E4OD will only go into 1st and 2nd gear help ASAP - Ford Bronco Forum
post #1 of 9 (permalink) Old 06-11-2005, 11:41 PM Thread Starter
AndyBronco's Avatar
Bronco Info: 1995 white sport 32x11.5 MT/R's,rancho shocks,dustins rock sliders,4.10 gears and lockers
Well heres the story i was stuck in a mud hole gave it a little gas noticed the RPMS go to like 3000 before it went anywhere and thought nothing of it at the time. well on the wayback from the cliffs my truck wont shift out of second. first and second gear work fine. when i let off the gas it feels like it shifts into neutral. and ideas whats causing the problem? i need the rest of the gears to work by monday so i can go to work.
daily driver:06 midnight blue jeep liberty CRD sport.
mods: rock rails All J interior rack, All J tansmission skid, stock engine, transfercase and a kilby gas tank skid. still 24mpg around town
AndyBronco is offline
post #2 of 9 (permalink) Old 06-11-2005, 11:47 PM
Ogeechee 4x4's Avatar
Bronco Info: '95 Bronco, 351W, NP435/205, Solid D44 front, 35" MTR's, 3.55 gears
did you check the fluid level? Even 1/2 qt. will make a difference in how an auto tranny shifts...
My SuperFord
'95 Eddie Bauer-- 351W, NP435/205, D44 SAS
Ogeechee 4x4 is offline
post #3 of 9 (permalink) Old 06-11-2005, 11:49 PM
Engineer
ToddACimer's Avatar
Bronco Info: 95 Eddie Bauer
Your truck got owned... and I got pics to prove it. Yet another awesome wheeling day
ToddACimer is offline
post #4 of 9 (permalink) Old 06-11-2005, 11:51 PM Thread Starter
AndyBronco's Avatar
ya I did it was low after i left filled it back up and it still does it. Im gonna try some transtune from seafoam and get it flushed on monday. I just hope this isnt a bigger problem
post #5 of 9 (permalink) Old 06-12-2005, 12:18 AM
Engineer
ToddACimer's Avatar
I think you lost your tranny minutes before this pic was taken
FYI the water is following his ass out the door and here's why
post #6 of 9 (permalink) Old 06-12-2005, 09:10 PM
Bitchin.
84x4bronco's Avatar
Bronco Info: 84 bronco 351W, C6, 79 D44, 9", Twinstick 205
transmission shift modulator? or are thos eonly and C4's and such....
84x4bronco is offline
post #7 of 9 (permalink) Old 06-13-2005, 10:40 PM
Engineer
ToddACimer's Avatar
help?
post #8 of 9 (permalink) Old 08-22-2005, 12:21 AM
Bronco_In_Ny's Avatar
Bronco Info: 90 bronco 392 stroker motor, 80mm Pro-M MassAir conversion, edlebrock upper and lower intake manifol
OK try and check the Harness on the Passengers side, thats the Harness that controls shifting, if its not sealed well and you get water in there its going to cause Probs. I had this happen to me after some Deep mud holes and after cleaning out the harness and using Electric grease it went away. Question, Is your OD light blinking when it Happens? If so pull your Wiring harness off your Computer and look for water inside of there. I think but might be wrong but the grounding plugs are on the far left of the harness and Pin number 49 (I think controls your Converter lockup) I was having some big probs with mine Dropping out of 3rd and Over Drive and thats what it was a Bad Wire in the Harness. Hope it Helps Ohh and I've found it wise to add Electric grease to any and all harness plugs.
Hey Stang I lived in Lima Ny for abit and was a member of Team Mud Nuts, if your not a member you might want to look them Up if you want I can give you there website, they meet at Gander Mt each Month.
90 fullsize bronco
6in ProComp lift stage2 in front
4.5in superlift springs w/2in blocks
351w stroked to 392
Roush Racing heads w/stage2 porting
80mm ProM MassAir Conversion
MSD igntion sys (Complete)
Gibson headers W/true dual exhaust
Edelbrock Upper and lower intake manifolds
BBK 56mm Throttle body
200amp alternator
Auburn ECTED locker in the rear
35in Thornbirds
Super Motors Garage
Bronco_In_Ny is offline
post #9 of 9 (permalink) Old 08-22-2005, 11:32 AM
sprky's Avatar
Bronco Info: 95 Bronco, SAS, 37'' Tire
i had the same prob after i sucked water in it. the solinoid pack was bad. i drove it for a little while and it started working again. but i changed the trans out not long after that
Tim
President-Wisconsin Off Road, Inc
95 xlt d44 sas 8.8 4.88 ectd sleeved axle tubes
37" mtr's beefed e4od
sprky is offline
