposite of "times 2")
Anyway, I don't agree with any of that.
The picture is clear and well done and I know what area of the engine
it's on and can see the PCV right there at the end of that hose with its
st00pid little extra solid plastic hose connection and all. xD
I{t} looks like a bi-metal strip (heat) actuated valve to vent the PCV hose?
Anyway that's my guess, what it's really for or does I have no idea. :/
Be cool to know tho. :)
I don't believe in PVCs BTW. xD
Alvin in AZ is a skeptic
post #99 of 459 (permalink) Old 04-25-2013, 02:17 AM
Steve83's Avatar
OK I had to stare at it, but I finally see where & what it is. Someone added a valve to cut off or adjust the PCV flow, probably due to an unrestricted vacuum leak, or excessive blowby.
post #100 of 459 (permalink) Old 05-08-2013, 04:57 PM
F.O.T.M. - MAY 2014!!!
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs Daystar leveling kit
Parking Brake line to the rear drivers side tire broke at the place where the two lines split off the main line. What is it called exactly, I am ordering from Rock Auto and don't want to order the wrong part.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options. 4.10 gears LSD 33" MTs First ever Stock Fullsize of the Month...
J A S N http://www.supermotors.net/registry/19528
fartman is offline
