9 inch + 35s - Ford Bronco Forum
post #1 of 32 (permalink) Old 12-06-2012, 09:04 PM Thread Starter
9 inch + 35s
wasnt sure where to put this. ive acquired a 9 inch to replace my 8.8. id like to lock it and have been considering a spool or even lincoln locking it. its a 28 spline rear end and im currently running 35x12.50s (plan to for awhile too), how should it hold up? im not super hard on my truck but it definitely gets used
96 Eddie Bauer
SAS'd -Radius Arms/Coils/Panhard
D44/8.8/6ish inch lift /35' km1s
stevelknievel is offline
post #2 of 32 (permalink) Old 12-06-2012, 09:11 PM
JBfab's Avatar
Might hold up if you can keep your foot out of it. but you wont have a vss to control your speedo or abs. Also affects shift points in an automatic. There is a company that sells a vss relocation kit to move it to the rear output on the tcase but i belive its $300. So you have to ask if its worth it at that point.
JBfab is offline
post #3 of 32 (permalink) Old 12-06-2012, 09:15 PM Thread Starter
Sorry forgot to mention my vss has already been relocated as the 8.8 I had to hastily had to swap in during the summer had no vss
96 Eddie Bauer
post #4 of 32 (permalink) Old 12-06-2012, 09:33 PM
sackman9975's Avatar
If you drive it everyday, you won't like having the rear "locked".
sackman9975 is online now
post #5 of 32 (permalink) Old 12-06-2012, 09:36 PM
f150inline's Avatar
Bronco Info: 94 Bronco, 96 F150
go with a real locker locker for the rear if you drive it on the street like a detroit locker or a yukon grizzly locker.
94 Bronco http://www.fullsizebronco.com/forum/...74#post5397874
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs.
f150inline is offline
post #6 of 32 (permalink) Old 12-06-2012, 10:06 PM Thread Starter
I'm currently trying to get my hands on a second vehicle so the truck wouldn't be a main dd but if the budget allows I would prefer a real locker, main question is durability
96 Eddie Bauer
post #7 of 32 (permalink) Old 12-06-2012, 10:17 PM
ProBronco's Avatar
Bronco Info: 80 Bronco XLT 302 4sp, 4"lift on 35" Factory LS F&R
Like U can hurt it with your engine ?????
ProBronco is offline
post #8 of 32 (permalink) Old 12-06-2012, 10:20 PM
JBfab's Avatar
Id find a locker and some 31 splines. That would be much better then lincoln locking and 28's. if it was me id pull a pumpkin and axles from a yard with 31 splines. Did you use a relocation kit or use a transfer case with vss? Im curious because i swapped in an older tcase that has the vss in it and wondered what needed to be done if i went this route.
JBfab is offline
post #9 of 32 (permalink) Old 12-06-2012, 10:30 PM Thread Starter
That would be ideal if time/money allows otherwise i just toss it in as is. And I used a relocator kit to just move the vss
96 Eddie Bauer
post #10 of 32 (permalink) Old 12-06-2012, 11:14 PM
Bronco Info: 1974 Bronco with 351w, 1978 F150 4x4 with 1966 F100 cab
Your 8.8 in there is probably stronger than that 9 inch with 28 splines. Why do you want to change it? What did the 9" axle come out of?
bluebolt is offline
post #11 of 32 (permalink) Old 12-06-2012, 11:19 PM
ProBronco's Avatar
Um No!! Axle bearing suck on a 8.8.
Only down side is HIGH HP draw on the 9" and not rab compatible.....
8.8 is a MUSTANG rear MADE to fit a truck.
post #12 of 32 (permalink) Old 12-06-2012, 11:23 PM Thread Starter
9 inch is out of a older fsb so it's a easy swap and I like the idea of a removable 3rd member the extra strength and no c clips
96 Eddie Bauer
post #13 of 32 (permalink) Old 12-06-2012, 11:43 PM
Nothing beets a Fullsize
Kingfish999's Avatar
i always wondered that but ive heard that the signal is different. would be a nice alternative.
most mustangs/rangers use a 7.5" axle or a 28 spline 8.8. stock 31 spline 8.8 is stronger than stock 9". the aftermarket for the 9" is huge tho
Kingfish999 is online now
post #14 of 32 (permalink) Old 12-06-2012, 11:49 PM
ProBronco's Avatar
Really ?? are U a true Ford fan??
Boy I have owned many Mustangs and never found a 7.5 behind a V8 past 85................
Hell I have 03-04 Cobra 8.8 pumpkin center in the basement.......
The Stang Master
post #15 of 32 (permalink) Old 12-06-2012, 11:53 PM
Resurection Ranch
379sinvb's Avatar
I'm running 36" swampers 9" with a Detroit drive it on the street a lot and wheeled it hard with no issues of yet. broncograveyard is doing a 10% off special right now on items they sell. I bought my Detroit there and was about the cheapest anywhere.
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #16 of 32 (permalink) Old 12-07-2012, 12:00 AM
Robs79BBbronco's Avatar
Wouldn't really consider it an "upgrade".
Sent from my XT603
Robs79BBbronco is offline
post #17 of 32 (permalink) Old 12-07-2012, 12:02 AM
I admit the 8.8 axle bearings with C clips suck but a 31 spline 8.8 will be stonger than a 9 inch with 28 splines.
The more HP draw of a 9" is only something to worrry about if you need that last .02 second in a drag race.
And actually the 8.8 came out for 1983 trucks so it is a truck axle made to fit a Mustang.
bluebolt is offline
post #18 of 32 (permalink) Old 12-07-2012, 12:06 AM
Are you sure it's a 28 spline? I have pulled apart a lot of 1973 up truck axles and the only 28 spline ones I have seen are the 4.5" bolt pattern ones in early 80's F100's.
bluebolt is offline
post #19 of 32 (permalink) Old 12-07-2012, 12:11 AM Thread Starter
99% sure its a 28 spline
dont want to start a pissing match regarding strength or what came in what, but you also hit the nail on the head, ive got more options with a 9 inch than a 8.8
96 Eddie Bauer
post #20 of 32 (permalink) Old 12-07-2012, 12:24 AM
ProBronco's Avatar
U got me on that, my 98 F150 had the 8.8
So trucks have more torque and mustang have more hp. So how is it a bad rear ??? C clips maybe.....
Not sure on how splines have anything to do with it..................
