15x10 Ride Height - Ford Bronco Forum
  • 1 Post By racerx72
post #1 of 11 (permalink) Old 01-09-2017, 07:21 PM Thread Starter
JCG74's Avatar
Bronco Info: 89' EB Bronco 351W C6T BW1356TC TTB44 w/E-Locker 9" w/Detroit Locker 35" GoodYear MT/R Warn 12,000W
15x10 Ride Height
Probably another stupid question and afterthought, for which I can't seem to find an answer. My 89' is currently sitting on new GY Wrangler MT/R 35x12.5x15R with 15x8 rims. With a level on top of tread & aired up to 35 psi, tires stand exactly 34.5" tall.
I recently ordered some Allied Rockathon Beadlocks in 15x10 with 3.75 backspacing. Can anyone tell me how much shorter, if any, I can expect my tires to stand when mounted on these rims? Also, any photos floating around out there of this size rim on FSB's? Thanks!
JCG74 is offline
post #2 of 11 (permalink) Old 01-09-2017, 07:39 PM
RAMPNT1's Avatar
That is the exact wheel I bought for my 78 but I'm running 33x12.50x15 BFG KO's so I can't help with ride height but you can see what they look like installed.
BTW no local tire shops would mount and balance them for me. I ended up using dynabeads and mounted them myself. It worked well.
Jim
RAMPNT1 is offline
post #3 of 11 (permalink) Old 01-09-2017, 07:42 PM
MidlifeCrisisUndrWay
CDA 455's Avatar
The short answer: Not enough difference for you to care.
The long answer: Maybe .5"+/- shorter due to spreading the tire out; Maybe.
Are your Goodyears 'D' or 'E' rated tires? Or rather; What's the max inflation for said tires? 35PSI sounds like max PSI unless it's rated for 45PSI.
FWIW; I inflate my tires so that there's an even footprint across the entire tread. I don't go by PSI because the tires I use are rated for a full size truck with a max load heavier than what I can carry.
μολὼν λαβέ
CDA 455 is offline
post #4 of 11 (permalink) Old 01-09-2017, 07:45 PM Thread Starter
JCG74's Avatar
Thanks. Look good. Fortunately I have a shop nearby which will actually do it all for me.
JCG74 is offline
post #5 of 11 (permalink) Old 01-09-2017, 07:51 PM Thread Starter
JCG74's Avatar
Thx CDA. I do likewise on the pressure. They're rated C for load range with 35 psi max. I aired one all the way up just to measure height.
JCG74 is offline
post #6 of 11 (permalink) Old 01-09-2017, 08:36 PM
Harley's & Bronco's FTW!
I got pics of 15x10's but like RAMPNT, there only on 33's.
I'd post pics of my '95... but I'm honestly not sure if they're 8 or 10 wide, as PO set it up.
BikerPepe` is online now
post #7 of 11 (permalink) Old 01-10-2017, 07:29 AM
racerx72's Avatar
Bronco Info: 3rd gen 83 w/302 - 3"body lift 35x12.50
Here's mine with 35 x 12.50 r15 on 10" wide rims. I also run 1.25" wheel spacers to get the tires out to the edge of the fender flares.
CDA 455 likes this.
racerx72 is offline
post #8 of 11 (permalink) Old 01-10-2017, 11:23 AM
I ran 37" and 35" tires on 15x10s on a 6" and 4" lift respectively. Can't remember the back space.
35s and 4"
35s and 6"
And finally the 37s and 6" lift
I went to 16x10" wheels on my 85, so I could get some 10 ply swampers. I kept wearing the 6 plys out too fast.
BigBlue 94 is online now
post #9 of 11 (permalink) Old 01-10-2017, 08:42 PM Thread Starter
JCG74's Avatar
Good looking rides guys! Thanks for the input.
JCG74 is offline
post #10 of 11 (permalink) Old 01-10-2017, 09:30 PM Thread Starter
JCG74's Avatar
Just curious Blue...Are you running the 44 TTB with those 37"s?
JCG74 is offline
post #11 of 11 (permalink) Old 01-11-2017, 09:28 AM
I was on that Bronco, with 300+HP and 450+ft/lbs and 4.88 gears.
My 85 is running 37s now on the ttb, with 200hp and 400 ft/lbs (inline six) and 4.56 gears with a trutrac Detroit in the front and a Detroit locker in the rear.
I don't "wheel" my broncos, but ol blue had been jumped numerous times, at highway speeds, without a problem. I've had them in holes, ditches, creeks, and any other environment on the way to fishing, camping, or hunting and trapping. Never had a problem with the axles.
