460 saginaw - Ford Bronco Forum
post #1 of 5 (permalink) Old 11-27-2012, 02:34 AM Thread Starter
Bronco Info: 79 EFI460,T18,ORD Doubler,Lincoln locked Sterling rear, Coil sprung D60 front, 4" lift on 37s
460 saginaw
I've been looking for a Saginaw bracket and pump for my 92 460. I found one from an 89 E250 van, does anyone know if this is correct for my application?
Pedestrian is offline
post #2 of 5 (permalink) Old 11-27-2012, 09:12 AM
Bronco Info: 1989 F350 XLT Lariat, 4x4, 7.5L SD, E4OD
Any van from 88-96/97 should have the right bracket. Make sure to grab the bolts for the A/C compressor while your there. Some drilling of the A/C compressor may be required.
-Travis
My Supermotor(What's left of it.)
SomeDude451 is offline
post #3 of 5 (permalink) Old 11-27-2012, 09:57 PM
Steve83's Avatar
There's a bracket for the EFI 4.9L; a different one for EFI smallblock V8s; another for the EFI bigblock 7.5L; and possibly another for diesel vans. Then there are several more for carb/V-belts. If the '89 is a serpentine EFI, it should fit a '92. This is the correct one:
post #4 of 5 (permalink) Old 11-27-2012, 10:02 PM
Yes, the '89 460 bracket will work on a '92 460.
BigWheelz is offline
post #5 of 5 (permalink) Old 11-29-2012, 12:22 AM Thread Starter
Thanks, I will go grab it this weekend. I'm tired of my Ford C2 announcing my presence to the rest of the group from 1/4 mile out. :(
