E303 in a 351w - Ford Bronco Forum
 6Likes
post #1 of 21 (permalink) Old 03-13-2017, 07:58 AM Thread Starter
E303 in a 351w
I've had one in mine for a while and haven't been happy with it just looking for anyone's feedback on it .
Bill88stang is offline
post #2 of 21 (permalink) Old 03-13-2017, 08:14 AM
I know quite a few guys have used that cam..what specifically aren't you happy with?
jermil01 is offline
post #3 of 21 (permalink) Old 03-13-2017, 11:37 AM
sackman9975's Avatar
I ran that cam for about 10 years. I was happy with it, but it kinda sucked to tow with specially on hills.
But power, had lots of it.
What is it that you're unhappy with?
sackman9975 is online now
post #4 of 21 (permalink) Old 03-13-2017, 03:17 PM
natedawgg94's Avatar
Bronco Info: 1989 bronco
I've put a few Ecam's in mustangs and like them. Seems there might would be a few better options for a 4wd and towing. What you unhappy with??
1989 Bronco project rig
1994 Mustang Cobra Pace Car #365 of 1000
1997 Mustang GT DD
2002 F-150 Crew Cab FX4 6" lift and 35's
1978 f-150 Ranger 2wd project demon
natedawgg94 is offline
post #5 of 21 (permalink) Old 03-13-2017, 04:55 PM Thread Starter
I've had it in my lighting for about a year and just disappointed in the lack of low end and seems to be a pig gas mileage wise . I prolly shouldn't be disappointed I should have known it wouldn't have much down low . I used it since I wasn't reusing stock cam. I'm debating pulling the timing cover off and advancing it 2-4 degrees and seeing how that helped.
post #6 of 21 (permalink) Old 03-13-2017, 08:23 PM
Have you tried running it at 13 degrees before TDC?
post #7 of 21 (permalink) Old 03-14-2017, 07:58 AM Thread Starter
Yea and did not notice much difference. Wondering if any of you ran it in your broncos or f150's. like I said I am pondering pulling off timing covering and advancing it 4 degrees to bring back some low end. I need to be able to do some towing . I've also considered removing it for the stock ho mustang roller cam I was thinking that would work better for low end.
post #8 of 21 (permalink) Old 03-15-2017, 08:12 AM Thread Starter
Sackman what was the test of your combo? Did you install the e cam dot to dot or was it advanced at all? This thing also seems to just be a pig on gas, I ran a larger flat taller cam in my previous motor before it spun a bearing and it got way better fuel mileage I chalked it up to the e303 just being a poor choice
post #9 of 21 (permalink) Old 03-15-2017, 12:15 PM
Bored .030
Heads shaved to 59cc's
Fully Balanced rotating assembly
3 inch full exhaust
Timed at 13 BTC
I believe I was pushing 300 HP, and at least 350 ft lbs of torque, however I never had it tested. I did 0-60 in 8 secs though
UHKBV_JcIjU
https://youtu.be/UHKBV_JcIjU
Dot to dot
Yeah, they're all pigs lol, but we love to drive 'em!! I remember only checking the mileage one time. 250 mile trip towing a trailer full of wood. I got 12 MPG's and was happy with it.
silver70 likes this.
post #10 of 21 (permalink) Old 03-15-2017, 09:18 PM
Eric
Originally Posted by sackman9975 View Post
Bored .030
3 inch full exhaust
Timed at 13 BTC
Hey Sack, what were your gears and tire size for that run? Kinda impressive for a DD BKO.
sackman9975 likes this.
silver70 is offline
post #11 of 21 (permalink) Old 03-15-2017, 09:19 PM
3.55 gears, 31x10.50 tires
post #12 of 21 (permalink) Old 03-15-2017, 09:36 PM
Eric
Last question: Did you have to tune, or, was the MAF okay with the cam?
I just looked up the specs. 110* LSA for the E cam. Just wondering if the, stock, MAF can cope with something that close, or, not.
Thanks,
Eric
silver70 is offline
post #13 of 21 (permalink) Old 03-15-2017, 09:40 PM
Thanks,
Eric
Lol..... no tune.....no MAF either. Speed Density on my old 95. They said it wouldn't work......
That cam specs says only works with MAF, but I proved that wrong.
Question for you: is my video working that I posted? Showing on my phone "the plugin not supported"
post #14 of 21 (permalink) Old 03-15-2017, 10:03 PM
Eric
Okay.... that just makes it friggin' cool. Seriously? SD?! That's a very dicey cam for SD. This new point begs another question: Any CEL's or codes? There's gotta be something. In all technical reasoning, your truck should run lean with that cam on stock SD fuel maps. I mean, it apparently doesn't, but..... how?
Also, yes, the video works fine for me. I enjoyed every second of it.
silver70 is offline
post #15 of 21 (permalink) Old 03-15-2017, 10:10 PM
No CEL's or codes either
post #16 of 21 (permalink) Old 03-19-2017, 11:08 AM Thread Starter
Have a vid of it idling? You still currently run this cam? Stock converter too? What about injectors ?
post #17 of 21 (permalink) Old 03-19-2017, 11:08 AM Thread Starter
What's your compression also?
post #18 of 21 (permalink) Old 03-19-2017, 11:36 AM
Video is link in my signature. See below
Sold the truck to guy at work. Stock converter, stock injecctors too.
Engine builder said compression was at 9.2 :1
post #19 of 21 (permalink) Old 03-19-2017, 01:23 PM Thread Starter
Can't believe it idled that well speed density wise I would never have luck like that. Haven't driven mine in almost 2 years since my e4od died in my 94 lightning. Been searching for a decent priced used one since .
post #20 of 21 (permalink) Old 03-19-2017, 08:48 PM
Eric
I'm wondering if it's a roller 5.8L. The ramp rates on roller cams are more aggressive than flat tappet and could be responsible for developing enough vacuum to keep the MAP sensor happy. Just a theory.
Hey sackman, was that 351W a roller motor?
silver70 is offline
