78 Fs frame ranger body swap - Ford Bronco Forum
post #1 of 15 (permalink) Old 09-23-2012, 07:28 PM Thread Starter
So I'm the proud new owner of a 78 FSB. I took it off roading for the first time up in Michigan. It performed very well except for the body mounts that were pretty much gone. The whole underside of the bronco shell is very rusty and structurally unstable, even to weld reinforcements on. So I was wondering, does anyone have any info/experience swapping a first or second gen. ranger body (83-92) onto a full size 78 bronco frame? Any information would be very helpful, thanks!
78'FSB is offline
post #2 of 15 (permalink) Old 09-23-2012, 08:19 PM
96XLTJD's Avatar
NO DONT DO IT.
96XLTJD is offline
post #3 of 15 (permalink) Old 09-23-2012, 08:24 PM Thread Starter
Why not?
78'FSB is offline
post #4 of 15 (permalink) Old 09-23-2012, 08:29 PM
Show us some pics.
You can cut and replace a lot of tin before throwing the body away.
66CC is offline
post #5 of 15 (permalink) Old 09-23-2012, 08:45 PM Thread Starter
If I had to, I could do a lot of welding and reinforce it, but I like the idea of tires sticking out more then that almost 7 foot wide body, I'm building for tighter trails and if my tires are going to hit before my body does, then I can maneuver that much easier. My plan is to actually cut the front of the ranger bed out and the back of the cab and weld it together to make my own mini-bronco. I'm looking for any info to see how it fits on the frame before I buy a ranger body
78'FSB is offline
post #6 of 15 (permalink) Old 09-23-2012, 08:55 PM Thread Starter
How do I post pics since I can't add attachments?
78'FSB is offline
post #7 of 15 (permalink) Old 09-23-2012, 09:02 PM
Resurection Ranch
379sinvb's Avatar
You're a noob so I'm going to take it easy well maybe.
Here is where you post questions:
http://www.fullsizebronco.com/forum/...splay.php?f=21
Here is how you post pictures:
How to POST PICTURES
Maybe search a little and read a little before we go giving us your 2 cents.
I have not seen the Ranger on 78 frame but there is one in the General Section.
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #8 of 15 (permalink) Old 09-23-2012, 11:57 PM
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
moved to correct forum....
Tim
Newest token Jeep owner....
Redwagon is online now
post #9 of 15 (permalink) Old 09-24-2012, 08:56 AM
Do a search for the user The Legend, he put a 80s Ranger body on his 77 frame. Its a pretty badass truck.
reptillikus is offline
post #10 of 15 (permalink) Old 10-08-2012, 03:16 PM
f150inline's Avatar
Bronco Info: 94 Bronco, 96 F150
Why a ranger body if you want to build a mini bronco? just use a bronco 2.
94 Bronco http://www.fullsizebronco.com/forum/...74#post5397874
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs.
f150inline is offline
post #11 of 15 (permalink) Old 11-13-2012, 02:50 PM
Bronco Info: 300 I6, 79 bronco Frame 84 F150 cab
Dont let them sway you, If its junk its junk. Mine was.....well, it might still be. But still.
I6 Bronco is offline
post #12 of 15 (permalink) Old 11-13-2012, 06:55 PM
Ford Hoarder
78-79FordMan's Avatar
Bronco Info: 7 of them 1978-79's and 1 of the 1991's and 1 of them 1986's
fix'en to do a '86 ranger on a '79 bronco frame. because the bronco is beat to crap rusted out . and has no title...
Ford It Man
78-79FordMan is offline
post #13 of 15 (permalink) Old 11-13-2012, 07:28 PM
Age. Fac ut gaudeam
Andrew James's Avatar
Put a Bronco 2 body on it.
2008 Jeep Liberty 3.7/42r
Andrew James is offline
post #14 of 15 (permalink) Old 11-13-2012, 07:32 PM
Bronco Info: 96 bronco all stock
the ranger body swap is not to bad at all we have done a couple of them the bronco 2 is alot shorter then the full size
bronco466 is offline
post #15 of 15 (permalink) Old 11-13-2012, 07:43 PM
Ford Hoarder
i scraped and sold all my bronco 2 .. and even my rangers 2 years ago .. so i bought the ranger for a $100 that i am going to use.. and i don't what to use a big heavy body .. as mine will only be using a gutted out body.. i probably want use the front clip .. i will be building something like Dooley's dodge on Mudstruck.com
Ford It Man
