460 in your bronco ... I dont get it - Ford Bronco Forum
post #1 of 80 (permalink) Old 11-04-2012, 09:55 PM Thread Starter
DirkDiggler's Avatar
Bronco Info: 79 Bronco. 4 inch lift, 37 inch H1 tires. Edy intake, 650 carb and new timing set ready to go in
So i have been reading a bunch about swaping a 460 into my bronco, and for the $ i dont get it. I am looking at picking up a JY 400m and rebuilding it this winter with edelbrock cleveland heads, intake, holly carb, cam, and some high comp pistons. I keep running he numbers and i see some great ability to make power from the 400 at about half the price of a 460 swap ... Am i missing somthing? What am i looking at wrong, because i know i cant be the first to raise that question.
DirkDiggler is offline
post #2 of 80 (permalink) Old 11-04-2012, 10:26 PM
not banned
no replacement for displacement.
i want to build a torque monster that will pull the mud out of a ditch... i have plans to swap in a 460, in place of my 351.
Where we go one, we go all.
Mickaila's Rebuild
mickaila is offline
post #3 of 80 (permalink) Old 11-04-2012, 10:26 PM
Robs79BBbronco's Avatar
What numbers?won't every swap be different? And just an FYI....cost me about $800 to swap mine in and that is including the motor!start looking at performance parts for your 400....you won't find that many compared to the 460.don't knock the 385 series until you've driven a bronco with one.
Sent from my XT603
Robs79BBbronco is offline
post #4 of 80 (permalink) Old 11-04-2012, 10:28 PM
lifeizhard102205's Avatar
put in a diesel if you really want a torque monster
lifeizhard102205 is offline
post #5 of 80 (permalink) Old 11-04-2012, 10:34 PM
not banned
i would, but there is a lot more to that then a simple gasser.
Mickaila's Rebuild
mickaila is offline
post #6 of 80 (permalink) Old 11-04-2012, 11:03 PM Thread Starter
Sent from my XT603
Ok now thats an answer. I was looking at threads saying it cost 4k to swap. I know a junk yard 460 can be had for super cheap. And i know there are a lot of things you need to make it work, but that gives me a lot of hope. So maybe the 460 isnt out. Just dont have a ton of experience so maybe thats my biggest issue. Thanks a 3/4 ton
post #7 of 80 (permalink) Old 11-04-2012, 11:47 PM
junkyard wise it's a cheap swap. Unless you are swapping in the fuel injection, then you might as well buy a parts truck. Just because most big junkyards want to charge for every little part.
GetBent4x4 is offline
post #8 of 80 (permalink) Old 11-04-2012, 11:49 PM
Nothing beets a Fullsize
Kingfish999's Avatar
on newer trucks it can cost more but every build is different as he said. if you wanted an EFI 460, rebuild it, mod it, it will add up. plus if you dont have a big block tranny then you have to get a new one. pick a used tranny and rebuild it. if you had to do driveshafts also for whatever reason, that adds up. all depends on the build
Kingfish999 is online now
post #9 of 80 (permalink) Old 11-05-2012, 07:55 AM
And if you want to spend a lot more money and add a bunch of weight.
Sent from my XT603
post #10 of 80 (permalink) Old 11-06-2012, 01:18 AM
Bronco Info: 79 EFI460,T18,ORD Doubler,Lincoln locked Sterling rear, Coil sprung D60 front, 4" lift on 37s
I swapped the 460 because it was cheaper than trying to fuel inject my 400. The added power was just a bonus.
Pedestrian is offline
post #11 of 80 (permalink) Old 11-06-2012, 01:25 AM
Try it now!!
kf4amu's Avatar
Sent from my XT603
Money yes, weight no. Couple hundred pounds is irrelevant. Just being fair here.
kf4amu is offline
post #12 of 80 (permalink) Old 11-06-2012, 03:43 AM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
Sent from my XT603
So what does the 460 have that the 400 does not have in the aftermarket? Excessively stroked cubic inches does not count.
Let's Go Fishing.
jopes is offline
post #13 of 80 (permalink) Old 11-06-2012, 04:09 AM
Sent from my XT603
money yes....
cummins 5.9 weight 1010lbs...
ford 460 weight....803lbs....
compare the torque numbers and you'll find a cummins will out pull a 460 even with the added weight. not to mention how many 460's can produce 800+hp and 2000+lb/ft of torque? there's a quite a few 5.9's that do. i'm not knocking a 460 swap. they're a good way to gain power for a low price. but for a true torque monster you can't beat a diesel.
post #14 of 80 (permalink) Old 11-06-2012, 06:15 AM
wilburbeest's Avatar
Bronco Info: 1989 Bronco Custom 4x4 w/300i6/M5OD
money yes....
This. If you want to talk about pure grunt it's pretty hard to compare near any gas engine to a cummins. And those which could be compared aren't likely to be near as reliable or have half the longevity. The only possible downside I see is weight distribution. I can totally understand doing a 460 for budget reasons though and no doubt it's still got massive torque.
wilburbeest is offline
post #15 of 80 (permalink) Old 11-07-2012, 11:51 PM
More heads,cams,intakes,stroker kits,etc.
Sent from my XT603
post #16 of 80 (permalink) Old 11-08-2012, 01:35 AM
rhauf's Avatar
my dream engine is a 460 stroked to a 545, built right with a roots blower and all the trimmings. 1,000 horsepower, 1,000 torque. oh yeah.
Im sure obama will make it illegal to drive on the street though.
-Ryan
rhauf is offline
post #17 of 80 (permalink) Old 11-08-2012, 03:46 AM
gone fish'n
jopes's Avatar
Sent from my XT603
20 years ago yes. Today... no.
Heads are all ovet now. Cams are a stupid thing to even bring up. And there is stroker kits nearing 500 cubes. So really there is nothing to say about lacking aftermarket parts.
Let's Go Fishing.
jopes is offline
post #18 of 80 (permalink) Old 11-08-2012, 09:30 AM
What about ease of EFI? Arent you guys running custom intakes to make the 400 EFI? Or has something hit the market now?
For the 70s trucks i can understand starting with a 400 but considering how easy it is to drop a 460 in an 80+ using 100% oem parts, it seems silly to me to spend the time to try to slap a 400 in one (yes i know the m blocks were still available in 80). My efi 460 swap cost me ~700 (including motor/trans)and used no aftermarket parts, except for the headers. Cant beat that.
For those arguing the available torque of a diesel, lets be honest here. The average person has no use for 1000 ft lbs, let alone 2k ft lbs. Unless youre racing, you just dont need that kind of power.
reptillikus is offline
post #19 of 80 (permalink) Old 11-08-2012, 10:24 AM
MudRider's Avatar
Bronco Info: 96 XL 302-K&N-3" magnaflow exhaust no cats-33s-locker front+rear-4.10s-E40D-custom bumper-SOFTTOPPER
isn't that the truth
SOLD 1996 Bronco, 302, lockers, geared, softtopper, leveled, 33s, restored body, lots of extras.
Current...2006 Chevrolet Duramax, Danville tuning, DHD built front end, other minor things...7200lbs 13.62@99, 1.8 60'
MudRider is offline
post #20 of 80 (permalink) Old 11-08-2012, 11:12 AM
maybe you're right.....but if you had xx amount of dollars to dump into either a 400 or a 460, it would be stupid to opt for the 400, everything else being equal.
