1356 Tail housing - Ford Bronco Forum
post #1 of 24 (permalink) Old 01-25-2013, 07:23 PM Thread Starter
manchild's Avatar
Bronco Info: '91 Ford Bronco 351 V8 E40D Tranny D44 TTB 8.8 Rear Axle 4.56 Gears Front and Back 6in Lift w/35in
1356 Tail housing
I'm trying to figure out how to remove the tail housing for a 1356 t-case. I'm trying to figure out the count to the gear inside and see if its damaged.
manchild is offline
post #2 of 24 (permalink) Old 01-25-2013, 09:52 PM
JBfab's Avatar
Remove rear drive shaft. Remove the nut in the center of the drive flange. Remove the vss/speedo cable. Then remove the four torx head bolts and it should pop off with a little coaxing.
JBfab is offline
post #3 of 24 (permalink) Old 01-25-2013, 11:25 PM Thread Starter
manchild's Avatar
do i need to seal it back with permatex gasket and do i have to drain the t-case out? also, do i have to take the t-case off the bronco.
manchild is offline
post #4 of 24 (permalink) Old 01-25-2013, 11:50 PM
JBfab's Avatar
Yes i would reseal it with permatex lightly. No need to drain it as long as your not parked facing up a big hill. And aslo no need to remove the tcase i think. Let me ask you this, are you only taking the tail housing off to count the speedo gear teeth? Or are you looking to open up the whole tcase to have a look inside? Your first post is a little vaige so i figured only the tail housing. If your wanting to open the whole case more is involved.
JBfab is offline
post #5 of 24 (permalink) Old 01-26-2013, 12:32 AM
Chillin on the Gulf Coast
cajunrebel's Avatar
You can look through the hole for the VSS. Disconnect the driveshaft and put the TC in neutral and use a mirror to look through the hole as you spin the yoke. You should be able to see all of the teeth and if you mark one you can count them as well.
cajunrebel is offline
post #6 of 24 (permalink) Old 01-26-2013, 01:24 AM
Steve83's Avatar
You can't count the drive gear teeth since it's a spiral (worm-drive). Don't remove anything but the driven gear. All you need is the COLOR of the drive gear - that identifies its tooth-count.
post #7 of 24 (permalink) Old 01-26-2013, 09:56 AM Thread Starter
manchild's Avatar
i'm looking into taking of the tail housing.
manchild is offline
post #8 of 24 (permalink) Old 01-26-2013, 10:04 AM Thread Starter
manchild's Avatar
from reading other posts i figured its color coded but i just want to be on the safe side steve. i was talking to jim from http://www.transmissioncenter.net/sp...n_______va.htm and he was saying that there are so many after market products out there for these gears that it would be better to be on the safe side to count the teeth instead of going by color.
manchild is offline
post #9 of 24 (permalink) Old 01-26-2013, 03:00 PM
Steve83's Avatar
Well, you can count the spirals along the gear and that might be how that website IDs drive gears, but that number will be meaningless for gear ratio (the way most gearsets are IDed). To get the effective tooth count for the ratio, you'd have to wrap something around the drive gear & then count how many lands it crosses. But that would require removing either the gear or the tailhousing, which is pointless when it's color-coded.
post #10 of 24 (permalink) Old 01-26-2013, 04:35 PM Thread Starter
manchild's Avatar
Well...I just got back from the Hobby Shop( It' a place on the base where you can work on your vehicles) and could not get that nut off to get the tail housing off! I couldnt find the right socket metric and standard to save my life Even the Ford Master Tech that works there says those gears are color coded. Thanks for all the input fellas
manchild is offline
post #11 of 24 (permalink) Old 01-26-2013, 05:22 PM
Bronco Info: 1994 xlt THE MUSTARD MONSTER 9 inch coils shackle flip new e40d new bw1356 bm floor shifter Aussie
it is 1 or 1 1/16 i think. pb blast it! mine was a real bish to get off
bluelabel1927 is offline
post #12 of 24 (permalink) Old 01-26-2013, 08:42 PM Thread Starter
manchild's Avatar
tried the 1 1/16 and it wouldnt grip the nut. the one that almost worked was the 29mm thin wall socket. but they didnt have a 29mm six point thin wall socket.
manchild is offline
post #13 of 24 (permalink) Old 01-26-2013, 09:00 PM
desertdog's Avatar
Bronco Info: 89 351W rebuilt 55k miles, 3G swap, relocated TFI, cherry bomb exhaust, 6 inch pro comp lift' 33's
Just did mine, its a 32mm non impact socket for sure!
desertdog is offline
post #14 of 24 (permalink) Old 01-27-2013, 02:52 AM
Steve83's Avatar
The nut &/or the clearance around it MIGHT be different for yoke vs. companion flange. Which do you have?
post #15 of 24 (permalink) Old 01-27-2013, 11:51 AM
desertdog's Avatar
post #16 of 24 (permalink) Old 01-27-2013, 12:33 PM Thread Starter
manchild's Avatar
I have the companion flange
manchild is offline
post #17 of 24 (permalink) Old 01-29-2013, 03:36 PM Thread Starter
manchild's Avatar
Does anybody know the size of the nut to take the companion flange off the t-case?
manchild is offline
post #18 of 24 (permalink) Old 01-29-2013, 10:15 PM
Steve83's Avatar
My Snap-On chrome 1 1/4" barely fits in my '93 flange. A cheaper brand with a thinner wall should be easier, but cleaning the bore of the flange would help.
post #19 of 24 (permalink) Old 01-30-2013, 05:20 PM Thread Starter
manchild's Avatar
Does it matter if its six or twelve point. Also, do I need to buy new seals if I'm just removing the tailhousing.
manchild is offline
post #20 of 24 (permalink) Old 01-30-2013, 06:50 PM
JBfab's Avatar
No seal needed but for the $5 it costs for the output flange seal its good insurance.
JBfab is offline
