Straight 6 vs. 351 Windsor V8? - Ford Bronco Forum
post #1 of 12 (permalink) Old 04-01-2005, 12:53 PM Thread Starter
Hey, I was just wondering what some of your guys' oppinions are on a Straight Six or the 351 Windsor, such as which do you prefer and what you like about them and so on.
The problem I'm having is I have a 351 but when I go off road it tends to over heat more readily then most other engines, yeah I could put an electric fan in and so on but the straight 6 seems like the better option right now, if you didnt read my last posting I was switching from an auto tranny to a manny tranny, but the truck that had the manny tranny had been rolled so the body was shot but mechanically it was better then my truck(with the auto) once I got to the swapping step of the project the manny tranny had issues I had un-forseen,mounting brackects were broken and had been bolted down "Customly" (who-ever did it had no clue what they were doing) so in the end I had to do a body swap, my body from the running truck onto the frame of the rolled truck. In my current truck was the 351 and now I will have the straight six after the body swap is complete. So I was wondering if any one thought swapping the engines (which would create alot more work and possibly unforseen hassels) is worth it or not? any and all oppinions are welcome, thanks.
1981 Ford Bronco
Straight Six
Stock Suspension
3 Spd OD Tranny
38x15.50 Nitto Mud Grapplers
bronco_boy is offline
post #2 of 12 (permalink) Old 04-01-2005, 01:10 PM
Owned 20 Years
The 6 is a nice, reliable, low end torque, long-lasting motor. So I would not trade one. The 351 overall I would prefer (but I'm biased here). It should not be overheating, they don't have issues with this with a properly set up cooling system. Would I go to the hassle of swapping one for the other, probably not.
post #3 of 12 (permalink) Old 04-01-2005, 01:31 PM
Stuck like a MoFo
85f150's Avatar
Bronco Info: Srry no Bronk only a F150
It starts all over again....If ya search in the anything else or general pics forum there was a nice poll started with a bunch of info on the motors available in bko's....Long live the six
Truck Porn mooseracing.org
1985 F150 300 cubic inches of raw tq
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline
post #4 of 12 (permalink) Old 04-01-2005, 02:13 PM
TTB Hater of course
The problem I'm having is I have a 351 but when I go off road it tends to over heat more readily then most other engines, yeah I could put an electric fan in and so on but the straight 6 seems like the better option right now,.
We also have a broncoboy, also from BC. That's gonna get confusing.
Anyhow, if you're avoiding the 351 'cause you think it runs hot, you're on the wrong track. As a general rule Ford overbuilt their cooling systems, a/c systems and even heaters (so the entire HVAC). In the summer the a/c will freeze us out (still good ol' R12, knock on wood) and in the winter the heater forces us to crack the windows.
My '90 351 will run at 205 degrees all day long crawling in the heat with the a/c on. That's with a stock radiator with 195k miles on it and a slight leak where the plastic tank is starting to separate.
Ever heard the expression "cold blooded Ford?" It's quite common, and you'll find many Ford trucks dont' warm up very quickly in the winter.
Anyhow, I'm not gonna debate 351 vs 300 as they're both great motors, but if you want to swap a 300 in place of a 351 because of overheating issues you're not looking for the real problem and it's like killing a housefly w a sledge hammer.
Totally Twisted and Broke makes me a saaaad Panda
"You can almost see the dismay on Phil, Paul & Bob's faces when Trautwig is talking....and the pause in their voices after he stops....after which they pick-up the pieces of his non-sensical commentary and continue with their telling of the story that is the Tour de France! "
TTBlows is offline
post #5 of 12 (permalink) Old 04-01-2005, 02:18 PM Thread Starter
I'm not swapping the motors, I am half way through doing a body swap with the body of my current bronco that has the 351 to a rolled bronco that has a straight 6. The over heating isnt what really bothers me, I love my 351 its a great motor I think, its just is it worth swapping the motor over too with the body? do you prefer the 351 or the straight 6?
1981 Ford Bronco
Straight Six
Stock Suspension
3 Spd OD Tranny
post #6 of 12 (permalink) Old 04-01-2005, 05:11 PM
Mr. Asks Alot
rsm688's Avatar
Bronco Info: 78' Bronco
with gas prices at what they are now and will be in 6 months....i would take that 6 in a heartbeat and its got a lot of low end torque
~spencer~
78 Bronco:
SUPERMOTOR PICS
SOLD....well traded, to a dealership for $7000
rsm688 is offline
post #7 of 12 (permalink) Old 04-01-2005, 05:33 PM
Owned 20 Years
Yep, manuf. better start re-thinking all the mosta trucks they are producing, diesel included. That crap is more expensive than premium around here.
post #8 of 12 (permalink) Old 04-01-2005, 08:48 PM
4sd4d's Avatar
Bronco Info: Stole Potamus's old FSB. I own a BKO that was made the same month and year I was born
I am currently thinking of installing a smaller radiator in my car because it gets way too cold. In the dead of winter with cardboard over my whole radiator my car would only get up to 175*. That is with a 195* thermostat in my car too.
Most Fords that I have experience with run cooler than I would prefer.
-1978 Bronco w/mild 351M
-1990 Mustang w/2.3 Turbo and 5 gears
-1991 Thunderbird w/5.0HO
LIFE IS GOOD!
4sd4d is offline
post #9 of 12 (permalink) Old 04-02-2005, 12:42 PM
Optika1 illushun's Avatar
Bronco Info: 1993 F-150 XLT 4x4 300/E4OD
^---aint that the truth...
1993 F-150 XLT 4x4
-300/E4OD/SA D44/8.8/BW1356
1988 F-350 Custom 4x4
-7.3IDI/ZF/D60/10.25/BW1356
Optika1 illushun is offline
post #10 of 12 (permalink) Old 04-02-2005, 01:00 PM
Wil
Wil's Avatar
Bronco Info: 1982 Ford Bronco Full Size. 300 cid 6 cyl. 4 spd tranny, no lift (yet) with 31x10.5 15's on 7x15
Both my E-150 and my Bronco have straight six's and I love them. They're low maintainance and good on gas mileage. Don't get me wrong a 351 is more powerful and sounds cool, but I don't think I'd trade the 6 for one. As for temp, the Bronco is ALWAYS right in between the O and the R in NORMAL. The E-150 has a wierdness in it's electrics... if you turn the headlights on, the gas, temp, and amp guages all go up
Wil is offline
post #11 of 12 (permalink) Old 04-03-2005, 10:58 AM
piney fab's Avatar
Bronco Info: 85 Bronco
I noticed my 351w before a rebuild would over haet all the time. I found two problems and cured it! Now I can run 3200rpm all day in the summer with out a miss.
Problem #1 My timing was out. I kept tuning by ear... not the way. Get a light and see whats going on. For me it was a strecthed timing chain.
Problem #2 after the engine rebuild, I forgot to purge my cooling system and just kept filling the radiator with fluid. This ruined my cap by over working it. put a new cap on and purged the system with the prestone kit and voila! no more overheating
piney fab is offline
post #12 of 12 (permalink) Old 04-03-2005, 04:31 PM Thread Starter
Perfect, I'll check that out, thanks for the tip
1981 Ford Bronco
Straight Six
Stock Suspension
3 Spd OD Tranny
