84 bronco horn doesnt work - Ford Bronco Forum
post #1 of 5 (permalink) Old 02-17-2013, 03:59 PM Thread Starter
Bronco Info: 1985 XLT, headers, 33's
Hi everyone, I have searched, traced wires and cant follow them completely, they seem to change colors which doesnt make sense.
I bought the truck, the horn pad on the stock wheel was missing, I but a new grant wheel on it with the installation kit hooked all the wires up correctly and my horn doesnt work, , didnt work before the grant wheel either(had a spare wheel that was in bad shape but come off of a bronce that the horn was working).
I traced the wires to the horn relay (under dash near cigarette lighter)
I have 12v to 1 or 2 terminals on the relay (cant remember), I dont get any power at the horn. Can anyone give me some ideas or have had this problem before (I checked the fuses too...)
I'm not a cracker, I'm a vanilla wafer!
Clint Baxley is offline
post #2 of 5 (permalink) Old 02-17-2013, 04:46 PM
war1ock's Avatar
Bronco Info: 1980 300 I6 4spd/1981 302 C6
find the horn and hook 2 jumper wires up to the 2 leads and see if the horn itself works. Then work your way back from there. I use my Power Probe for this but 2 jumper wires from a battery with do the same trick.
war1ock is offline
post #3 of 5 (permalink) Old 02-17-2013, 06:14 PM
thats what i would do then check to see if the horn button is closeing the circut when pushed
socaloffroader is offline
post #4 of 5 (permalink) Old 03-01-2013, 09:21 AM
Time for a train horn
You shouldnt let your girlfriend sign you up with mitchy as your user name...
i'll never let it go.
Mitchy7 is offline
post #5 of 5 (permalink) Old 03-03-2013, 11:58 AM
F.O.T.M. - MAY 2014!!!
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs Daystar leveling kit
My horn stopped working a while back. I thought it was just the horn, replaced and still nothing. Then I would get a beep every now and then.
After tinkering, I found the problem is on the steering column. Behind the wheel on the column there is a metal ring. For some reason the ring on my truck was not making full contact with the contact pad on the wheel.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options. 4.10 gears LSD 33" MTs First ever Stock Fullsize of the Month...
J A S N http://www.supermotors.net/registry/19528
fartman is offline
