1991 bronco Dana 44 straight axel need help!!!! - Ford Bronco Forum
post #1 of 3 (permalink) Old 12-25-2012, 03:58 PM Thread Starter
Bronco Info: 1991 bronco xlt
Merry Christmas to every one. I have a 1991 bronco with a straight axel Dana 44 . The truck had a caliper crack so when I went to replace it I order the caliper for a 4x4 1991 bronco 5.8l and the calipers are not the same So I went back and returned them thinking they gave me the wrong ones but they were the right ones so now I am pissed off cause I can't figure out what's wrong and why my old calipers are different
b-rex90 is offline
post #2 of 3 (permalink) Old 12-25-2012, 04:14 PM
Driving Stuff Henry Built
El Kabong's Avatar
Merry Christmas to you too.
A straight axle isn't stock for a 1991. 1979 was the last year for solid axle Broncos. Your truck has had it's axle swapped from something else. It is an upgrade that rockcrawlers go to a lot of work to do. Check out the Solid Axle Swap forum here on FSB for info related to the changes. You'll have to find new parts to match your axle instead of the truck.
El Kabong is offline
post #3 of 3 (permalink) Old 12-25-2012, 06:41 PM Thread Starter
Thanks man will do and again merry Christmas
b-rex90 is offline
