Proper category for 3G in a 79? - Ford Bronco Forum
 5Likes
  • 2 Post By Spktyr
  • 1 Post By miesk5
  • 2 Post By the Son
post #1 of 8 (permalink) Old 03-19-2017, 11:45 PM Thread Starter
Just wondering the best and right forum for the information of my 3G alternator installation for my 79. Noobie, 78-79, or Tech?
It's detailed with which model 3G is best (for the 78-79), the materials I used, and how it all ties straight into stock 78-79 harness connecting points.
the Son is offline
post #2 of 8 (permalink) Old 03-20-2017, 05:09 AM
The Write-Up forum? Technical Write Ups - Ford Bronco Forum
locopny and the Son like this.
Spktyr is offline
post #3 of 8 (permalink) Old 03-20-2017, 09:21 AM Thread Starter
I guess I should have read here in the Tech write-up forum description:
(Mods, feel free to correct the Tech write-up description's spelling of "description" over there)
"A technical write up consists of a detailed discription, pictures and information of a particular repair, install or modification."
the Son is offline
post #4 of 8 (permalink) Old 03-20-2017, 10:46 AM
Yo T,
Will do if I can find it.
I searched through all of your posts here, but found none on the 3g title. So I am guessing that you are in process of writing it, but didn't get it posted yet.
post #5 of 8 (permalink) Old 03-20-2017, 10:58 AM Thread Starter
Yo T,
Yes. In progress. I just wanted to put it in the right place when I finish. I'm typing outside of here so I can edit, copy, and paste to post it.
What I was talking about correcting is the description of the Technical Write Ups forum. Just a hint of OCD on my part.
the Son is offline
post #6 of 8 (permalink) Old 03-20-2017, 11:14 AM
Yo T,
Ok, no problemo. Will change title.
Good idea on cooying before hitting the reply icon because I have spent hours entering a post, smacking the reply or enter only to get an error message, thereby losing all my hunt & peck narrative.
79BroncoSpringTx likes this.
post #7 of 8 (permalink) Old 03-20-2017, 11:35 AM
Depending on the amperage of your alternator sme things gotta be move around and the main alternator lead needs upgrading. I upped the cable to 1/0 for the charging lead, moved the battery + lead by the solenoid for charging and gauge and moved the alternator + lead to the output terminal for the regulator and charge/discharge gauge. Also added a breaker mounted next to the voltage regulator, I used M class oil resistant cable and used copper HD tin plated copper lugs I soldered in place. For 3G being internal regulated some stuff will need to be removed like regulator field, stator and regulator. If it were me I would get an external adjustable regulator and 2G big case as it has better cooling, and it goes 110 amp at idle and 215 at full RPM. I bolted mine in yesterday, fits nice and I can juice the voltage from 13-18 volts cut out. Also if the regulator takes a crap it is much cheaper and easier to service.
post #8 of 8 (permalink) Old 03-20-2017, 12:17 PM Thread Starter
Thanks. Yes, I have it all sorted and worked out. My only "noobie" part of this thread was which forum to put my post in because I didn't read the description of the Technical Write Ups. I just have to finish composing my Tech Write-up and then I'll post all about it.
I'm working on it with pictures and everything. It'll be in the Technical Write Up forum in a few days.
the Son is offline
