Cold air intake? - Ford Bronco Forum
 10Likes
  • 1 Post By sackman9975
  • 1 Post By Aaron's Mud E 1
  • 1 Post By CrazyBRONCOguy
  • 3 Post By miesk5
  • 1 Post By CDA 455
  • 2 Post By Mikey350
  • 1 Post By BikerPepe`
post #1 of 17 (permalink) Old 03-15-2017, 07:18 PM Thread Starter
Aaron's Mud E 1's Avatar
Bronco Info: 90 FSB Custom. 302. known as Mud E1. 2 in level with an Aussie locker up front with manual hubs.
Cold air intake?
First, I'm sorry if this has been asked and answered. I recently bought a 90 custom with a 302. I'm curious what kind of benefits I would really get by converting it to a cold air intake? The tricky part, maybe is the fact that the motor is from 03. Any recommendations or advice or tips or product recs.
Aaron's Mud E 1 is offline
post #2 of 17 (permalink) Old 03-15-2017, 07:39 PM
Yo Aaron's Mud E 1,
Cooler intake air increases airflow by lowering airtemperature. As air gets colder, it gets denser, thus this air contains more oxygen within a smaller volume. More oxygen means more power Google it for more info.
Cheapest improvement is Air Tube & Box Insulation;
miesk5 Note; Ken used Reflectix Insulation, avail @ Lowes. etc. ST16025 - 16" x 25 feet. Ken installed the K&N & removed the cold air intake tube that runs to the top of the radiator; but he could have installed the intake tube section later. One pic for example:
See more pics @ 1994 Ford Bronco insulating air box and intake tube pictures, videos, and sounds | SuperMotors.net
Source: by Ken B (Kenny's 94)
Also see FOUR WHEELER Magazine's Project M.P.G..
Not a typical Bronco, but has some test info. Although not everyone agrees with their findings, sorta typical of drag racers, and others.
post #3 of 17 (permalink) Old 03-15-2017, 08:20 PM
sackman9975's Avatar
Welcome Aaron!
The motor is probably not from '03 rather rebuilt in '03.
Besides......I think someone here knows that truck! Lol
Cold air intake.. eeh. Don't waste your money.
beernut likes this.
sackman9975 is online now
post #4 of 17 (permalink) Old 03-16-2017, 12:42 PM
Yo,
As sackman advised. I forgot to mention to install a stock air inlet atop radiator, tubing and filter box with the insulation. Get parts from a yard queen.
post #5 of 17 (permalink) Old 03-16-2017, 01:42 PM Thread Starter
Turns out this truck is more than well known around here, lol. I love the truck that's for sure. Already replaced all shocks including the front aux. set that wasn't there and have a stabilizer on the way. Replaced a leaking pinion seal, trying to find a knock in the rear when I corner (any ideas).
I know the concepts of the cold air and why it's done. But who has done it and was it worth the gains and any recommendations on product?
BikerPepe` likes this.
post #6 of 17 (permalink) Old 03-16-2017, 02:14 PM
Ford Hoarder
They are saying that the cold air intakes that a readily available for these trucks air actually not cold air intakes by design. They put an open air filter on the end of the intake tube inside the hot engine bay. So they are really warm air intakes.
The factory parts actually seal the air filter in and pull air form the radiator area. Either from the top, or right behind core support if you have the 460/4.9 air tube.
Most of the aftermarket ones are also not a very good choice for water and mud as they are so wide open under the hood.
If you are just running on the street and do not care, the air intakes available do seem to increase throttle response a little, but it also could just be a mind game by product of hearing the air being sucked in too. I do not think actually helps much, you would get similar gains putting a good filter in the stock box and insulating it. or making your own that draws air from inside a fender or the like, much like any performance oriented car would have. You could also create you own box to house a sizeable cone filter with a tube that draws form somewhere not in side the engine bay. This approach is not easy but I think would offer something.
Fast Floyd likes this.
CrazyBRONCOguy is online now
post #7 of 17 (permalink) Old 03-17-2017, 12:16 PM
This 460/300i6 inlet tube is the only worth while upgrade, besides the aluminum heat shield posted above. It slides through an opening in the core support.
BigBlue 94 is offline
post #8 of 17 (permalink) Old 03-17-2017, 01:35 PM
.... But who has done it and was it worth the gains and any recommendations on product?
Yo,
The results are in the FOUR WHEELER Magazine's Project M.P.G. link I posted. Here are the insulated box and tubing results;
See Results for #5
Read results narrative @
But forget the K&N filter, box, etc and as CrazyBRONCOguy advised, use a quslity filter and moving inlet point-of-entry; such as Motorcraft; and consider another inlet path such as Fender Intake, K&N® w Stock Air Box info & pics in a 96 5.8
Source: by DNBELOWBRONCO (Kevin, Labor of Love) at 1996 Ford Bronco Stock intake/ K&N tube combo pictures, videos, and sounds | SuperMotors.net
Three 3 pics for example,
"Gas hose cut lengthwise to cover sharp edges while household window screen keeps debris out."
But iggie the K&N filter
Or consider a Snorkel:
Fabrication & Installation through fender in a 90: by 90Beater (Topher, Chris) at Tophers World Bronco Site
Fabrication & Installation through fender in a 90 5.0
Source: by votum at Home made Snorkel - Ford Bronco Forum
Also see pics by Kingfish on page 2
CDA 455, Fast Floyd and fodder like this.
Last edited by miesk5; 03-17-2017 at 01:40 PM. Reason: Changed pic url for votum's
post #9 of 17 (permalink) Old 03-17-2017, 03:45 PM
MidlifeCrisisUndrWay
CDA 455's Avatar
It's interesting you should bring that up.
During my racing days I used to use NACA ducts for intakes. I was thinking about putting one on the hood in front of the air box.
Do an airflow test on the hood to see how air flows (flow direction) over that part of the hood and then mount the NACA duct in the direction of the confirmed airflow direction.
Here's a pic of tufts on a vehicle during an airflow study:
μολὼν λαβέ
CDA 455 is offline
post #10 of 17 (permalink) Old 03-17-2017, 08:25 PM
JohnMcD348's Avatar
Question, if you might be able to answer it on that image.
Wouldn't the green area be a Low pressure area? I'm thinking of those lines in the same manner as a wing or foil where the pressue above the line would be lower, allowing the higher pressure below to lift it.
Am I wrong about what' s happening with the air flow on that vehicle or am I just looking at the wrong parts for results?
JTMcD.
JohnMcD348 is offline
post #11 of 17 (permalink) Old 03-18-2017, 11:49 PM
CDA 455's Avatar
For an airfoil; yes, there is a low pressure area.
But the vehicle in question doesn't have an airfoil shape to take advantage of.
μολὼν λαβέ
CDA 455 is offline
post #12 of 17 (permalink) Old 03-20-2017, 12:25 PM
JohnMcD348's Avatar
So then, the green area would be where you would install a ram intake?
JTMcD.
MY A/C Vacuum leak repair http://www.fullsizebronco.com/forum/showthread.php?t=175808
post #13 of 17 (permalink) Old 03-20-2017, 01:55 PM
CDA 455's Avatar
That; and the tufts that run along the upper side of the bonnet (Above the green circle).
Those are good airflow areas for a NACA duct.
Said NACA ducts scavenge air from the boundary layer which lies next to the surface. If you look close crucial air intakes are mounted with the opening several inches away from the surface due to boundary layer. Boundary layer is a layer of still air next to the surface. So designers and engineers design air scoop openings away from said surface.
Here's a pic of a P-51's supercharger intake:
JohnMcD348 likes this.
μολὼν λαβέ
CDA 455 is offline
post #14 of 17 (permalink) Old 03-20-2017, 10:55 PM
That opening on the bottom is NOT the supercharger intake, it is the radiator (oil cooler).
JohnMcD348 and CDA 455 like this.
Mikey350 is offline
post #15 of 17 (permalink) Old 03-20-2017, 11:24 PM
CDA 455's Avatar
Originally Posted by Mikey350 View Post
That opening on the bottom is NOT the supercharger intake it is the radiator (oil cooler).
Thanks for correcting me. I got sidetracked and was thinking of the P-47 .
Regardless; the point stands regarding the boundary layer and intake design.
μολὼν λαβέ
CDA 455 is offline
post #16 of 17 (permalink) Old 03-27-2017, 03:50 PM
Harley's & Bronco's FTW!
well I missed this thread somehow.
Aaron... you mention you're having a clunk or noise while turning? Are the front hubs locked when you're hearing this noise on turns? If the front hubs are locked, the Aussie locker is trying to engage but won't because the t-case isn't locked in. That causes the plates to clack together, making noise but not being able to engage. I generally left the front hubs in "Free" position, until I really needed to go into 4x. This was different than how I've used any previous Bronco over the years, w/out a locker in the front... which I would drive around most of the winter w/hubs locked and ready to engage 4x at a moments notice. It is one short-coming of the Aussie locker... but the flip side is, when you really need it, it's hard to beat the traction a locked front end will give you.
Aussie lockers are very noisy but it's not an indication of a real problem. Read the Aussie info pamphlet included in the booklet I gave you with the Bronco or check the info on their site. For a noise free locker... you'd have to look into spending some serious money for a air or electric lock type locker. The Aussie is the definitive "lunch-box" locker, cheap and noisy but strong and effective.
The motor in question will be the same as any other Ford Bronco 302 with a few exceptions. It was re-manufactured from the Engine Factory in '03. They did use different heads on it and those heads require different spark plugs. If you remove the plugs you have now... take note of the type before replacement. The PO before I bought it had the wrong plugs in it and they would barely seat properly, much less seal. The plugs recommended in Haynes manual were not the right ones either. With some help around here... we finally identified the heads and found the right plugs to use. I did so on the last tune-up and was much happier with the results.
As to the original question about the cold air intake... other than refining the stock setup, I've never really seen anything that impressive around here, like the guys are saying.
You could install hood vents and go with a open cone K&N but you'd still get some engine heat. I have considered that but I like the look and tend to think the added airflow would be great but with the weather in our area, I'd be seriously concerned about moisture on the engine (rain, puddle jumping, etc.) and that's why I never went there... well, that and I don't have money to waste.
A link to my SuperMotors account for your Bronco: 1990 Ford Bronco pictures, photos, videos, and sounds | SuperMotors.net
BigBlue 94 likes this.
BikerPepe` is online now
post #17 of 17 (permalink) Old 05-02-2017, 10:02 PM
van1987's Avatar
Bronco Info: 1994 FSB, 302 untouched, 31" Goodyear Kevlar, more to come
The cold air intake is designed to give better performance in conjunction with other upgrades. Although it will give some better performance in general that is do to less restricted airflow and not from colder air. As others have stated to get true cold air it needs to come from outside the engine bay. Cold air intakes are worth the investment if you understand the true benefit comes when used with other upgrades.
William V. Sisson
FF/EMT
van1987 is offline
