trail riding and sway bars - Ford Bronco Forum
 20Likes
  • 1 Post By My Little Mule
  • 2 Post By BikerPepe`
  • 2 Post By 78BroncoSteve
  • 2 Post By andrewmp8
  • 1 Post By CrazyBRONCOguy
  • 1 Post By deathmobile2
  • 1 Post By 78BroncoSteve
  • 1 Post By arse-sidewards
  • 1 Post By cheepsk8
  • 3 Post By silver70
  • 1 Post By wyatt earp
post #1 of 17 (permalink) Old 02-15-2017, 10:02 PM Thread Starter
My Little Mule's Avatar
Bronco Info: 1979 Bronco 351m
Question trail riding and sway bars
Hi All!
As stated before I am getting the BKO ready to do some mudding and trail riding. Nothing to serious just weekend fun once a month.
Question is.
I have been looking for front diff protection and it seems that every picture I see shows the front diff without a front sway bar.
Is it easier to trail without that thing hanging down in front of the diff?
Should I remove it?
How are the on-road manors without it?
How about the off-road manors?
Any suggestions?
Thanks for helping the new guy out!
CDA 455 likes this.
79 Bronco
71 Torino
67 Charger
My Little Mule is offline
post #2 of 17 (permalink) Old 02-15-2017, 11:42 PM
Harley's & Bronco's FTW!
they help to eliminate "body roll" in the corners by keeping the suspension a little stiffer, side to side.
removing the sway bars allows the front end to articulate flex more/better.
many just remove them altogether, some make detachable points on them like the jeepers.
I removed them on my old '89 and difference was minimal on the road and noticeably better off.
most of us aren't trying to turn tight corners and break-neck speeds. if you are/do then you may want to keep 'em.
My Little Mule and CDA 455 like this.
BikerPepe` is online now
post #3 of 17 (permalink) Old 02-16-2017, 08:03 PM Thread Starter
BikerPepe, Thanks for the input. I am thinking I am going to ditch the sway bar and see how it goes. I did end up buying Duff diff skid plates. Would be a shame to bend up the sway bar and hurt the diff by not using it.
CDA 455 likes this.
79 Bronco
71 Torino
67 Charger
post #4 of 17 (permalink) Old 02-17-2017, 12:12 AM
78BroncoSteve's Avatar
Took mine off (front and rear) on my 78. Overall the ride quality improved greatly for me. I had/have all new suspension as well, so that probably helps the stability factor. Still though, much less head bobbing when turning in to inclined driveways at 45 degree angles and such. It just flexes and is compliant.
I'll keep mine for originality as my Bronco came with the "handling pkg" as part of the Freewheeling pkg, but I'll never reinstall them.
78BroncoSteve is offline
post #5 of 17 (permalink) Old 02-17-2017, 02:31 AM
On road you kinda need the front one,Off road you don't need one at all.Most of the jeep guys use a sway bar disconnect which lets you unhook it for off road and hook it back up for on road,But no one makes them for broncos but you could figure out what your swaybar end links length is and find a swaybar dicso the same length.
andrewmp8 is offline
post #6 of 17 (permalink) Old 02-17-2017, 05:56 AM
Ford Hoarder
Half true,
https://desolatemotorsports.com/shop...-sway-bar-kit/
Its expensive but should be easily removable for ultimate flex.
Not sure if your bronco does, but with the quad shocks up front the difference between no sway bar and sway bar is even less noticeable, assuming you have good quality not worn out shocks on it.
CDA 455 likes this.
CrazyBRONCOguy is online now
post #7 of 17 (permalink) Old 02-17-2017, 08:51 AM
deathmobile2's Avatar
That is one nice piece of kit. Sweet engineering.
CDA 455 likes this.
deathmobile2 is online now
post #8 of 17 (permalink) Old 02-17-2017, 09:26 AM Thread Starter
Bronco Steve, My shocks appear to be oringinals! I do plan on buying new shocks before I hit the trail. Which will be a subject for another forum search and post I am sure. Then when I can get to it new body mounts will be in order, with maybe a small lift. I am also going to put on some 35" tires as well.
Thanks for the help!
CDA 455 likes this.
79 Bronco
71 Torino
67 Charger
post #9 of 17 (permalink) Old 02-17-2017, 09:29 AM Thread Starter
Andrew,
THanks for the idea, never thought of that.
CDA 455 likes this.
79 Bronco
71 Torino
67 Charger
post #10 of 17 (permalink) Old 02-17-2017, 09:34 AM Thread Starter
Originally Posted by CrazyBRONCOguy View Post
Half true,
CrazyBRONCOguy,
The cost of that would pretty much eliminate that as an option for me. My shock are shot! They pretty much look like the original ones! I will be getting new shocks before I hit the trails.
My BKO does not have the quad shock set up although I have been looking for a set to install on my Bronco. If you have a set..........
Thanks for the advice.
CDA 455 likes this.
79 Bronco
71 Torino
67 Charger
post #11 of 17 (permalink) Old 02-17-2017, 01:02 PM
Of course! Here's a good read for you and it'll save at least one search: http://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/423985-2-lift-78-a.html
CDA 455 likes this.
post #12 of 17 (permalink) Old 02-18-2017, 05:02 PM
Bronco Info: 94 F150 8ft 4x4 4.9L, E4OD
I've never had sway bars and never felt the need for them.
CDA 455 likes this.
'94 F150, 4.9L, lunchbox locker, extended RAs, 66" leafs, manual steering
...................____ ___
_________ ||__,\\___\\,_____
|]__/---\__||__ ||/---\_[-\==/-]
_ __(o))-0---))_ _(o))-----o))______________
arse-sidewards is offline
post #13 of 17 (permalink) Old 02-18-2017, 07:41 PM
Bronco Info: 1979 $300
Took mine off first thing. Getting better fuel economy. Haha
CDA 455 likes this.
cheepsk8 is offline
post #14 of 17 (permalink) Old 02-18-2017, 10:11 PM
Eric
Sway bars are for body roll. Not shock absorbtion, not ride height. The BKO is top-heavy and, since the intro of modern interstates, people have developed the habit of taking merge ramps at higher speeds. To negate the ill effects of, possibly, rolling your vehicle while taking an interchange ramp at 80 mph, vehicle manufacturers integrated anti-sway bars into vehicle design. If you're a "conscientious" driver, this should not be an issue. If you drive an SUV like an SUV, and not a Ferrari, you will be fine.
However, if you are subjected to rapid lane changes and "evasion" tactics due to idiot drivers on a 20-30 mile freeway commute everyday, you should keep the sway bars on. People are dumb and will kill you. -_-
Eric
BikerPepe`, wyatt earp and CDA 455 like this.
silver70 is offline
post #15 of 17 (permalink) Old 02-19-2017, 09:15 AM
I have both front and rear on mine, because I believe it helps when towing my boat. Tight winding roads, and steep descents, with a 2000 lb. trailer, make the sway bars very helpful. If anyone thinks that their sway bar doesn't do squat, I suggest that they look at their sway bar bushings. If the body is not rolling, then why are those bushings so smashed and worn?
silver70 likes this.
wyatt earp is online now
post #16 of 17 (permalink) Old 02-19-2017, 12:31 PM
I did forget, that this thread is about trails and mud, so go for it, remove them.
post #17 of 17 (permalink) Old 02-19-2017, 08:20 PM Thread Starter
Wyatt,
Thanks for your input! And for remembering the topic. The BKO is not a daily driver and only used on weekends for pleasure riding. I will try with the sway bars off for trail riding and I may just bolt them back on afterwards.
Thanks again
79 Bronco
71 Torino
67 Charger
