Factory 4.10 Gears? - Ford Bronco Forum
post #1 of 16 (permalink) Old 07-22-2012, 07:23 PM Thread Starter
Factory 4.10 Gears?
Hey guys. dont know a whole lot here. Just wondering if there is an axle that will direct swap in to my 1980 bronco that had factory 4.10 gears. i dont have a bunch of money to pay for gears but have a TON of junkyards around me that may have what i need. i know i can use the d50 with 4.10s in the front but not sure what is available in 5 lug for out back. thanks guys
1980 Ford Bronco
302 V8
Automatic C6
NP208F
Wojo is offline
post #2 of 16 (permalink) Old 07-22-2012, 08:28 PM
CWbronco's Avatar
Bronco Info: pile of parts
Sterling 10.25 does. But of course that's 8 lug. You could do Chevy 8 lug outers on the ttb though.
Build
SAS
FOTM Oct. 2012
CWbronco is offline
post #3 of 16 (permalink) Old 07-22-2012, 08:46 PM
Steve83's Avatar
Why wouldn't you use a D44IFS & 9" or 8.8" from an F150 or Bronco?
post #4 of 16 (permalink) Old 07-22-2012, 09:05 PM
CWbronco's Avatar
Because he's looking for factory 4.10s. I think I remember hearing some of those axles came with that gear ratio. But very rare. Correct me if I'm wrong.
Build
SAS
FOTM Oct. 2012
CWbronco is offline
post #5 of 16 (permalink) Old 07-22-2012, 09:05 PM Thread Starter
That's what my question is. Are there any f150's or broncos with factory 4.10 gears.
1980 Ford Bronco
302 V8
Automatic C6
NP208F
Wojo is offline
post #6 of 16 (permalink) Old 07-22-2012, 09:54 PM Thread Starter
The front diff im not worried about. Like i said. I can use the D50 front from a f250. The rear will be harder. Sounds like an 8.8 will be easier to find the 4.10s
1980 Ford Bronco
302 V8
Automatic C6
NP208F
Wojo is offline
post #7 of 16 (permalink) Old 07-22-2012, 10:01 PM
Steve83's Avatar
Did either of you look at the pics I posted?
post #8 of 16 (permalink) Old 07-22-2012, 10:19 PM
alaskan155's Avatar
Bronco Info: 1988 BRONCO 5.0/AOD axle code H5
not to rare,
look at smaller engine broncos/f150s the 5.0s/ 4.9ls
mine came factory with 4.10s....
88 Bronco(sold)
new trail rig
2000 ranger
4.0/5r55e/bw 4.10 gears 35 mt/rs
alaskan155 is offline
post #9 of 16 (permalink) Old 07-22-2012, 10:25 PM
Riggs's Avatar
Bronco Info: 91 Bronco 5.0 E40D and 4.10 gears
ya, they exist.
like Steves pic showed, code H5 if you are looking through junkyards.
4.10 rear, 4.09 in front is what I have.
91 Bronco 5.0 E4OD and 4.10 gears
"The trouble with quotes on the internet is that it's difficult to determine whether or not they are genuine." - Abraham Lincoln
Riggs is offline
post #10 of 16 (permalink) Old 07-22-2012, 11:08 PM
alaskan155's Avatar
Originally Posted by Riggs View Post
ya, they exist.
h5 is just a limited slip with 4.10s in the rear axle
Originally Posted by steve83
1st digit: A letter generally indicates a limited slip diff (H for 1/2-tons) or a heavy axle; 1 generally indicates a 1/2-ton axle with an open diff; 2 generally indicates a 3/4-ton open; 3 a 1-ton open. There are MANY exceptions.
2nd digit:
1 = 3.07 (heavy), 3.00 (light), 3.54, 3.07
2 = 2.73, 3.73 (early light), 3.50 (early heavy)
3 = 3.54 (late), 3.73 (early), 4.10, 4.11
4 = 3.00 or 3.73
5 = 4.10
6 = 3.55 (heavy) or 3.73 (medium)
7 = 2.47
8 = 3.08
9 = 3.55, 3.70 or 4.11 (early)
3rd digit: Any character (usually 2 or B) indicates a limited slip front axle (4WD)
8.8" axles under fullsize light trucks are rated at 3800 lbs or more.
so 15 or 19 would be acceptable, but always check tag on cover and stamping on ring gear
88 Bronco(sold)
new trail rig
2000 ranger
post #11 of 16 (permalink) Old 07-22-2012, 11:17 PM
Nothing beets a Fullsize
Kingfish999's Avatar
i know i couldnt find any 4.10 axles out of the 20 trucks i searched at the JY. 3.73 was closest ive seen and 3.55 is defiantly msot common. i couldnt even find a 4.10 Sterling axle (or at least a good condition one) and i had to use a D60 from a E-250 van. even using carpart.com the closest 4.10 8.8 axle to me was over 275 miles away
Kingfish999 is online now
post #12 of 16 (permalink) Old 07-23-2012, 02:35 AM
Steve83's Avatar
It ALSO indicates 4.09 in the front, if the truck is 4WD.
...19 would be acceptable...
4.11 isn't available in the 9" or 8.8"; that's a heavy axle ratio, so code 19 usually means 3.55 . If he gets axles from a truck with "1" in the first digit, he wants "5" in the 2nd.
post #13 of 16 (permalink) Old 07-23-2012, 02:36 AM Thread Starter
So it looks like there not TOOO hard to find. I live in montana and these trucks are a dime a dozen around here for farm trucks. Im sure ill find something. Just gotta get it for the right price.
1980 Ford Bronco
302 V8
Automatic C6
NP208F
Wojo is offline
post #14 of 16 (permalink) Old 07-23-2012, 02:43 AM
Bronco Info: 1995 F150 single cab, short bed 2wd with a 300/5spd 6" ProComp lift
Being a 1980, you should have a 9" rear. Just go find a 9" rear out of anything with 4.10s and pull the third member. Might have better luck looking under trucks from the 70s.
Friends don't let friends install TTB lifts.
gijoe4500 is offline
post #15 of 16 (permalink) Old 07-23-2012, 06:11 AM Thread Starter
Did ang rigs from the 70's have factory 4.10 gears
1980 Ford Bronco
302 V8
Automatic C6
NP208F
Wojo is offline
post #16 of 16 (permalink) Old 07-23-2012, 12:41 PM
Steve83's Avatar
Look in post #12.
