Will this have PVC? - Ford Bronco Forum
 8Likes
  • 1 Post By BigBlue 94
  • 1 Post By wyatt earp
  • 1 Post By norm
  • 1 Post By norm
  • 1 Post By CrazyBRONCOguy
post #1 of 15 (permalink) Old 04-20-2017, 05:16 PM Thread Starter
RLVBronco's Avatar
Bronco Info: 1995 Ford Bronco Eddie Bauer Edition 5.8Liter
Will this have PVC?
Ok so I'm trying to figure out if these aftermarket heads I picked, and after market cam will have PVC with stock 351W piston heads. I know there is an equation to solve this, but I forgot it. If you could help me out with this problem I'd greatly appreciate the help.
Head specs : Combustion Chamber Style Heart Combustion Chamber Volume (cc)58
Intake Valve, 1.900'' x 4.903'' o.a.l.
Exhaust Valve, 1.600'' x 4.955'' o.a.l.
Cam specs : Lift .531int/.515exh
Duration at 050 inch Lift: 227 int./241 exh.
Head gasket specs :
Bore 4.100''
Compressed Thickness .041''
Compressed Volume 9.0cc
Thank you
Edit :
Rocker ratio is 1.6,
RLVBronco is offline
post #2 of 15 (permalink) Old 04-20-2017, 05:50 PM
Pretty sure whoever can figure this out will need deck height, rocker ratio, valve length, and valve diameter.
4.100 bore is huge, why such the overbore?
I know that my .480 lift cam, with 1.7 rockers, 58cc afr165 heads, near zero deck height, and 19 cc dish pistons (stock are 22 cc dish) had no issues. But I don't know really what valves it had.
BigBlue 94 is offline
post #3 of 15 (permalink) Old 04-20-2017, 05:58 PM
Wait, how are you using factory pistons with a .100" overbore?
sackman9975 likes this.
post #4 of 15 (permalink) Old 04-20-2017, 08:23 PM
He listed Head Gasket specs, not overbore. HAHA got me at first too!
BigBlue 94 likes this.
wyatt earp is online now
post #5 of 15 (permalink) Old 04-20-2017, 08:27 PM
norm's Avatar
Bronco Info: 79 V8 C6/205
I believe he listed the bore of the head gasket, not the cylinder.
Piston to valve clearance needs to be checked, there are alot of variables.
Lift doesn't have much to do with it, duration is more of a factor.
.http://www.fullsizebronco.com/forum/image.php?type=sigpic&userid=26328&dateline=121233  5329
norm is online now
post #6 of 15 (permalink) Old 04-20-2017, 08:28 PM
norm's Avatar
Ha! I type too slow!
wyatt earp likes this.
norm is online now
post #7 of 15 (permalink) Old 04-20-2017, 08:32 PM
And I apparently can't read!
Lift has enough to do with it that it matters. However, as said above, duration, and timing as well will play a factor. The piston is only at TDC for a fraction of a second, while the valves are open for a significantly longer time.
post #8 of 15 (permalink) Old 04-20-2017, 08:33 PM
HAHA Norm beat you to it! It is a race to show up Big Bleu!
post #9 of 15 (permalink) Old 04-20-2017, 08:38 PM
norm's Avatar
The intake valve chases the piston down the hole so when it opens is the critical thing. The piston is long gone by the time it reaches max lift.
Radial clearance of the valves can be an issue with bigger than stock valves and stock pistons.
norm is online now
post #10 of 15 (permalink) Old 04-20-2017, 08:44 PM
BTW @norm that is a sick 79 you've got
post #11 of 15 (permalink) Old 04-20-2017, 08:51 PM
norm's Avatar
Thank you sir. It's the main reason i'm addicted to overtime :)
norm is online now
post #12 of 15 (permalink) Old 04-21-2017, 02:56 AM
I don't know of any equation that will determine piston-to-valve clearance.
Originally Posted by RLVBronco View Post
Ok so I'm trying to figure out if these aftermarket heads I picked, and after market cam will have PVC with stock 351W piston heads. I know there is an equation to solve this, but I forgot it. If you could help me out with this problem I'd greatly appreciate the help.,
Huh???
WHICH heads are you asking about, and I know of no equation. You have to check/verify piston-to-valve clearance during build.
the Son is offline
post #13 of 15 (permalink) Old 04-21-2017, 08:00 AM
Ford Hoarder
Agree with the above. Always good to check. Also agree on the WHICH heads as the various heads available, some move the valves around to get the best flow, therefore the stock pistons may not have the relief in the right spot. the Trick Flow Twisted Wedge is example of this.
However I also "think" you will be fine as there was no issues at all on the last 351w I put together which has a bigger cam and more of a flat top style piston then what you have listed. The block had been decked and was an earlier block as well.
the Son likes this.
CrazyBRONCOguy is offline
post #14 of 15 (permalink) Old 04-21-2017, 09:27 AM
Originally Posted by the Son View Post
I don't know of any equation that will determine piston-to-valve clearance, but none of this helps.
Huh???
And none of your post helps at all. Thanks for your ten quote post about nothing.
post #15 of 15 (permalink) Old 04-21-2017, 09:36 AM
Couldn't have said it better myself.
