351 swap to 300-6? - Ford Bronco Forum
post #1 of 66 (permalink) Old 02-09-2005, 01:14 AM Thread Starter
Reverend Trick Playa
Dawg Bones's Avatar
Bronco Info: No Mo Bronco
Question 351 swap to 300-6?
I saw a 300 6 cyl in a junkyard this weekend and could get it really cheap..plus it ran. It's out of a 86. I have a 79. Anybody done that? If so, any advice about do's and don'ts?
Dawg Bones is offline
post #2 of 66 (permalink) Old 02-09-2005, 01:58 AM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
stick with the M block they are better suited for the heavier broncos.
Let's Go Fishing.
jopes is online now
post #3 of 66 (permalink) Old 02-09-2005, 02:04 AM
MikE2's Avatar
Different tranny too
MikE2 is offline
post #4 of 66 (permalink) Old 02-09-2005, 11:28 AM
aka: kemicalburns
TravisITGuy's Avatar
your asking for a lot of work to swap to that motor.
TravisITGuy is offline
post #5 of 66 (permalink) Old 02-09-2005, 03:38 PM
Stuck like a MoFo
85f150's Avatar
Bronco Info: Srry no Bronk only a F150
well if you want to swap the motor you need, a diff radiator, motor mount towers, different tranny if auto - if stick just a different bellhousing, i would also get rid of the feedback system on the 86 and swap it to duraspark.... Which you will already have on your existing 79 and would only need a dizzy and carb. Not a bad swap if you really want it or want something unique. Could install a turbo on it to have a little more fun
Truck Porn mooseracing.org
1985 F150 300 cubic inches of raw tq
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline
post #6 of 66 (permalink) Old 02-09-2005, 07:18 PM
Harmful if swallowed
Agily00's Avatar
Why would you swap a 8 for a 6 anyway, thats backpedaling
Agily00 is offline
post #7 of 66 (permalink) Old 02-09-2005, 07:40 PM
Stuck like a MoFo
85f150's Avatar
six is alot better than a 302 and stock six has the same amount of torque as a 351w. There weak spot is in the head design as they can't flow above 3k. They are easy to wake up and are just like setting up a diesel, if i had more cash i would have the turbo on mine but right now i don't have the tools to modify my manifold the way i want and definately can't afford a custom one.....
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline
post #8 of 66 (permalink) Old 02-09-2005, 10:06 PM
MikE2's Avatar
A 300 never had the same ammount of torque as a 351. Usually the 302 even has 10 more ft lbs in stock form and a broader power band too
MikE2 is offline
post #9 of 66 (permalink) Old 02-10-2005, 01:02 AM
Optika1 illushun's Avatar
Bronco Info: 1993 F-150 XLT 4x4 300/E4OD
ur wrong there buddy, the 300 in the early to mid 80s had more torque and hp than a 302 and was knocking on the door of the 351. plus the 6 is bullet proof, can be easily modded and can definatly kick some bent-8s asses. ill take a 300 over a 302 and day and probaly a 351...
looks like we need to team up 85f150 against all the 6 haters =-D
1993 F-150 XLT 4x4
-300/E4OD/SA D44/8.8/BW1356
1988 F-350 Custom 4x4
-7.3IDI/ZF/D60/10.25/BW1356
Optika1 illushun is offline
post #10 of 66 (permalink) Old 02-10-2005, 01:50 AM
MikE2's Avatar
Well let me dig the books out..........
1980
300 = 243 ft lbs @ 1200
302 = 239 ft lbs @ 1800
351M = 263 ft lbs @ 2000
351W = 266 ft lbs @ 1200
1981
300 = 255 ft lbs @ 1400
302 = 233 ft lbs @ 2000
351 = 268 ft lbs @ 1200
1982
300 = 253 ft lbs @ 1200
302 = 232 ft lbs @ 1800
351 = 269 ft lbs @ 1200
1983
300 = 250 ft lbs @ 1600
302 = 250 ft lbs @ 2000
351 = 278 ft lbs @ 1400
1984
302 = 250 ft lbs @ 2200
351 2 bbl = 280 ft lbs @ 1800
351 4 bbl = 305 ft lbs @ 2800
1985
1986
300 = 260 ft lbs @ 2000
302 = 270 ft lbs @ 2400
351 = 295 ft lbs @ 2600
1987
1988
351 = 315 ft lbs @ 2800
1989
1990
1991
1992
351 = 310 ft lbs @ 2800
1993
1994
1995
302 = 275 ft lbs @ 2400
351 = 325 ft lbs @ 2800
1996
So according to my books, the 300 does make more torque than the 302 up untill 1983 where they make the same ammount untill 1985. Then from 1986 on the 302 makes 10 to 15 ft lbs more than the 300 does.
And it makes more torque at a higher RPM where the 300 cant even rev too.
So what I said before:
Is right. The 300 never made as much torque as a 351, and the 302 usually makes 10 ft lbs more than the 300 (it did for 11 years)
MikE2 is offline
post #11 of 66 (permalink) Old 02-10-2005, 01:56 AM
ok so u proved my point...the 300 is a better engine than a 302 anyway u look at it. IMO and many others, its the best truck engine ford EVER made.
1993 F-150 XLT 4x4
post #12 of 66 (permalink) Old 02-10-2005, 02:00 AM
MikE2's Avatar
So now I'm a 6 hater?
I always liked the 300. Its a very reliable and durable engine. but it doesn't make more torque than a 351
MikE2 is offline
post #13 of 66 (permalink) Old 02-10-2005, 02:01 AM
MikE2's Avatar
My 302 can beat up your 300
MikE2 is offline
post #14 of 66 (permalink) Old 02-10-2005, 02:14 AM
MikE2's Avatar
does that "hp" stand for hrsepower?
the 300 never mad more horse power than the 302
Dont make me type all the horsepower specs in too
and don't hate me because I have V8s
The only 6 I drive is a Cummins
MikE2 is offline
post #15 of 66 (permalink) Old 02-10-2005, 06:45 AM
$13,000 FSB, Never Driven
DirtyDeedz's Avatar
Bronco Info: 1986 Ford Bronco XLT 466CID MSD Holley Ford Racing
this is like NASCAR...
its slower and only makes left turns
Keep'n It Real Since '78
DirtyDeedz is offline
post #16 of 66 (permalink) Old 02-10-2005, 05:29 PM
Head's Avatar
Bronco Info: 94 xlt,302,e4od,6" lift,35" swampers,Aussie locked
IMHO you couldn't beat the 300 with a 4 speed. Had that combo in my 90. Blew the 302 I have now out of the water.
Head is offline
post #17 of 66 (permalink) Old 02-10-2005, 05:32 PM
its all good, ill take my tractor like 300 over any bent 8.
and mike2, u can kiss meh ass! :-p
1993 F-150 XLT 4x4
post #18 of 66 (permalink) Old 02-10-2005, 11:28 PM
MikE2's Avatar
I'll put my stock 302 and $1000 up against your 300....but since your all the way across the country I dont think its possible
MikE2 is offline
post #19 of 66 (permalink) Old 02-10-2005, 11:30 PM
doing what? id be game for everything except a 1/4.
1993 F-150 XLT 4x4
post #20 of 66 (permalink) Old 02-10-2005, 11:50 PM
MikE2's Avatar
truck pullin...or sled pullin - whatever you call it back there
First one this year on my usual circuit is April 17
MikE2 is offline
