1978 Bronco what size tires? - Ford Bronco Forum
post #1 of 24 (permalink) Old 02-17-2013, 10:10 PM Thread Starter
Here in a few months im going to buy a body lift. (i don't have cash for suspension and i just wanna lift the truck) I would like to put 35's on it. If I get a 3 inch body lift, will 35's work well? what about a 2 inch body lift? its got 31x10.5x15 on there right now, i bet i could fit 33's stock... but idk, what do you guys think?
78Bronkadonk is offline
post #2 of 24 (permalink) Old 02-17-2013, 11:43 PM
79BOSSHOGG's Avatar
Bronco Info: 1979 Ford Bronco Custom, 351m, c6 auto, np205 transfer case, 4" suspension lift, 35" tires
With a 3" body 35s will be pushing it. They will rub and you won't have much clearance. I have a 4" suspension on a 79 bronco and 35s look nice and have enough clearance. If all you can do is 3" body the max I'd do is 34s
[><]BOSS HOGG[><] NOT A CONCRETE QUEEN!!! GOTTA PAY TO PLAY!
79BOSSHOGG is offline
post #3 of 24 (permalink) Old 02-17-2013, 11:52 PM
Thanks 351w500
LarryP's Avatar
Wrong info there bud.
Nobody makes a 34 inch tire
35's fit with no rubbing on 78/79 broncos that's common knowledge here for the most part. with a 4 inch lift I was clearing 38's with no rubbing and I have flexy suspension. When my 78 was stock I wheeled the piss out of it weekly with 35's and never had a rubbing problem ever.
LarryP is offline
post #4 of 24 (permalink) Old 02-18-2013, 06:39 AM
OX1
OX1's Avatar
With stock suspension travel, 35's will fit no problem with 3" body lift. I have 35 BFG AT's, 2 inch front springs and it does not hit on the street even with a plow on the front.
Now if you go with a 35 X 14.5 bogger, it probably will hit, so you need to decide what tire you are talking about before anyone can truly answer the question.
OX1 is offline
post #5 of 24 (permalink) Old 02-18-2013, 07:43 AM
Raped Ape's Avatar
Bronco Info: 1991 Ford Bronco EB 5.0
When i had my 79 i had 37's stock. There wasnt much room at all in the wheel wells and it did rub at full turn. When i put the 3" BL it def made a diff in rubbing the fenders when wheeling. again it did rub the radius arms at full turn..
If you go to my thread there are pics to give you a better idea for room.
VOTE FOR ME FOTM! http://www.fullsizebronco.com/forum/...d.php?t=219679
1991 Ford bronco E.B. 5.0 V8 3" Suspension lift & 3" BL 1979 ford bronco 3" BL on 37x12.50x17 (sold)
Raped Ape is offline
post #6 of 24 (permalink) Old 02-18-2013, 10:40 AM Thread Starter
ok so ill probably go 2 inch body with 35's. the only problem is that i cant find 35x12.5x15 ANYWHERE.. think i found one tire but it was 250 a piece. is that normal? i payed 70 a piece for my 31x10.50x15's...
post #7 of 24 (permalink) Old 02-18-2013, 11:50 AM
Swampers come in 34 inch.
mrhp is offline
post #8 of 24 (permalink) Old 02-18-2013, 11:57 AM
f150inline's Avatar
Bronco Info: 94 Bronco, 96 F150
save up for the suspension lift it will be worth it in the end.
94 Bronco http://www.fullsizebronco.com/forum/...74#post5397874
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs.
f150inline is offline
post #9 of 24 (permalink) Old 02-18-2013, 12:14 PM
Bronco Info: looking to trade for chv or dodge NOT
craigslist always seeing cheap suspension lifts for solid axles
broncomine is offline
post #10 of 24 (permalink) Old 02-18-2013, 12:48 PM Thread Starter
true but i dont wanna worry about u joints and stuff as well.
post #11 of 24 (permalink) Old 02-18-2013, 02:03 PM
Thanks 351w500
LarryP's Avatar
why would you have to worry about U-joints?? If you do a lift right it all works.
LarryP is offline
post #12 of 24 (permalink) Old 02-18-2013, 03:15 PM
Bronco Info: 1974 Bronco with 351w, 1978 F150 4x4 with 1966 F100 cab
34's
It's not a common size but Interco has Super Swamper TrXux in a 34/12.50/15 but not cheap at over $300 each. They have a few others in a 34 but narrower.
bluebolt is offline
post #13 of 24 (permalink) Old 02-18-2013, 04:14 PM Thread Starter
I wanna get 35x12.50x15 but they are like 250 a piece. is that normal? or is that pretty high...
post #14 of 24 (permalink) Old 02-18-2013, 04:37 PM
Thanks 351w500
LarryP's Avatar
That's about the norm for new tires. Look on your local craigslist You can probably find a whole good set for $400 to $600
LarryP is offline
post #15 of 24 (permalink) Old 02-19-2013, 01:05 AM Thread Starter
ill take a look
post #16 of 24 (permalink) Old 02-19-2013, 01:26 AM
Ford Hoarder
78-79FordMan's Avatar
Bronco Info: 7 of them 1978-79's and 1 of the 1991's and 1 of them 1986's
Yap 35 no lift works ..
Sent from my iPhone 5 using Tapatalk 2
Ford It Man
78-79FordMan is offline
post #17 of 24 (permalink) Old 02-19-2013, 01:38 AM Thread Starter
alrighty then, cool. NOONE around me on craigslist has 35 inch tires for 15 inch rims, and tbh i dont wanna get bigger rims.. thanks for all the help everyone.
post #18 of 24 (permalink) Old 02-19-2013, 01:46 AM
Bronco Info: '96, 5.8, 4.56, 4", 35's, Thorleys, Warn 8274, 5100's, 160 3G, Sag, 10.25, E-fan, Projectors, 8-Lug
Yeah, I see 35's on Craigslist here all day long for $500 with like 85-90% tread on them. There is a guy right now selling 37x12.50x17's Pro Comp A/t's with decent tread for $250 and another guy selling almost new 37x12.50x17 TSL's for $700....bad crab is miserable I had that once sucked bad! -Kevin-
http://sacramento.craigslist.org/pts/3627025480.html
http://sacramento.craigslist.org/pts/3621792181.html
DON'T GIVE UP PUSH THE PEDAL ON THE RIGHT JUST A LITTLE BIT HARDER DNBELOWBRONCO www.supermotors.net/17883
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind" -Dr. Seuss-
DNBELOWBRONCO is offline
post #19 of 24 (permalink) Old 02-19-2013, 01:47 AM
Where are you?
post #20 of 24 (permalink) Old 02-19-2013, 09:34 AM Thread Starter
Originally Posted by DNBELOWBRONCO View Post
Where are you?
in the fayetteville Arkansas area.. looking for 35x12.50x15, gotta be 15 inch rim
