Drivers door stuck closed - Ford Bronco Forum
post #1 of 7 (permalink) Old 03-18-2017, 10:49 PM Thread Starter
Ok, so this sucks. I have long had a problem with the power locks where they make the drivers door stuck in the locked position. When it happens, I climb in through the passengers door, pull on the handle and shove the door with my shoulder till it opens. The problem today, it that the interior door handle came off in my hand-It's broken.
Now i can't open the door at all, what can I do?
11Screwball is offline
post #2 of 7 (permalink) Old 03-19-2017, 09:54 AM
Yo 11,
Fill out your Bronco Info with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click User CP
Edit Your Details,
Scroll down to Bronco Info
Suspect actuator is defective. Test by; disconnect actuator conhector; using jumper wires connected to battery positive (+) and negative (-) or use a portable tool 12vdc batty; attach jumpers to actuator connector; reverse polarity for opposite direction.
If it doesn't move in unlock replace it. It may be weak so try and determine if it pulls or pushes with equal force.
Using a Digital Multimeter, the actuator current draw (stall test) should not exceed 6.2 amps. Reverse the power and ground leads to the connector and repeat test.
If ok try these tests.
post #3 of 7 (permalink) Old 03-19-2017, 10:08 AM
bmad01's Avatar
Bronco Info: 1988 5.0L E/B AOD, bone stock+ 1993 5.8L E/B, E4OD, 4"lift with 33's
Besides meisk5's suggestions. Spray some lock lubricant into your door locks. I have to do that on my 88 because the dust cover on the key slot is broken. Dust gets into the works and things get stiff to where the key won't unlock the door...
bmad01 is online now
post #4 of 7 (permalink) Old 03-19-2017, 10:57 AM
59Ford's Avatar
Had a similar problem, the actuators have rubber boots over them to protect them from the elements, and over time they rip apart. Then they let water and grime in. That usually kills them. When you reinstall them, make sure you clean all the lock mechanisms and lubricate them. In the mean time, can you crawl out the back window??
Sent from my SM-G928V using Tapatalk
1990 Bronco Eddie Bauer 5.0L, AOD
1959 Ford Ranch Wagon with a 460/C6
Lowered 3 inches, Mexican blanket interior, and just the right amount of patina.
59Ford is offline
post #5 of 7 (permalink) Old 03-19-2017, 06:24 PM Thread Starter
ok, i got the door open which is step one. Going to a junkyard to pick up a new interior handle tomorrow and going to open up the door and test the system after that. thanks
post #6 of 7 (permalink) Old 03-19-2017, 09:33 PM
sharpshooter109's Avatar
Bronco Info: 1989 Bronco 351w/c6
They sell the door handles at parts stores, I would probably just buy a new one, it's not worth the time/hassle to get a 30 year old plastic piece when you can buy a new one at the parts stores
If the lock actuator is what is getting stuck, you can just disconnect it until you can get a new one. Then you would just have manual locks though until you replaced it. But as suggested, the key mechanism might be stuck too. Have you tried opening it with the key when it gets stuck?
sharpshooter109 is offline
post #7 of 7 (permalink) Old 03-20-2017, 12:24 PM
96EB351's Avatar
Bronco Info: 1996 Eddie Bauer 351 e4od stock auto hubs
Not to mention that if its a '96 or something compatible they are less than $10.
little to no mechanical knowledge but i can follow directions.
96EB351 is offline
