Heater Hi not Full Fan Speed - Ford Bronco Forum
post #1 of 9 (permalink) Old 10-16-2016, 05:12 PM Thread Starter
biggum's Avatar
Bronco Info: 1986 XLT 351HO and 1985 base 302FI
Howdy all, searched a bunch and found tons on the resistor but I've got a different issue and the -20 is on its way!
86 XLT with air.
I get low, m1 and m2 but when switching to high the fan speed drops down.
I've replaced the resistor. I get full fan when direct from battery to fan plug. I get full fan when jumping the resistor connectors to the ground resistor connectors.
I assume I am not getting full voltage to the fan when the switch is on high. I understand that the high setting bypasses the resistor. I'm not sure of what is between the dash switch and the fan, I assume there must be a relay somewhere and not 10g wire from the bat to switch to fan.
Ideas and experience?
Thanks!
biggum is offline
post #2 of 9 (permalink) Old 10-16-2016, 05:35 PM
Bronco Info: 1996 XL 5.0L e4od
Has happened to me before, but in an Explorer. The easiest solution for me was to replace the blower motor.
hms79 is offline
post #3 of 9 (permalink) Old 10-16-2016, 05:57 PM Thread Starter
biggum's Avatar
Thanks hms but the blower motor works 100% when full 12v is applied. Has to be somewhere between the motor switch battery
biggum is offline
post #4 of 9 (permalink) Old 10-16-2016, 06:04 PM
Well, that's good. Is it a replacement motor? I have found them to be cheap poo! Any how, that was my experience. I'm not much on electrical stuff.
hms79 is offline
post #5 of 9 (permalink) Old 10-16-2016, 06:46 PM Thread Starter
biggum's Avatar
It's a motorcraft blower so I think it's original
biggum is offline
post #6 of 9 (permalink) Old 10-17-2016, 01:45 PM
Yo biggum,
Bad brain day now.. so reading all this and responses have me in stupor.
So blower motor is ok.
Ok, that section of wiring is ok as well as the ground.
The high speed setting bypasses the blower motor resistor pack (see the diagram below). There is no relay.
Check switch connector and blower motor connectors for corrosion, etc.
Some are known to overheat and melt the plastic housing.
Wiring Diagram in an 86 Bronco & F-Series
miesk5 is online now
post #7 of 9 (permalink) Old 10-17-2016, 03:19 PM
jjandascog's Avatar
Bronco Info: 1988 Full Size with 5.0, AOD, manual transfer case
What miesk5 said
1988 Full Size Bronco, 5.0, AOD, Manual transfer case
jjandascog is offline
post #8 of 9 (permalink) Old 10-17-2016, 07:54 PM Thread Starter
biggum's Avatar
Thanks guys, I'm leaning towards the switch being bad or possibly a ground issue.
biggum is offline
post #9 of 9 (permalink) Old 03-20-2017, 05:43 PM Thread Starter
biggum's Avatar
To close this out.....the dash switch was bad - partially melted. Put in a new switch and works great. Did a little research and apparently melted heater fan switch is fairly common Ford issue. Cheers
biggum is offline
