Relacement rear drivesahft - Ford Bronco Forum
post #1 of 10 (permalink) Old 03-18-2017, 07:49 PM Thread Starter
Bronco Info: 94 Bronco 5.8L engine
Good day,
I just replaced the rear drive shaft on 94 ford bronce and pulled off the front drive shaft to repalce the ujoints and found out that i need to replace that shaft also. I did not reinstall the front drvice shaft, while driving it in 2 wheel drive, There was a loud rattle sound and the bronco shakes a little, is that due to not reinstalling the front drive shaft. Or something else. If something else what cound that be?
Thanks
Tony
TonyPark is offline
post #2 of 10 (permalink) Old 03-18-2017, 07:59 PM
MS88Bronc's Avatar
Bronco Info: 1988 Bronco XLT 4x4 302/C6
Originally Posted by TonyPark View Post
Good day,
Thanks
Tony
Shouldn't be. Your t-case shouldn't be turning in 2wd, and if your hubs are free, then your front pinion shouldn't be turning either. Have you tried reinstalling your rear driveshaft 180 degrees opposite? By that I mean disconnect the rear joint, put it in neutral and spin the shaft 1/2 turn and reinstall. Other than that, I'm not sure.
MS88Bronc
1988 Bronco XLT
5.0L V8, C6, BW 1356, 3.55 LSD, 33" rubber
MS88Bronc is online now
post #3 of 10 (permalink) Old 03-18-2017, 08:21 PM
BoulderBronco's Avatar
Sounds to me like it's your rear shaft being as it sounds like it started right after you installed the "new" shaft. What exactly did you replace? The front won't make a sound with the shaft out, whether it's in 4WD or not. Try rotating the shaft 180 as MS said but I bet you have something wrong with it.
BoulderBronco is offline
post #4 of 10 (permalink) Old 03-18-2017, 08:25 PM
MS88Bronc's Avatar
Relacemtn rear drivesahft
Was the replacement dshaft a used piece? Was it checked for balance? How were the ujoints and CV centering ball? Was the double cardan "floppy" or stiff? All of these could contribute to vibration. I literally just went through this on my rig.
MS88Bronc
1988 Bronco XLT
post #5 of 10 (permalink) Old 03-18-2017, 08:30 PM Thread Starter
The new shaft is brand new. Its a masterpro shaft, its was pre balanced, when i purchased it. I will try rotating it 180 degrees tomorrow.
Thank you for the help
Tony
TonyPark is offline
post #6 of 10 (permalink) Old 03-20-2017, 05:49 PM
352Ford's Avatar
Bronco Info: 1996 XL
What made you think the old drivelines were bad? Just vibrations? or something else. I find it's usualy cheaper to replace things like slip yokes and such than buy a whole new unit.
I love projects, I have ruined my life with them.
352Ford is offline
post #7 of 10 (permalink) Old 03-20-2017, 07:05 PM
Did the rear driveshaft get installed correctly in phase? By this I mean were the yokes installed parallel to each other. Google "driveshaft phase" to see what I mean. I find it hard to believe that it came from a shop like that but you never know.
Festus is offline
post #8 of 10 (permalink) Old 03-21-2017, 12:37 PM
aka: kemicalburns
TravisITGuy's Avatar
his 94 would have a flange mount style drive shaft. how would having it not In Phase be possible? Unless of course the shaft itself was not built correctly or balanced.
TravisITGuy is offline
post #9 of 10 (permalink) Old 03-21-2017, 01:48 PM
As far as the possibility of the shaft being out of phase, not built correctly could be a way. Since the shaft is splined, it could also be put out of phase by being assembled a spline (or more) off.
the Son is offline
post #10 of 10 (permalink) Old 03-21-2017, 02:10 PM
For reference while the chain in the transfer case may not be turning, the rear output shaft and the associated parts are all turning inside the case(everything on the right) as is the oil pump..the rattling sound could be from the oil pump retainer letting loose.
jermil01 is offline
