Spindle removal tool for 78 D44 - Ford Bronco Forum
 2Likes
  • 1 Post By Dman94X
  • 1 Post By RacersJunkyard
post #1 of 8 (permalink) Old 02-15-2017, 03:00 PM Thread Starter
RacersJunkyard's Avatar
Bronco Info: 1991 Bronco XLT
Hi all,
I've been lucky enough to purchase a solid D44 front from a 78 Bronco for an SAS conversion on my 91.
I'm searching for a spindle removal tool that can attach to a slide hammer similar to the service tool you can rent from a pep boys or autozone. So far I'm coming up short.
I'm aware of the BFH and block of wood method but that doesn't seem to be working. So does anyone know where I can find something like that tool anywhere? Or am I stuck with a BFH?
RacersJunkyard is offline
post #2 of 8 (permalink) Old 02-15-2017, 03:35 PM
sackman9975's Avatar
I use a 3 or 4 in wide brick chisel and a 4 lb hammer. Can get the chisel at Lowes or Home Depot and it doesn't take up too much room in the tool box.
Put the chisel at the base of the spindle where it meets the knuckle and hit it with the BFH. Works every time for me with no thread damage....
sackman9975 is online now
post #3 of 8 (permalink) Old 02-15-2017, 03:41 PM
Owned 21 Years
Originally Posted by RacersJunkyard View Post
Hi all,
It's just a big socket...on the bottom it screws into the end of the slider hammer and on the "socket side" it's threaded to go right on the end of the spindle.
post #4 of 8 (permalink) Old 02-15-2017, 04:16 PM
I bought one on Amazon. One size fits most D44, D50, D60...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
dash_cam likes this.
Dman94X is offline
post #5 of 8 (permalink) Old 02-15-2017, 05:10 PM
dash_cam's Avatar
That's exactly what he needs
it's fun to do bad things
my "build" thread
dash_cam is offline
post #6 of 8 (permalink) Old 02-15-2017, 06:10 PM
They work great, even pulled off a D60 spindle that had been sitting in water. I ended up breaking the slide hammer in pieces (had to use a 5lb sledge hammer on the slide hammer slide to make any progress) but the spindle eventually came off unharmed.
Dman94X is offline
post #7 of 8 (permalink) Old 02-15-2017, 09:10 PM
norm's Avatar
Bronco Info: 79 V8 C6/205
I've got this one-
https://www.summitracing.com/parts/otc-7502
basically the same as above, works on 1/2 ton stuff and 60's
.http://www.fullsizebronco.com/forum/image.php?type=sigpic&userid=26328&dateline=121233  5329
norm is offline
post #8 of 8 (permalink) Old 02-15-2017, 10:40 PM Thread Starter
BOOYA!
Thanks guys
Dman94X likes this.
